Tro Adjoyan
Post by Tro Adjoyan » Wed May 22, 2019 7:35 am
Fist timer here, want to sign up this summer.
I have a suspension/chassis modified challenger R/T stock motor 6 speed. What would be the best class for me?
Tom Kamman
Post by Tom Kamman » Thu May 23, 2019 12:20 pm
CAM-C. Just make sure you have 200TW (or higher) tires.
yohan park
Car#: 310
Post by yohan park » Tue May 28, 2019 3:28 pm
Hi I have a stock 2019 VW GTI rabbit edition with DSG transmission. I looked at the rules pdf and it says "GS"?
Yohan
Shane Donahue
Post by Shane Donahue » Wed May 29, 2019 8:43 pm
Bone stock? then G-Street or (AKA GS) it is.
Ben Wysard
Post by Ben Wysard » Fri Jun 21, 2019 11:59 am
I have a 2019 fiesta st. The only mods I have on it are lowering springs and camber bolts. What class would I be in? Also this would be my first autocross
Reed Gibson
Post by Reed Gibson » Fri Jun 21, 2019 12:50 pm
Ben, your car would be in HS is you ditched the springs and camber bolts (and it'd be very competitive to boot!). Otherwise you'll slot into the STH street touring class or you can run in CST, our open catch all class.
Reed Gibson
Post by Reed Gibson » Fri Jun 21, 2019 12:55 pm
For future reference, here are the SCCA provided stock car classing guidelines, to use these first identify the street (or otherwise stock) class your car resides in.
https://www.scca.com/downloads/44544-20 ... s/download
If you have any mods, check them against this handy spreadsheet that shows the allowances for the other prepared/modified classes.
If you have mods that bump you into an alternate class (say lowered suspension which would move you into at a minimum Street Touring or ST) then you'll need to check the full SCCA rulebook to verify which class your car falls into.
https://www.scca.com/downloads/45945-20 ... d/download
(This file is a .pdf so ctrl+f and search for your make/model to easily find what classes its eligible for!)
Bush Nguyen
Post by Bush Nguyen » Sat Jun 29, 2019 11:46 am
Hi guys, i have a 2013 370z Nismo, which i know is in the STU class, but i do have Cold Air Intakes, ArT Test Pipes and a Catback Exhaust System. I am also upgrading rear diff bushing to stiffer ones, and may tune my car soon. Will that kick me into a different category?
Reed Gibson
Post by Reed Gibson » Sat Jun 29, 2019 7:53 pm
The tune and the bushings are all Street Touring legal, however your test pipe will automatically bump you up to Street Prepared (SP). I would just run STU for now, you can ask your competitors if they are ok with it as the test pipe will only give you a slight power advantage, running in SP will be brutal unless you have Hoosiers :D
Ben Natividad
Post by Ben Natividad » Wed Jul 24, 2019 9:36 am
Hello all! I have a 1995 BMW 318ti that is stock except for a welded replacement muffler past the rear axle. I checked the rulebook and my search only showed F Street prepared. Can I possibly get more clarification on what class I can be in? Thanks! Your assistance is greatly appreciated.
Anthony P.
Current CSCC Overall Champion
Post by Anthony P. » Wed Jul 24, 2019 10:50 am
Pg 195 in the 2019 rule book shows a stock 318 would go in H-Street
Ben Natividad
Post by Ben Natividad » Wed Jul 24, 2019 11:34 am
Thanks a lot!!
