You cant get more Novice than me. I have a 08 Nissan Altima 3.5 SE with 20" rims, Tein springs, SPC camber bar, RL traction bars, and rear sway bar. Engine is entirely stock except for the oil filter. I used a remote that changed it from the thimble sized original filter to a Denso 90915 20004 with fiber element. My car has the CVT, am I going to be a unicorn on the track with a CVT? What class am I going to run?
I have a CVT in this:slowljoe wrote:You cant get more Novice than me. I have a 08 Nissan Altima 3.5 SE with 20" rims, Tein springs, SPC camber bar, RL traction bars, and rear sway bar. Engine is entirely stock except for the oil filter. I used a remote that changed it from the thimble sized original filter to a Denso 90915 20004 with fiber element. My car has the CVT, am I going to be a unicorn on the track with a CVT? What class am I going to run?
My car is a:
2012 MB C63
Everything stock except for a tune
What class would I be?
2012 MB C63
Define "Tune", a dealership "tune up" at 10k miles type... or are we talking chiped / piggyback ECU etc?dboutros wrote:My car is a:
2012 MB C63
If not of the dealership type... details of the mods are needed to provide an answer.
Hi Craig,
Tune being an ECU Tune by Eurocharged. Raised HP and TQ numbers up from 450/443 to about 520/490.
Stock, I think it is in FS nationally. I'm not sure what street prepared class you bump to, but locally you probably just want to sign up for CST - a local run what you brung street tire class.dboutros wrote:Hi Craig,
Hello,
What would my 99 miata be classed in w/ the following Mods
Full suspension: Coilovers, Front/Rear sways, and polyurethane bushings
Racing Seat/racing harness
light weight battery
205 NT01 (100 treadwear)
Pedro
Pedro
- Max Hayter
- Car#: 31
STRPeTeToTe wrote:Hello,
Pedro
Tires throw him out of STR due to treadwear, though.Max Hayter wrote:STRPeTeToTe wrote:Hello,
Pedro
- Max Hayter
- Car#: 31
Oh true - off to CSP with you then
Or come join me in CSM. I'm a lot easier to beat than those nastyfast CSP guys.Max Hayter wrote:Oh true - off to CSP with you then
Please help class my car
I am not entirely new to autocross, getting back into it with a friend. However, I previously competed on the east coast with BMW CCA, and with a different car.
What class will I be in with a lightly modded 1989 BMW 325i manual?
modifications: coilovers with camber plates, 16" x 8" wheels wrapped in 205/50ZR-16 BFGoodrich g-Force Sport COMP-2 tires, E36 steering rack (give a tighter ratio than stock), "OEM" short shifter (swapped bmw shift levers for a shorter throw), poly urethane transmission mounts, wheel studs, rolled inner fender lips, and corbeau GTSII sport seats
Thanks!
Also if possible, what class would I be in with the same car above, with full suspension mods (all upgraded poly bushings, all rear alignment adjustability added), an E36 S52 OBD2 swap with cams, a tune, M50 manifold, headers, full exhaust, a lightweight flywheel, and a limited slip diff? (winter project, motor is on the stand, awaiting parts and funds )
Thanks!
- Adam Tarnoff
- Car#: 49
Re: Please help class my car
Sounds like the first car would be STX.cpalella wrote:I am not entirely new to autocross, getting back into it with a friend. However, I previously competed on the east coast with BMW CCA, and with a different car.
Thanks!
Second car would be Street Mod... but I could be wrong on that one. Someone who knows more than me will chime in soon.
#49 STX Mazda RX-8
Thanks! I reviewed the rules some more and I understand how/why it's STX... wasn't as complicated as I thought it was. Still unsure of the S52 swapped e30 though. Waiting for some more input.Adam Tarnoff wrote:
- Max Hayter
- Car#: 31
I think the Steering rack puts you in SM.
Hi Everyone -- -- I have an old SCCA car-- 1970 VW Karman Ghia -- that use to run at Phoenix and Vegas in the 80's and 90's in EM (still has a couple battle scars on it). But I've brought it back as a street car that I drive around as a play toy with a highly modified engine -- it still has the cage, window restraints, 5 point harness, etc., etc., I'm planning on being in CSM as it is on 240 treadwear X-drives -- Is there going to any issues with this classing?????
Thanks in Advance, Harold
- Art Rinner
- Car#: 83
With 240TW Tires you should run CST.
Art Rinner
#83 240ZT
#83 240ZT
Thanks Art -- I need to find the differences in the two classes
Only difference is tires.Harold Hillhouse wrote:Thanks Art -- I need to find the differences in the two classes
CALIFORNIA STREET MODIFIED (CSM):
Vehicles eligible for CSM must be capable of being licensed for street use in California, shall be
run on DOT approved tires and must meet all SCCA Solo Safety requirements.
CALIFORNIA STREET TOURING (CST):
Vehicles eligible for CST must comply with the rules of CSM, with the exception that all of the
tires mounted on the car must have a TREADWEAR number of 140 or higher molded by the
manufacturer on the sidewall.
Totally cool car!
Thank you Rick -- CST it is
Hey guys, need some help classing my cars...
2008 Audi RS4, all it has are Stasis Coilovers and oem size 255/35/19 Michelin Pilot Sports. From reading through the rule book it looks like it would either fit into BS or ESP. Just not sure if the suspension throws it into a more difficult class.
2001 Audi S4, also only has Stasis Coilovers but only 225 section width Toyo Proxes. Will the aftermarket suspension put me into STU?
Thanks in advance, I appreciate the help!
Hello guys!!!
Looking to run solo2 and practice sessions but completely lost on what class my car would fall in.
Here is all the mods on my Nissan 370z.
Engine Output: VQ37 336hp/283lbft
Engine: Church Automotive Testing, Uprev Osiris Tuning, Motordyne M370 Intake Manifold, Motordyne Advance Resonance Tuning Test Pipes (ART-Pipes), Motordyne Shockwave Exhaust E370, Amsoil Signature Series Synthetic Oils, Saikou Michi Catch Cans, CSF Performance Radiator, AFE Power Intake with DEI Reflect Gold wrap, Setrab 34-row oil cooler.
Exterior: Z34 INGS+1 N-Spec Complete Kit, LTMOTORWERKS (LTMW) Paint/Labor, Gen-X Graphics.
Drivetrain/Transmission: Stock
Suspension: M7 Super Street Performance Coilovers, Motordyne Adjustable Sway Bars.
Brakes: Winmax W2 Brake Pads, Z-Speed SS-Lines, Amsoil DOT 4 Brake Fluids.
Wheels: Rays: Gram Lights 57Xtreme 19x9.5 +22 Front, 19x10.5 +12 Rear, Ti-Tek USA Lug Nuts.
Exterior: Z34 INGS+1 N-Spec Complete Kit, LTMOTORWERKS Paint/Labor, Gen-X Graphics, MYJAPANDIRECT JDM rear fog lamp.
Tires: 245/40-19 (Front) 275/35-19 (Rear) Continental Extreme Contact DW
If you aren't running National events that 370 is a perfect fit for our very popular local CST class.
Nationally might have to run ASP, which would be painful. Or SM.
Steve Ekstrand wrote:If you aren't running National events that 370 is a perfect fit for our very popular local CST class.
Thank you!!!! CST class it is!! Cant wait....
Would this intake duct cause a bump out of STU?Adam Tarnoff wrote:crazyjeys wrote:New to the forum... new to the sport...
I don't know what class my car will fall in to.. hopefully someone can help...
2005 350z. mods are:
intake
cat-back exhaust
coilovers
camber arms (front and rear)
upgraded sway bar (front and rear)
18x9.5 wheels with 265/35 Federal 595 RSR
stillen front splitter
Sounds like STU. I wouldn't worry too much about classification if this is your first run with us. Sign up for Novice, then select the STU modifier. That way you'll be classed against other novices. Also on this forum, since a lot of us know each other, it is a good idea to actually use your real name for the forum. It makes it easier to communicate.
- 43258d1211879499-brand-new-varis-style-carbon-fiber-air-duct-sale-slide_10.jpg (68.3 KiB) Viewed 18667 times
