Moderators: Mike Simanyi, Michael Palero, Leonard Cachola
chrispark
Car#: 7
Post by chrispark » Wed Jul 20, 2016 1:47 am
I have a AMS Alpha 7 Nissan Gt-r. What class is that?
Robert Puertas
Car#: 44
Post by Robert Puertas » Wed Jul 20, 2016 8:00 am
Depends on your tires.
CSM if treadwear is <140
CST if treadwear is = or >140
DGao
Post by DGao » Fri Jul 22, 2016 11:37 pm
Hi all,
I'm new to autocross, can you please class my car?
Bone stock 2004 BMW 330CI
Tires:
245/40-17 FALKEN ZIEX ZE-612+ 40R R17
225/45-17 FALKEN ZIEX ZE-612+ 45R R17
Thanks!
Scotitiealan2010
Post by Scotitiealan2010 » Sun Jul 24, 2016 11:55 am
Need help classifying my car. A friend of mine told me I'm in smf. But I don't believe so.
07 civic si 4 door sedan.
Mods are
hybrid racing shift bushings,
Short throw shifter
Cold air intake
Light weight flywheel
17x8.25 wheels with 215/45/17 tires
Megan rear tie bar
Front strut bar
Carbon fiber hood
Weighted Shift knob
Kevin Pao
Post by Kevin Pao » Mon Jul 25, 2016 9:14 am
The carbon fiber hood places your car in SMF.
BryanFlores
Post by BryanFlores » Mon Jul 25, 2016 10:05 am
Hello all,
I've been reading the rule book and need some help with classing my car.
2006 Mitsibishi Evolution 9
Engine:
-built 2.3l
-Manley 100mm crankshaft
-Manley rods
-Weisco 1400HD Pistons
-ported Intake manifold
-Ported Exhaust manifold
-Ported throttle body
-GSC S2 cams (275 cam)
-Forced Performance FP Black Turbo (56lb I think)
-3 port boost controller
-Speed density with 4" intake
Transmission:
-Quartermaster 8-leg twin clutch
Wheels:
-Enkei NTO3 18 x 9.5
-Federal 595 RSR
Suspension:
-KW -V3
Interior:
-AEM Guages
Fuel:
-Dual Walbro 255
-FIC 2150cc injectors
-Custom steal bradded fuel lines
-E85 Fuel
I think that's it but I'll update if I can think of anything else. The car will be making close to the 500hp mark but I'm going to drop the HP a bit depending on how it handles at that power. Thank you in advance!
Bryan
Steve Lepper
Car#: 355
Post by Steve Lepper » Mon Jul 25, 2016 12:53 pm
I would sign up for our local class CST, which is run-what-you-brung on 200tw or more tires (which i think the Federals are?)
BryanFlores
Post by BryanFlores » Tue Jul 26, 2016 9:28 am
Thank you Steve!
PeTeToTe
Post by PeTeToTe » Wed Jul 27, 2016 1:24 pm
Hey all,
I was wondering what run groups I can register for in a stock 06 MX5, for Sunday's Event that happen to be in either groups 1 or 2 (I can only make it if I run early)? SS? STS? ... I don't mind if the car is not competitive just need some class that is not TO. Also since I'm asking what would the normal class be for the mx5, STR???
Post by Craig Naylor » Wed Jul 27, 2016 8:19 pm
Steve Lepper wrote:I would sign up for our local class CST, which is run-what-you-brung on 200tw or more tires (which i think the Federals are?)
Actually the tires he posted are 140TW,
If we updated the rules to match ST classes @ 200TW, he would be in CSM.
If we did not make that update, and 140 is still the break point then CST.
Since our rules posted online are several years outdated... I'm not sure..... :(
Post by Craig Naylor » Wed Jul 27, 2016 8:41 pm
PeTeToTe wrote:Hey all,
You didn't mention any Mod's.
A bone stock '06 Miata - CS
Any modification (including non-OE rims) can, and will likely, alter that.
Run groups are not yet posted, so can't address what you may be legal to run in in the 1st or 2nd run group at this point.
That said... here is a general hierarchy of classes you car is potentially legal for from lowest to highest.
CS - STR - CSP - CST - CSM - SSM - DP - EM
The higher you go the bigger a shellacking you may take... but you'll be running in a class you car is legal for,
PeTeToTe
Post by PeTeToTe » Wed Jul 27, 2016 9:08 pm
Thanks Craig!!!
Car is bone stock, no mods and crap tires lol.
Do you guys know where to find all the classifications and rules for each class are? I've looked for it a lot and can't find it.
Post by KJ Christopher » Wed Jul 27, 2016 9:54 pm
PeTeToTe wrote:Thanks Craig!!!
http://www.scca.com/pages/solo-cars-and-rules
Post by Rick Brown » Wed Jul 27, 2016 11:24 pm
Craig Naylor wrote: Run groups are not yet posted, so can't address what you may be legal to run in in the 1st or 2nd run group at this point.
Run groups have been posted in the MSR flyer since just after the event opened. And the groups show up on the MSR entry list.
willeastenP
Post by willeastenP » Fri Jul 29, 2016 9:28 am
Hi I need some help and have some questions about my car.
73 Porsche 914 heavily modified it has a small block Chevy 350 that's got some work, Porsche 930 trans, 911 5 lug conversion and breaks, 911 suspension, fuel cell, roll bar/ cage that extends front to back, 5 point harness, tires are Dunlop Direzza Z2 225/50R16
Dunlop Direzza Z2 205/50R16
Will the roll bar/ cage be an issue ? I also have a Helmet with a 2010 snell approval will this work?
Post by Rick Brown » Fri Jul 29, 2016 11:30 am
willeastenP wrote:Hi I need some help and have some questions about my car.
Looks like E Modified to me, with that size engine, minimum weight is 1800lbs. Helmet is OK. Go to this page: http://www.scca.com/pages/solo-cars-and-rules and read Section 18 (Modified Rules) and Appendix C (Roll Bar Rules).
Is this a race car or is it streetable? If it is a street car (or could be) you can also run in our local CST class which is basically anything that could be street licensed on 200 or greater tread wear tires.
Phil Juncker
Post by Phil Juncker » Fri Jul 29, 2016 10:42 pm
Current:
'13 Fiat Abarth
Stock Tires and wheels (205/40R17 BSW all-season, Pirelli P-Zero Nero Three-seasons)
Eibach Pro Suspension
Near Future:
Koni Yellow rear shocks
Beefier rear sway bar (RRM)
Piggyback ECU unit
What would my current vs future class be?
Thanks!
Kai Hur
Car#: 114
Post by Kai Hur » Sat Jul 30, 2016 3:04 pm
Phil Juncker wrote:Current:
'13 Fiat Abarth
Near Future:
Piggyback ECU unit
Thanks!
You would be in STX (Street Touring Xtreme) both now and in the future. The fact that you have the Eibach Pro Suspension already took you out of stock class. You can add the beefire rear sway bar and still be stock legal, but not the suspension.
Forenz Arabian
Post by Forenz Arabian » Mon Aug 01, 2016 11:00 pm
Hi,
I am new to Solo *in Southern California* and I would like to know the class of my car. *I live 5 minutes from El Toro Airfield* I used to participate in eastern Canada.*
I have a 2001 Boxster S and my goal is to keep it as low as I can in class.
At the moment, mechanically the car is completely stock, with the spare and tools removed. But I have already replaced the seat with a Sparco Sprint and installed a 6 point harness.
Another factor probably bumping my class is my rear tire width is 265(*300 threadwear*) as recommended on the stock 18s. Correct me if wrong, but both those items put me in STX.
Since, my rear tires are basically driving my class( I do not plan to replace them). This should allow me to replace shock/springs, sway bar as long as they use the same mounting methods.(+ camber plates).
Question: Rear Toe arms. Is it allowed to install adjustable ones? 14.8.B rule states no replacement of material for the bearing. So I could have them adjustable but no rod-end?
Thanks for your time!
*EDIT*: As requested by the next post I replaced my "phony name" by my real name, added thread wear.
Last edited by Forenz Arabian on Tue Aug 02, 2016 6:55 pm, edited 3 times in total.
Bill Martin
Car#: 74
Post by Bill Martin » Tue Aug 02, 2016 1:25 pm
These are just generic comments:
1. When advising people on CSM/CST, people are using different treadwear requirements. Unless CSCC changed the rule when I wasn't looking, the break is at 140 not 200.
2. New posters coming here for initial recommendations -- not clear if they're CalClubers or from elsewhere and they just found our site. Obviously CSM/CST recommendations won't help the latter.
3. New posters almost always register with phony screen names. No problem, they don't know better. But unless we want to go down that path we should always alert them to our policy of regular names for registration. It's been kind of hit and miss.
4. We have the rules right here on our site. I don't think we share that information enough.
2012_SoCalWRX
New and Looking to Class My Car
Post by 2012_SoCalWRX » Sun Aug 21, 2016 1:11 pm
Hi, I'm new to autocrossing but really interested in doing some auto x events. I have a 2012 Subaru Wrx Sedan that has a Stage 2 tune as well as an AEM intake, Agency Power Downpipe, and a Nameless Axle Back Exhaust. My tires are also upgraded to 255/35/r18. I don't know how this effects me classing wise, so any help is greatly appreciated. Thank you very much and I look forward to meeting new people at each event, as well as pushing our cars to the limits.
Justice
Gerald Judianto
Post by Gerald Judianto » Mon Aug 22, 2016 12:37 pm
What's the difference between STR and CST? I recently saw a non-factory turbo'd miata running STR.
Kevin Pao
Re: New and Looking to Class My Car
Post by Kevin Pao » Mon Aug 22, 2016 2:36 pm
2012_SoCalWRX wrote:Hi, I'm new to autocrossing but really interested in doing some auto x events. I have a 2012 Subaru Wrx Sedan that has a Stage 2 tune as well as an AEM intake, Agency Power Downpipe, and a Nameless Axle Back Exhaust. My tires are also upgraded to 255/35/r18. I don't know how this effects me classing wise, so any help is greatly appreciated. Thank you very much and I look forward to meeting new people at each event, as well as pushing our cars to the limits.
Justice
I believe you would be in either STU or ASP (depending on how wide your rims are and if the tune is legal of STU)
Kevin Pao
Post by Kevin Pao » Mon Aug 22, 2016 2:37 pm
Gerald Judianto wrote:What's the difference between STR and CST? I recently saw a non-factory turbo'd miata running STR.
STR has more rules to adhere by.
CST - has to be street registered and on street tires (200 treadwear or above).
Maybe the turboed miata signed up in the wrong group?
niki smith
Car#: 710
Post by niki smith » Mon Oct 03, 2016 3:40 pm
Hello! I'll be signing up for October Autocross with Cal Club ASAP. It will be my first time.
just want to verify my 2017 stock Subaru WRX is DS class?
Also I will be running Novice all year. Do I need to add NOV or just N to my class letters? Any recommendations on a reliable place for magnets?
I will be doing a few mods eventually that may change my class but I'm hoping to understand classing more before those happen.
Thanks for the help!
Niki
