ProSolo Format
Kyle O'Rourke
Car#: 860
ProSolo Format
Post by Kyle O'Rourke » Mon Mar 18, 2019 11:51 am
I've only done the ProSolo once several years ago. If I remember right, Friday is registration/welcome, Sat is main competition, and Sun is Challenge?
If I register, compete Sat, then don't show up on Sunday, will that mess things up? I might need to catch a flight Sat night for work (hoping that my schedule changes...).
Sean Fenstermacher
Car#: 81
Re: ProSolo Format
Post by Sean Fenstermacher » Mon Mar 18, 2019 12:15 pm
Pro takes best times of both left and right side from both days.
If you no-show for Sunday then your Sunday runs will be DNS and your times will stand based on your Sat runs, iirc.
Also, trying to reg on Sat is tricky. Make sure you get there WAY early.
Ed T
Comms Chair
Car#: 711
Re: ProSolo Format
Post by Ed T » Mon Mar 18, 2019 1:35 pm
Competitions runs are Saturday AM/PM and Sunday AM. 4 runs each totaling 12. Challenge is Sunday PM, so you can reasonably do all 12 competition runs and leave Sunday afternoon if you choose to skip out on the Challenge.
ES #711 2003 Toyota MR2 Spyder
Shane Donahue
Re: ProSolo Format
Post by Shane Donahue » Mon Mar 18, 2019 4:57 pm
Normal runs do go into Sun AM, so you would have a work assignment that needs to be completed on Sunday.
Skipping Sunday entirely, without making agreeable arrangements with the Event Master/Chief Steward, would flag you as a "Did not work", likely dismissing your Sat runs entirely and not putting in good standing with National office.
Kyle O'Rourke
Car#: 860
Re: ProSolo Format
Post by Kyle O'Rourke » Mon Mar 18, 2019 7:37 pm
Alright, so I would loose 4 runs + maybe challenge. Not too bad.
Good point on work! I'll be sure contact them in advance if needed.
Kevin Huldis
Re: ProSolo Format
Post by Kevin Huldis » Mon Apr 01, 2019 4:42 am
That sounds rough. Do they make exceptions in case of an emergency?
Re: ProSolo Format
Post by Rick Brown » Mon Apr 01, 2019 10:25 am
In addition to your regular work assignment, as the event host, Cal Club members are expected to work the Challenges. While probably too late now, just like local events, there are a limited number of pre-event work assignments that count for the weekend.
