Suction Camera Mount
Brian Ernst
Post by Brian Ernst »
SCCA rule: "If using a suction-cup type of mount, you must have a secondary tether securing the camera in case the mount becomes loose."
Does anyone in this club use a single suction camera mount, or is this ruling strictly enforced? If not strictly enforced, is it okaay to use single suction cup on outside of car, or do you highly not recommend it?
CS 2007 Miata Grand Touring
Reed Gibson
Current CSCC Overall Champion
Re: Suction Camera Mount
Post by Reed Gibson »
It's not something I've ever seen called out before. As long as it's secure we are ok with it (I've used a gopro suction mount on the outside of my car before and had no problems).
Anthony P.
Post by Anthony P. »
As long as it's a full sized suction mount I'm sure it's fine. This rule was probably from pre gopro days.
Tom Tanquary
Car#: 705
Post by Tom Tanquary »
If you car is metal and not aluminum or plastic, this works great. Way stronger than a suction cup.
https://www.bhphotovideo.com/c/product/ ... MwQAvD_BwE
Ed T
Car#: 711
Post by Ed T »
Brian Ernst wrote: Mon Sep 09, 2019 5:15 pm SCCA rule: "If using a suction-cup type of mount, you must have a secondary tether securing the camera in case the mount becomes loose."
Everybody runs single suction cups with gopros outside the car. You will be fine.
While I seem to remember that, where did you find that quote? All I could find in the current 2019 Solo Rules is:
"Any cameras, if installed, must be securely mounted to withstand loads from driving maneuvers. The camera may be installed either inside or on the outside of the car. In either case, its mounting method and position must not interfere with driving or pose an additional hazard to driver, passenger, or course workers."
Brian Ernst
Tom Tanquary wrote: Mon Sep 09, 2019 9:54 pm If you car is metal and not aluminum or plastic, this works great. Way stronger than a suction cup.
Thank you for the idea!! I bought a cheaper RAM mount magnet, I wasn't sure if it would hold, but it worked perfectly! Thanks. https://www.amazon.com/dp/B00HFDNPIE/re ... FDbNASRXA4
Brian Ernst
Rick Brown wrote: Wed Sep 11, 2019 7:13 pm where did you find that quote?
I found it here: https://www.scca.com/pages/rules-and-regulations
Brian Ernst wrote: Mon Sep 16, 2019 9:09 pm
Ah, OK, Targa Rules. Each type of SCCA competition has it's own set of rules. This is the one for Autocross: https://www.scca.com/pages/solo-cars-and-rules
