who has Camber readers? -->(tapping thread help)
Kris Cho
Club: TCC
Car#: 214
Post by Kris Cho » Sat Apr 09, 2011 6:42 pm
Does anyone have the camber reading machine thing that you simply slap it on?
I installed back my stock upper A arms (can't adjust camber), and would like to see what camber it gives.
If you are close, i'll drive to your place
thanks
I'm faced with little trouble.. while i was installing hood spacers, i stripped one of the four hood bolt holes. I tried the JB weld method but didn't work.
Could someone fix the bolt hole for me? i don't have a drill and tap to do it myself. i believe the hoood is FRP.
I"ll be more than happy if someone can enlarge all four bolt holes and tap threads for me. The original bolts that came with the spacers were too big for the hood bolt holes. So for now, i'm using smaller bolt studs. These studs are too skinny for how large the inner diameter is for the spacers.
05 350z Performance
Re: who has Camber readers?
Post by Mako Koiwai » Sat Apr 09, 2011 8:29 pm
Make sure u have a perfectly level spot to do your reading
Kris Cho
Club: TCC
Car#: 214
Post by Kris Cho » Sat Apr 09, 2011 8:33 pm
i believe some camber readers don't require you to be on a flat spot.
anyone has it~?
05 350z Performance
Post by Mako Koiwai » Sat Apr 09, 2011 9:26 pm
U can also just use a straight edge, ruler and trig
Kris Cho
Club: TCC
Car#: 214
Post by Kris Cho » Sat Apr 09, 2011 11:23 pm
i'll just wait for someone to chime in w the reader.
OFF TOPIC: Do you know where i can find the rule book? i'd like to know if vented carbon hood kicks me out of BSP. vented hood won't make me go faster lol
05 350z Performance
Post by Rick Brown » Sat Apr 09, 2011 11:36 pm
Kris Cho wrote:i'll just wait for someone to chime in w the reader.
It's on our home page (solo2.com) in the right column. Or click here for the PDF: 2011 SCCA Solo Rules
Warren Leach
Post by Warren Leach » Mon Apr 11, 2011 7:39 pm
I have one Kris. But I am not close.
nalbar
Bill Schenker
Car#: 14
Post by Bill Schenker » Mon Apr 11, 2011 7:49 pm
Not legal.
Post by Steve Ekstrand » Mon Apr 11, 2011 7:59 pm
Mako to wrote:U can also just use a straight edge, ruler and trig
Leave the Palin Family out of this!
Bob Pl
Car#: 26
Post by Bob Pl » Mon Apr 11, 2011 9:24 pm
LMAO
Pretty sharp Steveo
Kris Cho
Club: TCC
Car#: 214
Post by Kris Cho » Mon Apr 11, 2011 9:29 pm
Warren Leach wrote:I have one Kris. But I am not close.
nalbar
i know you have it but too far to go there lol
I got my alignment done at Clark's with bad experience. One of couple of things is that the steering is not even close to straight.
05 350z Performance
Post by Mako Koiwai » Mon Apr 11, 2011 9:42 pm
Warren ... what type of camber gauge do you have that doesn't require a zero'ed out floor?
Post by Aaron Goldsmith » Tue Apr 12, 2011 9:07 am
Mako to wrote:Warren ... what type of camber gauge do you have that doesn't require a zero'ed out floor?
Electronic one, you zero it to a long straightedge run along the floor with the car to average floor slope.
Post by Mako Koiwai » Tue Apr 12, 2011 11:36 am
So you put your straight edge on two equal height "hats" (I use to ratchet sockets of equal heights) ... that are place where the wheels of one axle would be ... in order to calibrate to those positions? Placing a straight edge directly on the ground would be effected by local variations.
You could also use vinyl tiles to level those two areas using a bubble level ... to create a zero'ed area in your garage. Mark the two areas, noting how many tiles are required, and you then have a flat area to work on in the future.
I sold my electronic SmartCamber level. It was too much of a hassle zero'ing it out in all directions ... after I found that I could get equally accurate results using straight edge/ruler and a calculator with trig functions.
Former Club Chair
Post by Mike Simanyi » Wed Apr 13, 2011 11:33 am
Kris,
Are you in Orange County? I have a SmartCamber gauge and long level. I also have vinyl floor tiles you can use to easily create a level pad for your car, and I'll be working on alignment and suspension at my house tomorrow night and Friday night, if you want to stop by.
Richard Jung
Car#: 71
Post by Richard Jung » Wed Apr 13, 2011 1:33 pm
iphone 4, with an inclinometer/clinometer app.
Doug Kott
Car#: 300
Post by Doug Kott » Wed Apr 13, 2011 2:46 pm
You can get a fairly inexpensive digital level (from Sears, etc.) that reads to 0.1 degree. Measure the floor, measure the wheel, then subtract or add. No trig required, Palin spawn or otherwise. :thumbup:
Kris Cho
Club: TCC
Car#: 214
Post by Kris Cho » Wed Apr 13, 2011 11:06 pm
Mike Simanyi wrote:Kris,
i live in Irvine. I already got my alignment done. i don't feel like they did a good job though since the steering is still tilted to the left and i THINK i hear slight roaring sound when slowing down.I came out of the shop very unhappy with a broken rear toe bracket. It needs to be welded.
What kind of work do you do in your garage?
05 350z Performance
Kris Cho
Club: TCC
Car#: 214
Re: who has Camber readers? -->(tapping thread help)
Post by Kris Cho » Wed Apr 13, 2011 11:18 pm
the OP has been edited for help. didn't want to make another thread. :mrt:
05 350z Performance
Webster Jessup
Car#: 122
Post by Webster Jessup » Thu Apr 14, 2011 12:23 am
Doug Kott wrote:You can get a fairly inexpensive digital level (from Sears, etc.) that reads to 0.1 degree. Measure the floor, measure the wheel, then subtract or add. No trig required, Palin spawn or otherwise. :thumbup:
Even better is that they usually have a calibration button.
Calibrate on the floor, Then read the camber directly. No math needed. :thumbup:
Former Club Chair
Post by Mike Simanyi » Fri Apr 15, 2011 2:22 pm
Sorry Kris - I've had some stuff develop that's taking up too much of my time.
Maybe some other time.
Kris Cho
Club: TCC
Car#: 214
Post by Kris Cho » Fri Apr 15, 2011 8:17 pm
Mike Simanyi wrote:Sorry Kris - I've had some stuff develop that's taking up too much of my time.
no problem.
Do you have a welding machine by any chance? preferably TIG
i need some little dabs of welds on my toe arm. The long stud that screws into the rod is slightly broken off from the end bracket. I'll bring the toe arm taken off from the car.
05 350z Performance
Former Club Chair
Post by Mike Simanyi » Sun Apr 17, 2011 12:33 am
Sorry, no welder. There's no room in my garage for it!
