Course Setup for September 29-30
Reed Gibson
Post by Reed Gibson » Fri Sep 21, 2018 7:13 pm
Hey Everybody!
I'd like three helpers for Friday set up and two more for Saturday change over. Plan to start around 2pm on Friday and finish hopefully by 6 pm. Let me know if you'd like to help out! This will count as your work assignment for the next day.
Friday:
1) Vereker Tam
2) Pete Loney
3) Mo Al Rawi
Saturday:
1) Tom Frecentese
2) David Watson
Vereker Tam
Re: Course Setup for September 29-30
Post by Vereker Tam » Sat Sep 22, 2018 5:44 pm
I can help out friday.
Reed Gibson
Post by Reed Gibson » Sat Sep 22, 2018 6:24 pm
Vereker Tam wrote:I can help out friday.
Awesome, I will see you there!
Mo Al Rawi
Post by Mo Al Rawi » Sat Sep 22, 2018 8:49 pm
I can help on Friday. I can be there around 2:30. Is that OK?
David Watson
Post by David Watson » Sat Sep 22, 2018 10:48 pm
I can help with changeover Sat. afterwards.
1999 Mazda Miata, Lewis Hamilton, Ron Fellows, David Coulthard, Jacques Villeneuve, Laguna Seca, Spa Francorchamps, Racetrack of the Americas, Long Beach Grand Prix since 1992, Circuit De Gilles Villeneuve 98 -99, VARA Willow Springs BF Goodrich :crazy:
Powerglide
Post by Powerglide » Sun Sep 23, 2018 10:09 am
I can help with Sat. change. Thanks. - Tom F.
Reed Gibson
Post by Reed Gibson » Sun Sep 23, 2018 11:06 am
David Watson wrote:I can help with changeover Sat. afterwards.
Perfect you're in
Reed Gibson
Post by Reed Gibson » Sun Sep 23, 2018 11:07 am
Powerglide wrote:I can help with Sat. change. Thanks. - Tom F.
Sounds good Tom!
Pete Loney
Car#: 777
Post by Pete Loney » Mon Sep 24, 2018 10:27 am
I am looking good to be available on Friday about 1:00 PM
Will be in Fountain Valley at 11:00 beforehand at Steve Lepper's shop.
2018 Season: 777 ES | 1999 Miata, 10th Anniversary 3987/7500
MIATAROADSTER.COM, OS Giken, Kowalski Machining, PROPARTSUSA
Post by Rick Brown » Mon Sep 24, 2018 2:44 pm
A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
Reed Gibson
Post by Reed Gibson » Mon Sep 24, 2018 3:19 pm
Pete Loney wrote:I am looking good to be available on Friday about 1:00 PM
Perfect! You'll round out the gang then Pete.
Q V
Car#: 69
Post by Q V » Mon Sep 24, 2018 11:38 pm
Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
How many are we trying to get rid of? Maybe I can help remove really bad cones & donate some marginal cones for local FSAE practice? :)
Post by Rick Brown » Tue Sep 25, 2018 1:13 am
At least the amount that is stacked on the passenger side. We don't really need more than will easily fit in the designated area on the driver's side.
Reed Gibson
Post by Reed Gibson » Tue Sep 25, 2018 6:59 am
I'll create a pile of discards and donates to get us down to a more appropriate level for our storage capacity.
Reed Gibson
Post by Reed Gibson » Tue Sep 25, 2018 4:14 pm
Slight change of plans everyone. Looks like we can't get onsite for setup Friday so we'll need to do it Saturday morning instead. Please let me know if you can accommodate coming at the crack of dawn for Saturday morning setup now so I can plan accordingly!
Mike Flanigan
Post by Mike Flanigan » Tue Sep 25, 2018 6:12 pm
If Ortega is clear on Saturday morning early.......I'll be there to help.
Reed Gibson
Post by Reed Gibson » Wed Sep 26, 2018 7:45 am
Mike Flanigan wrote:If Ortega is clear on Saturday morning early.......I'll be there to help.
Awesome, thanks for always volunteering to come help out Mike, we appreciate it!
David Watson
Post by David Watson » Wed Sep 26, 2018 9:37 am
Hi Reed,
I can get there early Sat.
Post by Rick Brown » Wed Sep 26, 2018 11:22 am
And I'll be there early (though not as early as you guys) to set up timing and the motor home.
Reed Gibson
Post by Reed Gibson » Wed Sep 26, 2018 8:10 pm
David Watson wrote:Hi Reed,
No worries David, we are accounted for with workers for the wee morning hours. We'd definitely appreciate help chalking the course closer to the start time though!
David Watson
Post by David Watson » Thu Sep 27, 2018 8:43 am
Hi Reed,
what time should I arrive by?
Reed Gibson
Post by Reed Gibson » Thu Sep 27, 2018 1:37 pm
We probably won't need any extra hands until 8:00 am. No worries on showing up early, you're fine just helping out for the changeover after the event.
David Watson
Post by David Watson » Fri Sep 28, 2018 9:34 am
Cool, see you tomorrow!
