Course Setup for September 29-30
Posted: Fri Sep 21, 2018 7:13 pm
by Reed Gibson
Hey Everybody!
I'd like three helpers for Friday set up and two more for Saturday change over. Plan to start around 2pm on Friday and finish hopefully by 6 pm. Let me know if you'd like to help out! This will count as your work assignment for the next day.
Friday:
1) Vereker Tam
2) Pete Loney
3) Mo Al Rawi
Saturday:
1) Tom Frecentese
2) David Watson
Re: Course Setup for September 29-30
Posted: Sat Sep 22, 2018 5:44 pm
by Vereker Tam
I can help out friday.
Posted: Sat Sep 22, 2018 6:24 pm
by Reed Gibson
Vereker Tam wrote:I can help out friday.
Awesome, I will see you there!
Posted: Sat Sep 22, 2018 8:49 pm
by Mo Al Rawi
I can help on Friday. I can be there around 2:30. Is that OK?
Posted: Sat Sep 22, 2018 10:48 pm
by David Watson
I can help with changeover Sat. afterwards.
Posted: Sun Sep 23, 2018 10:09 am
by Powerglide
I can help with Sat. change. Thanks. - Tom F.
Posted: Sun Sep 23, 2018 11:06 am
by Reed Gibson
David Watson wrote:I can help with changeover Sat. afterwards.
Perfect you're in
Posted: Sun Sep 23, 2018 11:07 am
by Reed Gibson
Powerglide wrote:I can help with Sat. change. Thanks. - Tom F.
Sounds good Tom!
Posted: Mon Sep 24, 2018 10:27 am
by Pete Loney
I am looking good to be available on Friday about 1:00 PM
Will be in Fountain Valley at 11:00 beforehand at Steve Lepper's shop.
Posted: Mon Sep 24, 2018 2:44 pm
A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
Posted: Mon Sep 24, 2018 3:19 pm
by Reed Gibson
Pete Loney wrote:I am looking good to be available on Friday about 1:00 PM
Perfect! You'll round out the gang then Pete.
Posted: Mon Sep 24, 2018 11:38 pm
by Q V
Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
How many are we trying to get rid of? Maybe I can help remove really bad cones & donate some marginal cones for local FSAE practice?
Posted: Tue Sep 25, 2018 1:13 am
Q V wrote:Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
At least the amount that is stacked on the passenger side. We don't really need more than will easily fit in the designated area on the driver's side.
Posted: Tue Sep 25, 2018 6:59 am
by Reed Gibson
Rick Brown wrote:Q V wrote:Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
I'll create a pile of discards and donates to get us down to a more appropriate level for our storage capacity.
Posted: Tue Sep 25, 2018 4:14 pm
by Reed Gibson
Slight change of plans everyone. Looks like we can't get onsite for setup Friday so we'll need to do it Saturday morning instead. Please let me know if you can accommodate coming at the crack of dawn for Saturday morning setup now so I can plan accordingly!
Posted: Tue Sep 25, 2018 6:12 pm
by Mike Flanigan
If Ortega is clear on Saturday morning early.......I'll be there to help.
Posted: Wed Sep 26, 2018 7:45 am
by Reed Gibson
Mike Flanigan wrote:If Ortega is clear on Saturday morning early.......I'll be there to help.
Awesome, thanks for always volunteering to come help out Mike, we appreciate it!
Posted: Wed Sep 26, 2018 9:37 am
by David Watson
Hi Reed,
I can get there early Sat.
Posted: Wed Sep 26, 2018 11:22 am
And I'll be there early (though not as early as you guys) to set up timing and the motor home.
Posted: Wed Sep 26, 2018 8:10 pm
by Reed Gibson
David Watson wrote:Hi Reed,
No worries David, we are accounted for with workers for the wee morning hours. We'd definitely appreciate help chalking the course closer to the start time though!
Posted: Thu Sep 27, 2018 8:43 am
by David Watson
Hi Reed,
what time should I arrive by?
Posted: Thu Sep 27, 2018 1:37 pm
by Reed Gibson
We probably won't need any extra hands until 8:00 am. No worries on showing up early, you're fine just helping out for the changeover after the event.
Posted: Fri Sep 28, 2018 9:34 am
by David Watson
Cool, see you tomorrow!
