Tom Berry! Another Miata course?
After looking at the PAX results, and seeing the first non-HP car in 16th (Ryan), I don't think you can say that this time! And nice 2nd place!
Re: Tom Berry! Another Miata course?
Looking at those PAX results. I can almost guarantee that someone 1.1 seconds back from the leader in STR would not be top 5 in overall PAX!
No offense Marshal, I see the same thing in the SS results.
The ST* PAX factors seem way off to me compared to stock and SP classes.
none taken, we kicked your ass!Max Hayter wrote:Looking at those PAX results. I can almost guarantee that someone 1.1 seconds back from the leader in STR would not be top 5 in overall PAX!
- Jeff Stuart
Yeah, what he said!Max Hayter wrote: The ST* PAX factors seem way off to me compared to stock and SP classes.
Marshall Grice wrote: none taken, we kicked your ass!
- Jason Munchhof
- Car#: 808
I dunno, STR has been all over the top 10 of the local PAX results for the CalClub and SDR events this year. Doesn't seem the index is that hard.
Naturally ASP and other high power classes are gonna jump up at a pro. High grip and open courses help too. I don't think the SS index is too soft. It's not our fault my crappy 5th place times out paxed you Max.
It seems that the ProSolo drag-race start would give the PAX edge to high-horsepower cars on Hoosiers (awd and otherwise) compared to the typical start into a tight corner or offset.
- Bryan Heitkotter
There is still a separate ProSolo PAX index, though, isn't there?
http://www.pbase.com/bryanh" onclick="window.open(this.href);return false;
I'd say that cars that launch well compared to anything else they might do at an autocross would do better in PAX results at a ProSolo, and cars that launch poorly compared to their other performance characteristics would do worse. Consider that PAX is based on the particular weighting of performance traits that are called upon in a typical autocross course. In ProSolo, additional weight is given to how well the car launches. If it launches better than it turns, brakes, or accelerates from a roll, that helps.
Cars that seem to launch well:
AWD > Mid-engine > Rear drive > front drive
Torque from idle > torque at high RPM
sticky tires > less sticky
Power level is way down there in terms of influence.
Bryan, it looks like ProSolo has dropped the ProSolo Index and is just using Rick Ruth's PAX/RTP. There is a link to it in the ProSolo rulebook.
They switched to this a couple years ago (maybe effective 2011).
John Stimson wrote:Bryan, it looks like ProSolo has dropped the ProSolo Index and is just using Rick Ruth's PAX/RTP.
- Tom Berry
- Car#: 72
Thanks Bill.Bill Schenker wrote:After looking at the PAX results, and seeing the first non-HP car in 16th (Ryan), I don't think you can say that this time! And nice 2nd place!
But Max might disagree with you. A Miata (MX5) usually only bests STR when its a "Miata" course. Besides.... as you know....ALL courses are "Miata" courses! Silly rabbit !
Gotta consider the 400 feet of straight and the drag start when looking at overall PAX at a Pro - helps the power cars.
* Edited due to a failure on my part to consider interpretations of my original post that I had not intended..... :unimpressed:
Last edited by Gary Thomason on Wed May 09, 2012 10:19 pm, edited 1 time in total.
GT
Yeah, I did forget in my initial post that the PAX was not adjusted anymore for it being a Pro.
I have no idea what 200ft times would be for an STR car, but I'm pretty sure they suck in a STR MX5
Dude, MX5s launch better than S2000s on Hankooks! It was soooo painful to see in the corner of my eye that annoying MX5 paired with me sunday morning pull ahead every time, and knowing the retard of the driver behind the wheel, it just made it worse!Max Hayter wrote:Yeah, I did forget in my initial post that the PAX was not adjusted anymore for it being a Pro.
Said retard regularly pulls 2.2 sec 60 ft times in that 6 speed MX5. Interestingly, my fastest left had a .699 light and a 2.6 60ft time after I spun the tires too much. I was pulling 2.4 sec 60ft times most of the weekend.James Yom wrote:
- Davin Swanson
- Car#: 979
Launch slow to go fast?Max Hayter wrote: Said retard regularly pulls 2.2 sec 60 ft times in that 6 speed MX5. Interestingly, my fastest left had a .699 light and a 2.6 60ft time after I spun the tires too much. I was pulling 2.4 sec 60ft times most of the weekend.
FWD Civic on 195 street tires with 85ft lbs of torque.....
2.33 60 ft times.
God's Chariot on the Baby Jeebus' favorite tire... nuff said!Steve Ekstrand wrote:
2.33 60 ft times.
Max Hayter wrote:God's Chariot on the Baby Jeebus' favorite tire... nuff said!Steve Ekstrand wrote:
2.33 60 ft times.
With Wilbur the Alien driving... And yes, he had his fastest 60fts before we blew 12 million Dbs on the sound meter. Will is usually close to the fastest 60ft in STC. He did get beat a few times by Ann Hollis.
Now now, it was only 106.9+, according to the sound meter operator. But he did say he's never seen the + before.Steve Ekstrand wrote:... before we blew 12 million Dbs on the sound meter.
It was like and I was like and , then I got but in the end I was :king: while Steve was
The sound was described by course workers as "Rouseian" - sure sounded snotty inside the car! At first, I thought for sure some significant part of the motor was about to exit stage left.
like you said before Will... you should just campaign an STC Civic with a stock header. Nothing but header problems for you pal!Will Kalman wrote:Now now, it was only 106.9+, according to the sound meter operator. But he did say he's never seen the + before.Steve Ekstrand wrote:... before we blew 12 million Dbs on the sound meter.
- Car#: 226
Some call me Jebus. I drive God's Chariot. Yet, Im still slow!!Max Hayter wrote:God's Chariot on the Baby Jeebus' favorite tire... nuff said!Steve Ekstrand wrote:
2.33 60 ft times.
