June 11 - 12 videos
June 11 - 12 videos
Re: June 11 - 12 videos
Sheldon's 3rd lap on Sunday. 58.xxx +1. He kicked my ass.... But the problem.... Watch as it kicks out of 2nd gear twice at the finish. WTF????
#canttagmarshall
https://youtu.be/t8wrBkqpnZQ
#canttagmarshall
why does the shifter paddle rattle around? is it slipping out/re-engaging 2nd gear multiple times before it jumps out of gear or is the car hitting bumps and giggling the shift paddle back into neutral?
Could be that the 2nd gear dogs are rounded off, might have to eventually replace 2nd gear/rebuild trans if it continues to be a problem. APE will undercut the dogs to make them stick in gear better.
Looked to me like it was jumping around with bumps, but still not sure if it was actually moving or it was the camera jiggling. Didn't realize it was in a fixed position, though it was like my kart paddle shifter which is tied to the steering wheel and rotates with it so your fingers are always on it. Of course the kart wheel is not removable.Marshall Grice wrote:why does the shifter paddle rattle around? is it slipping out/re-engaging 2nd gear multiple times before it jumps out of gear or is the car hitting bumps and giggling the shift paddle back into neutral?
Does the class allow air or electric shifters? I've heard of this one mentioned by a couple of motorcycle friends: http://www.pingelonline.com/prodcat/ele ... ifters.asp
- Sean Fenstermacher
- Car#: 81
Fastest clean run after what seemed like 20mins of sitting at the start (X-Run 1)
https://youtu.be/7gsqAnioQe4
The paddle does float a bit. But I don't think it puts any force on the shifter cable.
Second gear slipping out matched rev's getting into peak torque. I think second gear has rounded off. I think to replace 2nd gear it's a split the case full disassembly kinda deal, but I'm not certain of that!
No electronic or air shifters in FM. You can set up a mechanical throttle lift. The ones I've heard of are pretty tough to keep adjusted dead-on.
- Car#: 905
Here are David Barrish 3 laps: https://youtu.be/s2eHq5KCIrA
And my 3 laps: https://youtu.be/U-wfc-Bx1n4
Here are my fastest clean (2nd run) and fastest dirty (3rd run) runs in CS:
https://youtu.be/JPYIeRUfUZM
SCNAX Champ Run Jeff - https://www.youtube.com/watch?v=MwxGDvj69M8
SCNAX Test Course Wet Jeff - https://www.youtube.com/watch?v=1z1q25ujydk
SCNAX Test Course Wet Nicole - https://www.youtube.com/watch?v=_yDJ49C0ktU
SCNAX Practice Course Nicole/Jeff Side by Side - https://www.youtube.com/watch?v=SXwSs8dIJE0
- Car#: 73
Sunday Champ run #2 STF RSX
https://youtu.be/fra0alZVLg4
