1994 Mustang GT- CAM prepped
JJ2218
Post by JJ2218 » Sun May 19, 2019 2:43 pm
Original CL ad: https://ventura.craigslist.org/cto/d/lo ... 98910.html
1994 Mustang GT for sale. Set up for SCCA CAM class autocross. Three local wins so far (PCA open class). This would also make a great HPDE car. Fully sorted in both maintenance and setup. It's ready to go and needs nothing. Over $13k invested. There is a small paint problem on the driver's door about the size of a hand. Also a small dent on the driver's door that I never bothered with. Please e-mail for more pictures or for questions. An extra set of wheels and tires come with it. Below are the new maintenance parts and racing parts that have been installed.
• BBK fenderwell cold air intake
• Underdrive pulleys
• MAC exhaust dumping before the axle
• Ceramic coated shorty headers
• Full length, weld in subframe connectors
• Strut tower brace
• Poly suspension bushings
• Maximum Motorsports caster/camber plates
• Maximum Motorsports Panhard Bar
• Maximum Motorsports Solid steering rack bushings
• Maximum Motorsports rear lower control arms (stock uppers)
• HR Super Race springs
• Koni Yellows
• New stock rotors with Hawk street pads
• Steeda triax shifter
• Apex racing 18x9 wheels with 245 Falcon Azenis K+
• Aluminum radiator
• TMoss Lower Intake
• Mild port on stock heads
• 8” adjustable lexan spoiler (removeable)
Maintenance
• All new ignition system (distributor, coil, plugs, wires, ignition module)
• Rebuilt heads (valve seals, new gaskets, ARP hardware)
• Even compression
• New harmonic balancer, belt
• New hoses
• New clutch, throwout bearing, and rear main seal
• Maximum Motorsports clutch quadrant and cable
• Rebuilt limited slip with new carbon clutch discs
• New rear wheel bearings.
• Recent smog cert. Parts have CARB EO numbers and it will pass smog as is
• New carpet
$5,900. Please make contact through the CL ad.
JJ2218
Re: 1994 Mustang GT- CAM prepped
Post by JJ2218 » Mon May 27, 2019 3:42 pm
I lowered the price some. I would really like to sell this to an autocrosser or track enthusiast. I have raced FWD cars, Miatas, S197 Mustangs, and this is by far the most fun to drive. (Sorry Miata owners)
I can also show proof that all the work mentioned was done.
JJ2218
Post by JJ2218 » Fri Jun 07, 2019 7:15 am
Price adjusted
JJ2218
Post by JJ2218 » Wed Jun 12, 2019 8:34 am
https://www.youtube.com/watch?v=jsEZHKN-US0
In car video. It has 2.73 gears. 2nd gear tops out at around 75 mph ~5300 RPM.
JJ2218
Post by JJ2218 » Sun Jul 07, 2019 8:42 pm
Bump, $5,900
