FS: '08 Tony Kart / '09 F-125 National Champion Honda CR
- Eric Nelson
2008 Tony Kart Krypton KRV. Honda CR engine package, won 2009 Solo Nationals running at 405 lbs.
Chassis: '08 Tony Krypton KRV. Magnesium wheel & components package; Type N axle; BS6 brake system; Size 3 OTK seat in excellent condition; front & rear flat bars; 4 seat struts; MG Green tires w/ 6 autocross runs from new. Brand new Original Tony Kart graphics package. Has repair to lower steering support which is not functionally significant.
Engine: '99 Honda CR125 w/ mods; 41mm Keihin PWM pump-around system; brand new RLV R5 pipe; 16" x 10" Champion radiator; Alumium motor mount; Wolf programmable CDI w/ Autocross over-rev and Traction control. Ready to run w/ under 45 minutes time on full overhaul and mods.
Extras: Wolf programmable CDI interface box & Windows software + (7) additional maps; (1) new GPT digital dash with Temp & RPM; (1) 25-piece jet kit; (1) OTK steering wheel + hub & clutch handle in excellent condition; (1) set 130mm / 210mm aluminum wheels; (1) new fiberglass seat in size of your choice; (4) new seat struts; (4) new Bridgestone 6.0 rain tires; (1) pair new pedal grips; (10) pints Burris premix oil; (2) quarts Motul Transoil.
Also included: Kart setup sheets; Jetting info; Info on all engine mods and engine maintenence.
Replacement cost approximately $15K for kart + spares as listed. Engine package as listed offered at $3500. Complete turnkey kart w/ spares as listed offered at $6900. Please contact Eric at (626) 232-9477 or e-mail seventh-gear@hotmail.com. Can ship anywhere in the continental U.S. at actual cost.
Re: FS: '08 Tony Kart / '09 F-125 National Champion Honda CR
how tall are you and how much does the kart weigh without driver?
- Eric Nelson
I am 6'1" / 190 lbs, driver who won Nationals is 5'10" / 155 lbs.
Kart weighs 199 lbs dry without driver. Driver + kart must weigh-in at 405 lbs using this engine configuration. If you are underweight it's made up by bolting lead weight to the kart.
KJ is a big guy....
Is there any way to reduce weight on the kart? Also, is the lbs with any weight penalties like programmable ignition or front brakes???
Also there foot porches right, for really long legs?
i'm 6'4", 245#, long legs and arms.Steve Ekstrand wrote:KJ is a big guy....
At 199, there isn't much on it that isn't necessary.Steve Ekstrand wrote:KJ is a big guy....
405 is with the penalty for the programmable ignition, 385 without. All 125 shifters have front brakes. You usually buy a chassis with the front porch on it, but it could be added.
- Robert Puertas
- Car#: 44
That's the good thing about a kart.KJ Christopher wrote:i'm 6'4", 245#, long legs and arms.Steve Ekstrand wrote:KJ is a big guy....
Your knees and elbows just stick out further...
I drove Eric's old kart once. At 6'-2", 245, it wasn't a problem.
- Eric Nelson
At 6'4", this kart would need to be specifically set up for you, with the correct seat and original Tony Kart porch extension. With that you would be as comfortable as anybody, but you'd still be coming in ~ 40 lbs overweight. But, the motor is pretty strong... :)
Tom Harrington was an honest 6'4" and at least 215 lbs. Only one of his wins was under P.I. rules; prior to that he used to demolish most of his competition while running about 30 lbs (around 8%) heavier than everyone else, with no power advantage. So, it can be done.
I remember an old movie about moon shine runners ... saying that cars that weighed more "handled" better. That was before ST cars proved THAT theory wrong!
If only.....
If by handling you mean "just keeps on goin' stright ahead, even when ah turns the wheel."Mako Koiwai wrote:I remember an old movie about moon shine runners ... saying that cars that weighed more "handled" better.
- Eric Nelson
Yeah, "Ground Hugging Weight", like the pre-war Indy Cars. HAHAHA!
In this kart's case, it's all about power-to-weight ratio. You can afford to lose a little in turns to weight, as long as you're making it up elsewhere...
