NTB, E36 ECU
Moderator: Will Kalman
David Barrish
Car#: 58
NTB, E36 ECU
Postby David Barrish » Fri Jul 01, 2016 5:42 pm
HELP, I need an ECU for AN OBD-I BMW E-36 325is 5 speed.
Any help would be appreciated, Thank you.
David Barrish
Toby Larsson
Re: NTB, E36 ECU
Postby Toby Larsson » Sun Jul 03, 2016 8:30 pm
If it got wet during a car wash or rain it can be saved by opening up the case and gently cleaning it with WD40. If it can't be saved I think I have a couple but would need to search thru some boxes to find them.
David Barrish
Car#: 58
Re: NTB, E36 ECU
Postby David Barrish » Mon Jul 04, 2016 6:14 pm
Toby,
No, it did not get wet. The tech working on the car has tested around it and has determined it is failing.
I am looking for a red label 413. Anything you can come up will help.
Thank you.
David
Return to “For Sale/Wanted”
Who is online
Users browsing this forum: Nic Sanchez and 8 guests
