Garmin Virb X action cam
James Yom
Car#: 28
Post by James Yom » Thu Mar 16, 2017 10:25 pm
For sale is my Garmin Virb X action cam.
The great thing about this camera vs the GoPro (other than the new and pricey gopro 5) is that it has a GPS sensor and accelerometers to record info like speed, forces, etc, and overlay it on your video with their software without another 3rd party app. The awesome thing you can do with the Garmin that you still can't do with any GoPro is that you can connect a wireless Bluetooth OBD2 unit to get vehicle data like RPM, A/F ratio, brake activation, coolant temp, etc and also overlay all this on your video.
Here is an example of what it can do:
https://youtu.be/KrcorDjE4Eo
And here is Max Hayter at SD Match Tour:
https://youtu.be/raE--wF9vxQ
$180
Max Hayter
Car#: 31
Re: Garmin Virb X action cam
Post by Max Hayter » Fri Mar 17, 2017 6:41 am
Excuse my wobbly mount in that video - not the camera's fault!
I should add that I have the XE. The XE adds Image Stabilization, which actually doesn't work very well for autocross, so buying the X like James' puts you at no disadvantage to the XE. I have the Image Stabilization always turned off.
I also run their Rugged Cable with an external mic. Battery life is much better than my old Go Pro.
This is a great camera at a great price.
~Max H.
Gearhead's Garage/FRSport
#31 SSC
Paul Molina
Car#: 274
Post by Paul Molina » Fri Mar 17, 2017 9:29 am
Is there a way to time your run? Or set a start and finish?
Any apps that work with it for Iphone, like harry's lap timer?
How quickly can you transfer a run to your phone to review it?
I'm about done with GroPro
Paul
Max Hayter
Car#: 31
Post by Max Hayter » Fri Mar 17, 2017 9:47 am
Paul Molina wrote:Is there a way to time your run? Or set a start and finish?
Paul
No, and no.
Virb has an App that you can view the camera via wifi.
You can just view the runs via the App, or put the MicroSD card in your phone (unless you have a crappy Iphone).
Check the App store for the Virb App.
~Max H.
#31 SSC
O Prachumsri
Car#: 811
Post by O Prachumsri » Wed Mar 22, 2017 7:16 am
I'm interested in the camera. What will come with it? Any of the mounting accessories?
#811
1987 AW11 MR2
Eddie Atherton
Car#: 250
Post by Eddie Atherton » Thu Mar 23, 2017 3:01 pm
James Yom wrote:The awesome thing you can do with the Garmin that you still can't do with any GoPro is that you can connect a wireless Bluetooth OBD2 unit to get vehicle data like RPM, A/F ratio, brake activation, coolant temp, etc and also overlay all this on your video.
Depending on your car. It seems the initialisation handshake between the dongle and the camera isn't as robust as with most OBD2 apps. So even if an app will read the data, there's no guarantee that the Garmin will.
Cheers.
James Yom
Car#: 28
Post by James Yom » Thu Mar 30, 2017 9:59 pm
O Prachumsri wrote:I'm interested in the camera. What will come with it? Any of the mounting accessories?
Sorry for the late reply. Yes, I will have mounting hardware for you. One curved mount and one flat mount.
James
