15x7.5 wheels
Moderator: Will Kalman
WMARLOW
15x7.5 wheels
Postby WMARLOW » Sat Oct 07, 2017 4:43 pm
Hello Racers,
WMARLOW
Re: 15x7.5 wheels
Postby WMARLOW » Sat Oct 07, 2017 4:49 pm
Hello racers, I'm looking to buy a set of 15x7.5 rims for my 1991 CRX SI. The problem I'm trying to figure out is why the konig hyperlite rim will fit a 1991 civic but not the crx anybody know why
Re: 15x7.5 wheels
Postby Steve Ekstrand » Sun Oct 08, 2017 1:55 pm
I thought that was a 35mm rim? 35mm put you into the fender with a Civie. I'm surprised they say it works. Maybe with a narrow 195 tire and a lot of camber or a high ride height. For STS you'd get a lot of rubbing I'd think. The wheel just sticks out too far. And you can't run negative spacers. Sometimes you can machine off the pads 5mm and that will make it work. But I have no experience with the Konig. I can't tell you how CRXen differ from the Civies.
WMARLOW
Re: 15x7.5 wheels
Postby WMARLOW » Mon Oct 09, 2017 7:31 am
Thank Steve, The offset is 35 on the konig rims. I dont think that a problem
Car#: 194
Re: 15x7.5 wheels
Postby Jonathan Lugod » Mon Oct 09, 2017 9:32 am
http://redshiftmotorsports.com/RedShift ... 20Page.htm
1991 Civic has different rear trailing arms that allow for use of 7.5" rim with offset between 39-43.
For everything else reference the above link to build a cookie cutter STS car.
4 STR- 2016 Mazda ND Miata
OS Giken / Bridgestone / Bride
WMARLOW
Re: 15x7.5 wheels
Postby WMARLOW » Mon Oct 09, 2017 11:04 am
Do the same thing work on the crx as well as the civic thread you post for me
Re: 15x7.5 wheels
Postby Steve Ekstrand » Tue Oct 10, 2017 12:04 pm
Just wanted to point out that the 91 trailing arms supercede in the parts book so you can use them on an 89-90. Sorry... Still no help on the CRX question. :(
WMARLOW
Re: 15x7.5 wheels
Postby WMARLOW » Sat Nov 04, 2017 4:12 pm
found and purchased
Return to “For Sale/Wanted”
Who is online
Users browsing this forum: No registered users and 14 guests
