Break and shaking up
Mysto Gan
Post by Mysto Gan » Mon Mar 05, 2018 7:00 pm
I have a question for my car that sometimes whenever I break my car is shaking up. What do you think is the cause of this problem?
George Schilling
Car#: 66
Re: Break and shaking up
Post by George Schilling » Mon Mar 05, 2018 9:07 pm
Mysto Gan wrote:I have a question for my car that sometimes whenever I break my car is shaking up. What do you think is the cause of this problem?
Sounds like a classic case of unbalanced washing machine syndrome. Consult Kowalski's Machine Shop. He has much experience with cars breaking and shaking up.
Jacob Abrams
Car#: 728
Post by Jacob Abrams » Mon Mar 05, 2018 9:28 pm
Lol.
If the car is only shaking when you apply the brakes, and the effect is amplified at speed, then you most likely have a brake rotor or two worn out. Have the rotors checked and worn ones replaced and you should be good to go.
Eric Wong
Car#: 900
Post by Eric Wong » Mon Mar 05, 2018 11:54 pm
Check your lug nut torque, loose ones can also cause this.
If you have new brake rotors or pads, they could be insufficiently bedded-in:
http://stoptech.com/technical-support/t ... pad-bed-in
Paul Molina
Car#: 274
Post by Paul Molina » Tue Mar 06, 2018 10:25 am
Do you feel it in the brake pedal? Could be warped rotors?
Mark Haubert
Post by Mark Haubert » Thu Mar 15, 2018 1:15 am
I get slight shaking when accelerating, but only when it's cold and the car has been outside for a long time. It goes away after the initial hundred meters or so. What might be causing this?
Eric Wong
Car#: 900
Post by Eric Wong » Fri Mar 16, 2018 1:30 pm
Mark: cars need to warm up, especially as they get older and parts begin wearing out, small gaps get bigger. Metal expands as it gets hotter, so gaps get filled in and there's less vibration.
Christine Grice
Car#: 17
Post by Christine Grice » Fri Mar 16, 2018 4:53 pm
Cold/old tires on a car that has been sitting in one spot for a little while can take a set in their non-round condition and it takes a little bit of driving to get them to flex and warm up enough to get rid of the slightly flat area.
