Tips to flatten magnetic numbers?
Stephen Strand
Car#: 519
Post by Stephen Strand » Mon Jan 19, 2015 6:53 pm
I wasn't able to use my magnetic numbers this past weekend because a few of them had become slightly bent and I was worried they would fly off. Does anyone have a way to get them flat again? I'm thinking either heat or a lot of weight but not sure what would be best.
Mediocre driver. #519 Focus ST. Lead mod for www.reddit.com/r/rallycross
Adam Tarnoff
Car#: 49
Re: Tips to flatten magnetic numbers?
Post by Adam Tarnoff » Mon Jan 19, 2015 7:01 pm
Stephen Strand wrote:I wasn't able to use my magnetic numbers this past weekend because a few of them had become slightly bent and I was worried they would fly off. Does anyone have a way to get them flat again? I'm thinking either heat or a lot of weight but not sure what would be best.
Typically people just lay them out in the sun until it's their turn to run. The material gets soft enough that will conform to any surface you stick it on.
#49 C Street Mazda RX-8
Post by Christine Grice » Mon Jan 19, 2015 8:03 pm
We lay out the numbers in the sun or put them on the top of the hood vent when the car is warming up.
Byron Goodman
Car#: 757
Post by Byron Goodman » Mon Jan 19, 2015 9:16 pm
I do the same. If you are in a hurry or there is no sun, try cranking the heater in your car and holding them in front of the vent.
Stephen Strand
Car#: 519
Post by Stephen Strand » Tue Jan 20, 2015 11:14 am
Great thanks!
Post by Jayson Woodruff » Tue Jan 20, 2015 11:34 am
For 'creesed' magnets in between events I've put them in between my box springs and mattress.
If they're just curling, then store them on something steel and flat. Washer/Dryer, file cabinet. Water heater kind works (but is curved).
For race day: Direct sun tends to heat up faster than heaters and motors. Put them on the sunny side.
Don't leave them on a car over night, especially if wet. It can push moisture into your clear coat.
Stephen Strand wrote:Does anyone have a way to get them flat again?
