O Prachumsri
Car#: 811
Post by O Prachumsri » Mon Jan 30, 2017 2:24 pm
Hi Guys,
I am thinking of doing my first Autocross event and wanted to make sure I get my car classes correctly. The car is a 1987 MR2 NA, with the following mods:
TRD lowering springs
Koni Yellows rebound adjustable shocks
Dunlop Direzza 205 sections tires (stock is 185 i believe)
Enkei's RPF1 15 in. diameter (stock is 14 in.)
Short Shifter
Aftermarket steering wheel
Polyurethane suspension bushings
Polyurethane engine mount bushing
Am I correct in classifying my car as a street touring sport (STS) and since I am a novice it would be NOV STS ?
Thank you,
O
#811
1987 AW11 MR2
Brad Grider
Post by Brad Grider » Sun Feb 05, 2017 10:02 pm
New to the forums and AutoX as a whole. I've run once and got hooked but now I need assistance classing my car. This is an easy one I believe...
I've got a stock 2017 Subaru WRX STI. Thanks!
Post by Rick Brown » Mon Feb 06, 2017 1:10 am
Brad Grider wrote:New to the forums and AutoX as a whole. I've run once and got hooked but now I need assistance classing my car. This is an easy one I believe...
B Street (BS)
Brad Grider
Post by Brad Grider » Wed Feb 08, 2017 7:34 pm
B Street (BS)
Thanks a bunch for this!
Post by Craig Naylor » Thu Feb 09, 2017 8:56 am
O Prachumsri wrote:Am I correct in classifying my car as a street touring sport (STS) and since I am a novice it would be NOV STS ?
Thank you,
O
Correct on both acct's. Car is STS, you may compete in either STS or Novice with an STS multiplier.
Bump for Julian Yun's post above for his Audi. Can someone assist with that one?
Anthony P.
Post by Anthony P. » Thu Feb 09, 2017 10:01 am
I think BSP is pretty close... and I certainly wouldn't complain. I notated whats not ok for BSP. For local events I think CST is proabably the way to go unless you get hooked on the sport and try some r-comps. On national level events if your on street tires while not legal I can imagine anyone protesting you being in BSP. (CST is not available at those events)
Julian Yun wrote:Hey Guys,
I normally go on open track road course events, but now I am thinking of doing AutoX events. I was wondering what you guys would classify my car as?
2016 Audi S3 (AWD) DSG Automatic
Upgraded Wheels (19x8.5 et 35) - OEM Wheels are 19x8
Michelin Pilot Super Sport Tires 235/35/19 (OEM Size)
OEM Exhaust Resonator Delete
Upgraded Exhaust Tips (Tips only, not muffler)
Lowering Springs
Upgraded Rear Sway Bar
Adjustable Rear End links
Upgraded Subframe Inserts
Upgraded Transmission Dogmount Mount -Might not be BSP legal
Upgraded Brake Pads
Upgraded Brake Stainless Steel Lines
Rear Chassis Brace
Castrol SRF Brake Fluid
Stage 1.5 ECU Tune
Stage 1 DSG Transmission Tune -Not BSP legal.
Upgraded Air Intake Short Ram System
Carbon Fiber Front Lip Spoiler -Might not be BSP legal if it extends beyond the front-most part of the bumper
Carbon Fiber Rear Trunk Spoiler
Thanks guys!
Look forward to hearing from you.
Julian
Robert Puertas
Car#: 44
Post by Robert Puertas » Thu Feb 09, 2017 10:08 am
Hey Julian,
You probably want to run our local-only CST class. It basically allows anything street-legal on "street" tires.
If you provide more detail on a couple of items, we can confirm which SCCA national class you would be in. But, I suspect the answer is SM (Street Modified).
Specifically send us links to websites for your Rear Chassis Brace, Transmission Dogmount and Subframe Inserts.
I may be missing something else, but those are the things that might bump you from Street Prepared to Street Modified.
Either way, I'd be running CST unless you decide to upgrade to DOT race rubber.
Lowering Springs
Upgraded Brake Pads
Rear Chassis Brace
Stage 1.5 ECU Tune
Thanks guys!
Julian
O Prachumsri
Car#: 811
Post by O Prachumsri » Thu Feb 09, 2017 10:34 am
Craig Naylor wrote: Correct on both acct's. Car is STS, you may compete in either STS or Novice with an STS multiplier.
Thank you! Looking forward to the weekend.
#811
1987 AW11 MR2
Car#: 21
Post by Marshall Grice » Sat Feb 11, 2017 10:36 am
Anthony Porta wrote:I think BSP is pretty close... and I certainly wouldn't complain. I notated whats not ok for BSP. For local events I think CST is proabably the way to go unless you get hooked on the sport and try some r-comps. On national level events if your on street tires while not legal I can imagine anyone protesting you being in BSP. (CST is not available at those events)
I don't see the 2016 S3 classed yet in any SP class. I think CST is a good place to run.
Anthony P.
Post by Anthony P. » Mon Feb 13, 2017 12:10 am
Whoops on my part. Marshall is indeed correct.
Ramon Valencia
Post by Ramon Valencia » Thu Feb 16, 2017 2:26 pm
Totally new here and want to try AutoX. What would you classify a bone stock 2014 Lexus IS250 and will the class change if I install aftermarket exhaust such as the Apexi N1 Evolution (catback system).
Thanks for the info.
Si vis pacem, para bellum.
Car#: 21
Post by Marshall Grice » Fri Feb 17, 2017 10:31 am
Ramon Valencia wrote:Totally new here and want to try AutoX. What would you classify a bone stock 2014 Lexus IS250 and will the class change if I install aftermarket exhaust such as the Apexi N1 Evolution (catback system).
D-street. catback exhaust is legal for street class.
Ramon Valencia
Post by Ramon Valencia » Fri Feb 17, 2017 10:50 am
Marshall Grice wrote:D-street. catback exhaust is legal for street class.
Awesome! Thanks for the info. DS it is. Hope to meet you guys next month.
Julian Yun
Post by Julian Yun » Tue May 09, 2017 11:10 pm
Thank you all for the responses!
Can't wait to go to my first event soon!
Here are links to my rear chassis brace, transmission dogbone Mount and my subframe inserts:
https://www.ecodetuning.com/audi-8v-mk7 ... ory_id=337
https://store.034motorsport.com/mqb-dog ... minum.html
https://store.034motorsport.com/billet- ... olf-r.html
Pete Morris
Post by Pete Morris » Fri May 26, 2017 7:33 pm
Just signed up. I run a 2014 Fiesta ST. Mods are as follows:- bigger intercooler, lowering springs, but with no internal or external engine modifications. I take it that I would be in SP?
Ramon Valencia
MB C450 classing help please
Post by Ramon Valencia » Sun May 28, 2017 8:27 pm
I looked at the SCCA classing rules but didn't find the C450. Does anyone know what class a bone stock Mercedes C450 falls under?
Thanks in advance.
Ramon
Q V
Car#: 69
Re: MB C450 classing help please
Post by Q V » Sun May 28, 2017 11:13 pm
Ramon Valencia wrote:I looked at the SCCA classing rules but didn't find the C450. Does anyone know what class a bone stock Mercedes C450 falls under?
Thanks in advance.
Ramon
It would fall under H Street under Mercedes NOC (Not otherwise classified).
Ramon Valencia
Post by Ramon Valencia » Tue May 30, 2017 8:58 am
Thanks in advance.
Ramon
Great! Thanks for the help!
The c450 is a V6 turbo with 365HP. It'll have crazy advantage in HS.
Post by Rick Brown » Tue May 30, 2017 12:09 pm
Pete Morris wrote:Just signed up. I run a 2014 Fiesta ST. Mods are as follows:- bigger intercooler, lowering springs, but with no internal or external engine modifications. I take it that I would be in SP?
Yes, OK for CSP. You could also run in our local catch all classes, depending on tires: Calif Street Mod (CSM) with any street legal tire, or Calif Street Touring (CST) with tread wear rating of 140 or higher.
Post by Craig Naylor » Tue May 30, 2017 9:43 pm
H Street would... except he is else-wise classed...
D Street:
Mercedes-Benz
- C-Class (6-cyl, non-AMG) (2001-16)
That's still a gift, as he probably belongs in FStreet along side:
Mercedes-Benz
- C300 (2007-16)
Dana Ebaugh
Post by Dana Ebaugh » Sun Jun 04, 2017 11:25 am
My car is a 97 Eclipse Spider with a 2.0ltr turbo. What class
Post by Rick Brown » Sun Jun 04, 2017 3:59 pm
Dana Ebaugh wrote:My car is a 97 Eclipse Spider with a 2.0ltr turbo. What class
Don't know much about Eclipse, but G Street (GS) is FWD, D Street (DS) if AWD.
Dana Ebaugh
Car is a 02 Acura 3.2 TL what class should I use
Post by Dana Ebaugh » Mon Jun 05, 2017 12:41 pm
Luke Daley
Post by Luke Daley » Fri Jun 09, 2017 12:52 pm
Hi everyone! First time Auto-xer here. Done some HPDE in the past, but I wanted to finally give auto-x a try. Hopefully someone can help me with my class! I am only doing the practice run, so I'm not worried about being in a competitive class.
I have a 2003 Mazda Protege5
Bridgestone RE-71R 200TW 215/45-17 (Stock is 195/45-16)
OEM Shocks and Springs from the MazdaSpeed Protégé (Lowers the car about an inch over stock IIRC)
OEM Rear Sway Bar from MazdaSpeed Protégé
K&N Cold Air Intake
Slotted Front Rotors
Short Shifter
Polyurethane front and rear motor mounts
I will also be stripping the interior for weight savings. Appreciate the help!
Ed Wang
Post by Ed Wang » Fri Jun 16, 2017 10:42 pm
Hey all, just wanted to make sure I classed my car correctly before I show up to my first AutoX event. I drive a 2009 Mazdaspeed 3 (2.3T) with some basic mods:
Autotech HPFP Internals
Corksport Short Ram Intake
HKS Catback Exhaust
KW V1 Coilovers
JBR Rear & Passenger Side Motor Mounts
OEM Spin-On Oil Filter Conversion Kit
SPC Rear Camber Arms
18x8.5 +25 Wheels (Stock are 18x7)
215/40R18 Hankook Ventus V12 (OEM are 215/45)
My understanding is that this setup would place me in STX. Can anyone give me a quick verification? Thanks a bunch! :D
