New guys
Santi Rodriguez
New guys
Post by Santi Rodriguez » Tue Mar 21, 2017 12:38 pm
So a group of us are looking to get into autocrossing. Is it possible for the 4 of us to sign up and utilize one car between us at the events?
Re: New guys
Post by Rick Brown » Tue Mar 21, 2017 1:01 pm
nopropslaw wrote:So a group of us are looking to get into autocrossing. Is it possible for the 4 of us to sign up and utilize one car between us at the events?
It is possible, but no more than 2 can be in the same group/class. Give us info about the car and we can recommend classes. Also, please note that we use real names on this forum.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Tue Mar 21, 2017 1:35 pm
Sorry...I didn't know...Can I change that?
The car is a 2001 Mustang cobra. I believe it just has a catback exhaust.
Re: New guys
Post by Rick Brown » Tue Mar 21, 2017 2:47 pm
nopropslaw wrote:Sorry...I didn't know...Can I change that?
Only a moderator can, just post the name here and it will be fixed.
Chad-1stGen
Car#: 268
Re: New guys
Post by Chad-1stGen » Tue Mar 21, 2017 3:18 pm
nopropslaw wrote: The car is a 2001 Mustang cobra. I believe it just has a catback exhaust.
At a minimum you could run CAM-C, CST, or TO. The first two require you to have 200 tw minimum tires. There is probably another class you could run to.
Just check out the run order and make sure two of the classes you want to run are in different run groups. For example, if you look at last weekend's event run order you see that CAM ran group 1 and CST ran group 3. two of you could of run CAM during the first run group and two of you could of run CST during the 3rd run group.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Tue Mar 21, 2017 3:33 pm
Is this something that people commonly do? And is the only difference that we would run in groups with different class cars? Same track setup?
My name is Santi Rodriguez, for whoever is able to change it. Thank you for the information.
Re: New guys
Post by Rick Brown » Tue Mar 21, 2017 4:38 pm
It's common to have 2 driver cars, which is what the rules are set up for and why you have to run in different classes. Yes, different competitors, same course.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Wed Mar 22, 2017 2:17 pm
Are there 2 classes I can run that don't require the 200 two tires?
Re: New guys
Post by Rick Brown » Wed Mar 22, 2017 3:50 pm
nopropslaw wrote:Are there 2 classes I can run that don't require the 200 two tires?
No stock classes. If you just want to learn, then CSM is a local catch all class. TO (Time Only) is all cars (index by regular class) that can run any time of day, but no trophies or points earned. You can actually all run TO, but no more than two per run group.
Kevin Pao
Re: New guys
Post by Kevin Pao » Wed Mar 22, 2017 10:11 pm
CSM = Like what Rick said. Car can have pretty much unlimited mods but needs to be registerable.
Street Prepared Combined = I believe your car will have an index of ESP. Limited rules on suspension and power mods. But your car qualifies for it if you would like to run race tires. :thumbup:
Street Mod Combined = Same as SP combined but with more allowances
Prepared combined = Even way more allowance than any of the classes listed above.
Those would be the 4 classes your car would probably qualify for if you run sub 200tw tires.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Thu Mar 23, 2017 8:26 am
The TO sounds good for us to get started and learn. We are excited to get going.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Wed Jun 07, 2017 5:09 pm
So I finally got the car ready. A friend and I are looking to come Sunday to do TO. Are we able to do both morning and afternoon? And Besides showing up, registering, going through tech, and walking the course, what else should I be prepared for? helmets?
I might try to come out Saturday to watch, learn and ask questions.
Re: New guys
Post by Rick Brown » Thu Jun 08, 2017 2:13 am
nopropslaw wrote:So I finally got the car ready. A friend and I are looking to come Sunday to do TO. Are we able to do both morning and afternoon? And Besides showing up, registering, going through tech, and walking the course, what else should I be prepared for? helmets?
You can only enter a class once. That being said, you can then buy X-Runs, which are another set that do not require an additional work assignment. If you get really hooked, you can even buy more X-Runs, however there are a limited number of X-Runs sold per group. Registration can give you all the details.
Bring water and sunscreen, you will likely be working course and it may be warm. Take advantage of instructors. There is a separate lane to get in to get an instructor, they can ride with you and coach or drive your car to show you how it's done (highly recommended and does not count as one of your runs). A limited number of loaner helmets are available for free. At around 8am and the beginning of the lunch break there is a guided course walk by our Novice Coordinator, very useful. Also on Saturday, most drivers are happy to give ride alongs, just ask.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Thu Jun 08, 2017 11:43 am
So registering for Sunday, I assume that although 2 of us will be using one car, we both register and pay the fee?
Randy Gonzalez
Car#: 436
Re: New guys
Post by Randy Gonzalez » Thu Jun 08, 2017 12:29 pm
That is correct. You are registering the drivers, not the car.
We do have an option to split practice entries so that two drivers can split the day's practice runs, but not on Sundays.
http://CorvetteNews.com/
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Thu Jun 08, 2017 2:16 pm
Ok great. We just registered and are set for Sunday. I did notice that when registering it didn't give me the option for morning or afternoon. I am only available morning. Do I need to contact someone regarding that?
Stephen Yeoh
Solo Chair
Car#: 888
Re: New guys
Post by Stephen Yeoh » Thu Jun 08, 2017 2:45 pm
Your account has been renamed to your full name. Use the same password.
Stephen Yeoh
Cal Club Autocross Chair
Randy Gonzalez
Car#: 436
Re: New guys
Post by Randy Gonzalez » Thu Jun 08, 2017 2:49 pm
Santi Rodriguez wrote:Ok great. We just registered and are set for Sunday. I did notice that when registering it didn't give me the option for morning or afternoon. I am only available morning. Do I need to contact someone regarding that?
I just reviewed your registration. You are registered for TO-M Class (Time Only - Morning)....so you should be all set. If you let me know your co-driver's name, I can check their registration as well.
Randy Gonzalez
Car#: 436
Re: New guys
Post by Randy Gonzalez » Thu Jun 08, 2017 4:16 pm
Looks like you and Phillip are registered for TO-M:
https://www.motorsportreg.com/index.cfm ... 0FA441CADE
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Thu Jun 08, 2017 5:34 pm
Awesome! Thank you. Hope to meet some of you when I come by on Saturday.
Re: New guys
Post by Rick Brown » Thu Jun 08, 2017 8:24 pm
Since you are running TO, you have a choice of groups to run (there are limitations on the number of TO per group) and you and your co-driver can run the same group or different groups. If you run the same group, be sure to get in the two driver lanes in grid.
Santi Rodriguez
Re: New guys
Post by Santi Rodriguez » Mon Jun 12, 2017 2:24 pm
Thanks for all the help. We had a blast! Looking forward to the next event. Hoping to be able to do the practice this time as well.
