Rules Proposal 2009-01
- Jeff Cawthorne
- Car#: 196
Re: Rules Proposal 2009-01
What I am starting in SD:
Here is my idea:
All, not classed in ST, stock classed cars may compete (stock excluded cars are excluded). Only for not classed in ST cars, no other ST cars can cherry pick in this class.
Cars that would be classed in ASP, BSP and ESP will use STU rules.
Cars that would be classed in CSP, DSP and FSP will use STS/2 rules, except they may use the limited slip rule from STU and can run 8" wide wheels with 245 tires.
All cars will compete in one class and use their respective Street Prepared PAX index to determine the class rankings.
No need to add the street tire reducing pax, just use the Street Prepared index for the class rankings
Here is my idea:
Jeff Cawthorne
2016 Miata STR
2015 Mini Cooper S
2016 Miata STR
2015 Mini Cooper S
We use overall event Pax placings for a team competition, so handicapping for street tires is important in LA. I don't know if they use the overall Pax in S.D. at all except for braging rights in the results.Jeff Cawthorne wrote: No need to add the street tire reducing pax, just use the Street Prepared index for the class rankings
Now that makes sense. Though with the 09 index's I get 0.84281.. for %97.322.. of ASP's .866.Marshall Grice wrote:I'd think something like scaling SST's index referenced to ASP by the same percentage as STU is to BSP. So something like .840 for SST.Sebastian Rios wrote:I think the SST index should be only slightly higher than STU until we figure out what's doing. I propose .838, it follows the progression of .002 increments shared by ST, STS, and STX.
for reference STU is about 97.3% of BSP's index.
.840 or .842 is fine, just makes it easier for me ;) . I was thinking of just a simple .002 over until we figure out what the class can do.
If we are talking about comparing to *sp does that mean STS(2) should be .838? (97.322% of CSP .862).
Any more discussion on this? .842 is fine with me, I'm not going to run the class.
Let's discuss this some more. First, cars should be Stock class eligible. I don't know if that was part of the local class foundation or not, but Stock eligibility is required for ST cars.
The car that will wipe out this class is a nice, little SS car we know as the Elise. Other cars will be competitive, but the Elise will be the car to have.
Here are some '09 PAX factors to consider:
SS .856
AS .843
STU .836
STX .822
I suggest .845 for SST. It's far lower than SS - from which the cars will be eligible - and while it's a tiny bit higher than AS it's also only .09 higher than STU, which itself is .14 higher than STX.
Let me demonstrate the number another way. STU cars compare favorably with BSP cars. They are STIs, Evos and M3s.
BSP .859
STU .836
STU is 97.32% of BSP. Compare that to our 98% Street Tire factor and it looks reasonable. A BSP car is allowed unlimited boost, an aftermarket steering wheel (no airbag), no stereo, no heat shields, no catalytic convertors, no smog equipment, etc. Certainly the latter items account for far more than just .68% improvement, so I think the 98% factor *just for tires* is reasonable.
Now look at ASP's .866 PAX. Adjust for 98% and we hit .849 for an ASP car on Street Tires. .845 looks quite reasonable by that standard.
If it weren't for the Elise I'd say .845 may be a little tough, but that little car is the Poster Child of ST cars. Ridiculously light, strong power / weight ratio, and with power that won't overwhelm street tires. A Z06 or GT3 won't stand a chance, and a well-prepped and well-driven S2000 will be facing a tough battle.
And if I'm wildly wrong... we just won't be rocking the Indexed results due to some foolishly easy local PAX. No harm there. If you're fighting to be at the top of the Indexed Times, stick with a conventional class that receives a carefully determined PAX.
Anyone care to comment?
SS .856
AS .843
STU .836
STX .822
BSP .859
STU .836
I'm not an informed source by any means, but how much would speed can an ST prepped Elise gain?
Stiffer springs.
Rear Bar. Needed?
Lighter seats/exhaust Do Elise seats weigh more than 25lbs? Exhaust path is already short, no huge weight loss.
Power mods how much 10-12hp?
SLOWER TIRES
I think it is a net loss.
Then again I won't be running the class, and I bet Ken could go faster in his S2K anyway so yeah, make it too hard. }:)
Stiffer springs.
Rear Bar. Needed?
SLOWER TIRES
<snip>
That's what's currently plugged into the timing computer and online in ORM.KJ Christopher wrote:Sounds like a good case to me.Mike Simanyi wrote:
<snip>
.845 sounds like an resonable place to start.
