GM OBD-II drive cycle help
Eric Wong
Car#: 900
Post by Eric Wong » Wed Apr 03, 2019 2:51 pm
I replaced a clogged AIR valve on the old gasmobile, cleared the code, and now I need to complete the OBD-II drive cycle for smog testing...
Unfortunately, the drive cycle procedure is difficult to follow and seems like an accident waiting to happen:
http://www.obdii.com/DRIVECYCLE.HTML
Evap and EGR readiness still haven't come on after several attempts and near-accidents (I only need one of them to be ready for a '99).
No new error codes since the AIR valve replacement...
12V battery seems good (no unintended trip resets), so it's not losing information between drives.
Is there a safer, more reliable way of getting either the Evap or EGR ready?
Anthony P.
Re: GM OBD-II drive cycle help
Post by Anthony P. » Wed Apr 03, 2019 8:00 pm
Drive 50 miles or so. Usually after enough miles it forces it.
Eric Wong
Car#: 900
Post by Eric Wong » Thu Apr 04, 2019 1:07 am
Just put in another 50 miles (highway, offramps, onramps) and that didn't work, either. Started at just over 1/2 tank.
I've put in over 180 at this point, actually; but I might've missed the 1/4-3/4 tank range on some tries since the fuel tank is V-shaped and the gauge gets thrown off by hills.
It occurs to me that I rarely hit 1/2 throttle on public roads (LS1 power); so I'm probably under-throttling the part which requires 3/4 throttle, or I'm overshooting the 20-55mph acceleration.
Maintaining 55mph is also tricky with elevation changes and no cruise control.
Anthony P.
Post by Anthony P. » Thu Apr 04, 2019 9:59 am
Hmmm, yeah fuel between 1/4 - 3/4 and more cold starts I guess.
