What's a good tar remover?
- Stephen Yeoh
- Solo Chair
- Car#: 88
What does everyone like for tar remover (specifically to remove cone marks)?
Stephen Yeoh
Cal Club Autocross Chair
- Anthony P.
Re: What's a good tar remover?
I like goof off as I use it for other cleanup work, but I'm sure others will chime in.Stephen Yeoh wrote: ↑Sun Sep 27, 2020 9:38 pm What does everyone like for tar remover (specifically to remove cone marks)?
- Car#: 111
Mothers "R3" is made just for removing tar and rubber marks and it "WORKS"
You also might try "NOT HITTING PYLONS" that works wonders also.
Brian
Brian
Morgan Plus 4 #111 ![Cool 8-)](./images/smilies/icon_cool.gif)
Turtle Wax label and sticker remover takes cone marks right off without any effort, way better than anything else I've tried. I also have a set of plastic razor blades to help with really built up marks.
https://www.amazon.com/Turtle-Wax-T-529 ... 201&sr=8-1
R3 race rubber remover didn't work at all for me. Goof off didn't work as well either.
- Anthony P.
Based off the msds this makes sense, ill have to try the tutle wax.Tom Layton wrote: ↑Tue Sep 29, 2020 1:29 pm Turtle Wax label and sticker remover takes cone marks right off without any effort, way better than anything else I've tried. I also have a set of plastic razor blades to help with really built up marks.
3.2 Mixture (Turtle Wax)
Component CAS Number Concentration (wt%)
Petroleum Distillites (Hydrotreated Light) 64742-47-8 15-40%
Diethylene Glycol Monobutyl Ether 112-34-5 10-30%
Propane 74-98-6 10-30%
Acetone 67-64-1 7-13%
D-Limonene 5989-27-5 3-7%
Undeceth-3 34398-01-1 1-5%
vs
Hazardous Components (Goof Off)
3. COMPOSITION/INFORMATION ON INGREDIENTS
Benzenemethanol {Benzyl alcohol} 5.0 -10.0 %
Oleic acid potassium salt 5.0 -10.0 %
Ethanol, 2-Butoxy- {Ethylene glycol n-butyl ether,
(a glycol ether)} 1.0 -5.0 %
112-34-5 Diethylene glycol monobutyl ether {2-(2-Butoxyethoxy)ethanol {(a glycol ether)} 1.0 -5.0 %
770-35-4 Propylene glycol phenyl ether {(not 313)} 1.0 -5.0 %
- Sean Fenstermacher
- Car#: 81
Turtle Wax stuff works great! I been using it for years ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
