Novice Challenge notes
Moderators: Mike Simanyi, Michael Palero, Leonard Cachola
Locked
Post by Mike Simanyi » Tue Jan 06, 2009 8:52 pm
I don't recall which thread I saw in the past 24 hours discussing the Rookie Challenge, asking if our SK classes are eligible. I just got off the phone with Curt Luther, our Eminent Rules-ologist, and we'll be publishing the updated Supp Regs shortly.
In a nutshell:
  • All National and Local classes will be available for the Rookie Challenge.
  • A Points Card *is* required.
  • Participants will run in the run group when their base class normally runs and work per the Run / Work schedule.
Those are the big items. I'm putting this out there in an incomplete, brief format just to answer that question about the SK class eligibility. Keep an eye out for updated Supp Regs in the next day or so. They're at the Solo2.com site, in the column on the left.
Locked
