Car haulers - dropped axles?
I figure with this economy there must be some big lot, where these all go to bake in the sun. Probably some good deals to be had.
Needs to be alum, drop tail or tilt, recent build. Would be nice to be able to open the car doors, I doubt I could crawl in the window. I can google, I'm looking for a personal referral if you know of or have done business with a trailer company.
Many thanks.
Many thanks.
- Thomas Barrett
- Car#: 519
Re: Repo alum car haulers - where?
Carson trailers in Yucaipa has done some good work for me and has a lot of different kind of trailers. Talk with Mike Lewis and see what he can do for you.
909-446-0322
http://www.carsontrailer.com" onclick="window.open(this.href);return false;
909-446-0322
Tom Barrett
Corvette Specialty C6
Life is like a race, the best times win!
Thanks TomThomas Barrett wrote:Carson trailers in Yucaipa has done some good work for me and has a lot of different kind of trailers. Talk with Mike Lewis and see what he can do for you.
909-446-0322
- Steve Glusman
- Car#: 424
I got a Carson trailer and I would insist on upgraded electrical
They took shortcuts and I ended up with shorts and had to replace the fixtures....
The trailer handles great and structurally, they do nice job [less paint which is VERY THIN]
Feel free to come see it -- not Al -- good old steel!
Steve G
Steve G
Carson doesn't make aluminum open trailers though.
I have the best steel open deck trailer Carson makes with a lot of addons. But it is heavy (like 2300lbs I think). And its a Carson so, it needs paint (I have a gallon of Aluminum Rustoleum paint to go with the trailer--Rollon works really well). But the electrical has been gone through. LED taillights. Electric jack, tool box, tirerack, 18ft dove tail with rear slide out storage ramps for easy access, full diamond plate deck, low mileage Goodyear Marathons, and an aluminum diamond plate tongue storage box recently added. I parked the car with tires on thin boards for the drivers side and it allowed the door to open with the ST Civic. This weekend measure my door and compare it with a vettes. There is room to drop the fenders a little on this style axle, that's what Brian Robertson did to his Carson to get the doors open.
$1900
$1900
I'm doing the SD BMW event tomorrow, but I'd like to ck it out. I guess 3/1 cscc champ is next event I will go north for. Will u have it there at the 3/1 event?
I need some way to open the Vette doors, for sure.
GVWR on my 02 Sub is #7200 less trailer #2300 less Vette #3000 leaves 1900 for tools tires or excess capacity so I guess I can pull it. Just.
Probably a 16 ft is a better fit to my truck, but I am going to eventually sell the 02 Sub for an Avalanche which I may be able to spec out for a higher GVWR.
Let's talk.
Let's talk.
ignore me....
Last edited by Steve Ekstrand on Sat Jan 31, 2009 9:19 pm, edited 1 time in total.
I dont' have it at events anymore... We went with something slightly larger...
- Steve Glusman
- Car#: 424
Show off!! Nice rig.....
Bob, I hauled my Z06 on a Carson full deck trailer. To be able to open the doors, all I had to do was position a 12" square of 3/4 plywood under each tire. I marked where they sat and screwed a 2x2 to the leading edge of the front pads for a parking stop. But I never had to attach them and had no problems. Also I layed a couple 2-ft 2x8's behind the ramps to pop the spoiler and rubber lip up before they got to the ramps.
The Carson twin-ramp all-steel trailers are a couple hundred pounds lighter than the full deck, I believe. Featherlite aluminums were only a couple hundred pounds lighter than that and twice the cost. Of course if you can find a deal...
The only electrical problem I had was the wiring for the license plate lite. It rubbed the ground and shorted. You gotta relocate the license plate to a fender. Also the OE tires were junk. I upgraded to larger wheels and tires. It's now on 225-15 LoadRange E Maxxis.
-- Bill
-- Bill
That's a great idea on the 12x12 ply, I'm going to try that, maybe I won't have to make like Luke Duke everytime.
I'm happy with my Carson too, just tack on an extra week or two to their ETA if you go custom.
Plus/minus regarding full deck vs twin ramp? I may go see Carson this week.
Thanks guys!
Thanks guys!
Why not make the fender removable like many other trailers have?Sebastian Rios wrote:That's a great idea on the 12x12 ply, I'm going to try that, maybe I won't have to make like Luke Duke everytime.
Twin: Little lighter, you can use it as a lift to work on your drive chain.Bob Plante wrote:Plus/minus regarding full deck vs twin ramp?
Full Deck: more utility
Thanks J.
It wasn't an option from Carson, but I don't think it would take too much work to make it removable.Jason Isley BS RX8 wrote:Why not make the fender removable like many other trailers have?Sebastian Rios wrote:That's a great idea on the 12x12 ply, I'm going to try that, maybe I won't have to make like Luke Duke everytime.
Another option is dropped axles. Anyone have those? pro/con?
Looked at one today (18 ft & wide & wood deck) but not with dropped axles.
About 2k.
About 2k.
Re: Car haulers - dropped axles?
Dropped axles lower the axles... That raises the fender relative to the deck.
I chose not to get dropped axles because it negates the advantage an open deck trailer has of being able to scoot under and work on the car while on the trailer.Bob Plante wrote:Another option is dropped axles. Anyone have those? pro/con?
About 2k.
- Chad Stubblefield
- Club: Team Blew
- Car#: 877
I am now throwing this idea around.
Would like to park the trailer in the garage with car on it.
The garage can fit a trailer at or under 18'.
Car weighs 2077.
Car weighs 2077.
You'd need a 14ft trailer to get under 18Ft total length. Bob Mosso did that with his RX-7 and a kart over the hood. Pretty cool to fit the whole rig in the garage. You'd need a tiny car like the Exige. A tire rack or tool box could go over the hood of the car. Don't think it could be done with a vette, but tiny cars give more options.
- Toby Larsson
I could fit two cars and one trailer in my old garage that was a 20'x20' two car garage.Steve Ekstrand wrote:You'd need a 14ft trailer to get under 18Ft total length. Bob Mosso did that with his RX-7 and a kart over the hood. Pretty cool to fit the whole rig in the garage. You'd need a tiny car like the Exige. A tire rack or tool box could go over the hood of the car. Don't think it could be done with a vette, but tiny cars give more options.
It was tight, notice how the rear bumper is touching the wall, the most difficult part was backing in with the truck .
- Pictures for website 008.jpg (56.61 KiB) Viewed 6936 times
Two cars, trailer, and a flat of Fruit snacks. Impressive.
Toby, you gave your secret away - the fruity snacks make the tires stickier!Steve Ekstrand wrote:Two cars, trailer, and a flat of Fruit snacks. Impressive.
GVWR isn't the same as towing capacity. The 2002 Suburban 1500's maximum towing capacity is 8,100 pounds.Bob Plante wrote:I'm doing the SD BMW event tomorrow, but I'd like to ck it out. I guess 3/1 cscc champ is next event I will go north for. Will u have it there at the 3/1 event?
Let's talk.
What about a Rollback:
http://www.rollbacktrailers.com/18%27_car_hauler.htm" onclick="window.open(this.href);return false;
I think you'd be better off with Silverado 2500 crew cab than an Avalanche.
