Custom Front Bar
- Michael Palero
- Car#: 18
Custom Front Bar
Where can someone get front sway bar built around here?
-Mike
-Mike
- Curt Luther
- Car#: 9
Re: Custom Front Bar
Not ST or ProgressMichael Palero wrote:Where can someone get front sway bar built around here?
-Mike
Might wanna try Hotchkis.
- Michael Palero
- Car#: 18
What happened?
Is there a story?
do tell...
Is there a story?
do tell...
- Curt Luther
- Car#: 9
Progress has/had a part# for my car. 70 people lined up to buy. Decided not to make anymore due to "lack of demand".Michael Palero wrote:What happened?
Is there a story?
do tell...
ST said they would do it. Took money and said wait three days. 2 weeks later said, "No."
Going to try an Si bar (Thanks, again, Ashley). We will go to Hotchkis or go custom if we think we need to.
I've made my own hollow 4130 bars with tubing and arm materials from Aircraft Spruce. You can make stiff bars without reheat-treating, but a more flexible bar will develop too much stress. Corner me at an event if you need more info. I can show you the math to pick tubing dimensions for various stiffnesses if you need that.
OK, masters of Stock ...
What are the limits of front bar replacement?
Is end link hardware replacement OK?
How about Bracket replacement? If brackets can be replaced, can they be replaced with ones that are offset, say to give clearance for the new bar?
I know the rules but others have lived through the clarifications, misunderstandings, etc and may have some insight....
- Reijo Silvennoinen
- Car#: 60
Front bars including mounts and end links are "free" in stock. Do what you must do. You just can't butcher the body to fit a bar in ... not that you would want to do that anyway.
Reijo
Reijo
Reijo
BS - CASOC
BS - CASOC
- David Avard
I believe that as long as they use the stock attachment points you are OK.
And KM and AH don't run HS.
Not running in a class doesn't stop AH from pushing his agenda.David Avard wrote:I believe that as long as they use the stock attachment points you are OK.
I have some connections at Progress, If you are still interested I can try for you.Curt Luther wrote:Progress has/had a part# for my car. 70 people lined up to buy. Decided not to make anymore due to "lack of demand".Michael Palero wrote:What happened?
Is there a story?
do tell...
Let me know.
- Curt Luther
- Car#: 9
I was actually gonna talk to you about this on Sunday, Seb. Will and I are thinking something more custom, but...Sebastian Rios wrote:I have some connections at Progress, If you are still interested I can try for you.Curt Luther wrote:Progress has/had a part# for my car. 70 people lined up to buy. Decided not to make anymore due to "lack of demand".Michael Palero wrote:What happened?
Is there a story?
do tell...
Let me know.
- Adam Richter
- Car#: 800
I second this. Anti-roll bars are fairly easy to make if you have the tools to do it. The 4130 tubing is cheap, and depending on the geometry you need for your car, it's probably as easy as TIG welding some simple arms onto a straight tube. Then you'll want to have it normalized and tempered to around RC40. That's how we make them for our FSAE cars. Ours are very highly stressed, and I haven't seen one fail yet.Bill Martin wrote:I've made my own hollow 4130 bars with tubing and arm materials from Aircraft Spruce. You can make stiff bars without reheat-treating, but a more flexible bar will develop too much stress. Corner me at an event if you need more info. I can show you the math to pick tubing dimensions for various stiffnesses if you need that.
Huh, i'd think you'd want to use one of the Silicon/Maganese Spring Steels like 9255 for a swaybar.Adam Richter wrote:I second this. Anti-roll bars are fairly easy to make if you have the tools to do it. The 4130 tubing is cheap, and depending on the geometry you need for your car, it's probably as easy as TIG welding some simple arms onto a straight tube. Then you'll want to have it normalized and tempered to around RC40. That's how we make them for our FSAE cars. Ours are very highly stressed, and I haven't seen one fail yet.Bill Martin wrote:I've made my own hollow 4130 bars with tubing and arm materials from Aircraft Spruce. You can make stiff bars without reheat-treating, but a more flexible bar will develop too much stress. Corner me at an event if you need more info. I can show you the math to pick tubing dimensions for various stiffnesses if you need that.
- Eric Clements
They don't even have to mount in the stock position. You can drill mounting holes and mount it how you like, as long as it serves no other purpose.David Avard wrote:I believe that as long as they use the stock attachment points you are OK.
Everything you need: http://www.hrpworld.com/index.cfm?form_ ... n=category" onclick="window.open(this.href);return false;
btw the replacement bar does not have to use the OE mounting locations in stock.
