How Come We Don't Have More Formula Car Racers?
I haven't run in SD in a while, but there use to be a number of FVees and FFords running down there. I got to run a FVee down there once. Neat seeing the wheels. The one I drove had extra wide tires on it making the steering a bit heavy.
It would seem that running a FFord would be a relatively inexpensive way to run a real, open wheel, very light weight "proper" race car. I would imagine that it would be fairly easy on slicks tire wear?
What class would a FF run in? Would one be allowed to construct a bubble canopy to keep out rain?
Someone lent me a helmet, I forgot that one had to wear a full visor helmet in open cockpit cars. I came in 2nd out of I believe five Formula cars.
Re: How Come We Don't Have More Formula Car Racers?
CM, no canopy.Mako Koiwai wrote:I haven't run in SD in a while, but there use to be a number of FVees and FFords running down there. I got to run a FVee down there once. Neat seeing the wheels. The one I drove had extra wide tires on it making the steering a bit heavy.
- Adam Richter
- Car#: 800
I've wondered that too. With so many people who drive trailered cars, it's a little surprising that more people don't drive purpose built race cars vs modified street cars. My only formula car experience is driving fsae cars and they're certainly faster and more fun to drive than any street car I've driven. I guess classing and car availability has a lot to do with it.
I'd never even think about buying a Formula Vee though. Why buy a formula car with such a disaster of a suspension?
I got two FSAE cars at my parent's garage. I just need a truck and trailer to bring them out. I like my street car though, the (street) tires are cheaper and last alot longer. Also, the street car is more reliable and less maintenance.Adam Richter wrote:I've wondered that too. With so many people who drive trailered cars, it's a little surprising that more people don't drive purpose built race cars vs modified street cars. My only formula car experience is driving fsae cars and they're certainly faster and more fun to drive than any street car I've driven. I guess classing and car availability has a lot to do with it.
Fixed that for ya...........Mako Koiwai wrote: It would seem that running a F125 would be a relatively inexpensive way to run a real, open wheel, very light weight "proper" race car. I would imagine that it would be fairly easy on slicks tire wear?
One clue might be found in the Nationals results. Most of the Prep and Mod Class champions are areas with colder climates where there are no events during the winter, allowing time to work on the car.
My next car might be a Formula F [formerly Ford, changed to F with last years homologation of the 1.5-liter Honda Fit engine]. It would be light enough to trailer behind the Red Rat and car and trailer would fit in half of my garage.
Hmm....bob, you might just be on to something there....
co drive? Either one of those or what about a Super 7? mmm....
2017 MX-5 - #427 ???
- Don Salyers
- Car#: 42
Bob, another big plus, the tires get old--not worn--on a 1500 car, they could last forever on a 900 to 1000 pound car. Also the mod classes weigh with driver, Kurt you listening, the prep cars weigh without....Bob Beamesderfer wrote:One clue might be found in the Nationals results. Most of the Prep and Mod Class champions are areas with colder climates where there are no events during the winter, allowing time to work on the car.
There are 2 Formula Fords on ebay right now, both under $10,000...
Don
Is one allowed to use tire treatments in CM to try and extend tire life ?
Are Hoosier A6's softer then racing slicks?
yesMako Koiwai wrote:Is one allowed to use tire treatments in CM to try and extend tire life ?
no
You're allowed to make your own tires in your garage if you want in P/M.Mako Koiwai wrote:Is one allowed to use tire treatments in CM to try and extend tire life ?
- Don Salyers
- Car#: 42
I picked up enough OPR or what ever it was at Nationals that after 15 runs here I am just now seeing the original tire.... ... and I only got 2 runs in Lincoln before the axles broke.....Aaron Goldsmith wrote:You're allowed to make your own tires in your garage if you want in P/M.Mako Koiwai wrote:Is one allowed to use tire treatments in CM to try and extend tire life ?
Don
Ears perked up! That's definitely something to think about, assuming I could sausage myself into one.Don Salyers wrote:Also the mod classes weigh with driver, Kurt you listening
sorry bud, there is no way you'd fit in any formula style cars that I know of.Kurt Rahn wrote:Ears perked up! That's definitely something to think about, assuming I could sausage myself into one.Don Salyers wrote:Also the mod classes weigh with driver, Kurt you listening
Check out John Kestler's Shannon sports 2000 racer when we get to the El Toro events ... roomier.
http://shannonracecars.com/
John in the blue one. As owner of the Shannon company, he might be able to get you a deal.
Kinda what I figured. BTW, you left your crappy weather back here...it's hailing with thunder and lightning.Marshall Grice wrote:sorry bud, there is no way you'd fit in any formula style cars that I know of.Kurt Rahn wrote:Ears perked up! That's definitely something to think about, assuming I could sausage myself into one.Don Salyers wrote:Also the mod classes weigh with driver, Kurt you listening
- Don Salyers
- Car#: 42
The formula style cars run in Modified classes, therefore you can make them fit----just a bit more modified than others. It may just have a few convex fiberglass panels and your feet may stick out the grille if it has one..... I can see it now, a little molded bubble up front for the size 15 and above Pilotis.Marshall Grice wrote: sorry bud, there is no way you'd fit in any formula style cars that I know of.
Don
But A6s come up to working temp faster than some slicks.Mako Koiwai wrote:Is one allowed to use tire treatments in CM to try and extend tire life ?
Not on a 1000lb car. And keep in mind just like you have the R6 and A6 you will find up to 3 to 4 compounds of slicks. If you know the right people you can even have your own compound made. In the last few years a number of people have shown up with a tire no one else had/could get in Prep/Mod.Bob Beamesderfer wrote: But A6s come up to working temp faster than some slicks.
Interesting. Not cheap I'll bet.Jason Isley BS RX8 wrote:Not on a 1000lb car. And keep in mind just like you have the R6 and A6 you will find up to 3 to 4 compounds of slicks. If you know the right people you can even have your own compound made. In the last few years a number of people have shown up with a tire no one else had/could get in Prep/Mod.Bob Beamesderfer wrote: But A6s come up to working temp faster than some slicks.
I guess I should have gotten on this sooner because I can't remember all the questions.
a) I have a Lola T540 formula ford, previously CM (& past national champ) now being refitted for BM. You'll see it back later this year. Faster!
In no particular order:
FF takes far less upkeep and maintenance than a car intended for road use. Buy one, put soft compound tires on it and drive it. Well...you may want to buy a lower first gear set, but they're cheap and all gears can be moved around. I,E. you old first is now your second, etc. As the car is designed from scratch for more severe service than solo, you just don't need to modify anything and do only the most basic services like oil changes and spark plugs. By rule, the engine is blueprinted stock, so not highly stressed.
Tires last a season and are regionally competitive into the next season with softener. And pretty cheap since they're fairly small. I've never worn out a tire...just gave up on them. And I've never seen an A6 on a FF...you need a 19.5" to 20" tall front tire. And the rears are special purpose (wide) cantilevers to fit the required 5.5" wide rims. Can't mess with the rims either. It's a highly restricted class...you just buy the tires designed for the car.
The car is a killer in rain. A little hard on the driver, but you can cope. At the San Diego Deluge National Tour I set TTOD by several seconds, which included nationally competitive BM cars. And it's not like I have a lot of experience at rain driving. Lightweight, mild power, real rain racing tires.
I think Cal Club's lack of prepared and modified cars is just an anomaly. But in general P & M have diminished nationally with the growth of all the street tire classes. Cal Club is exceptionally low for who knows why.
What did I miss? -- Bill
I
I
- Don Salyers
- Car#: 42
Bob, they could have been free "test" compounds....Bob Beamesderfer wrote:Interesting. Not cheap I'll bet.Jason Isley BS RX8 wrote:Not on a 1000lb car. And keep in mind just like you have the R6 and A6 you will find up to 3 to 4 compounds of slicks. If you know the right people you can even have your own compound made. In the last few years a number of people have shown up with a tire no one else had/could get in Prep/Mod.Bob Beamesderfer wrote: But A6s come up to working temp faster than some slicks.
Don
