Looking for a stock rear sway bar and
mounts for a NA miata. The thinner the better.
Local preferred. Will pick up.
Update 1/3/13, Kin Lee had one.
Thanks.
Wanted: NA miata rear sway bar and mounts
- Pete Loney
- Car#: 777
Re: Wanted: NA miata rear sway bar and mounts
I've got one from a Base model '94, which I believe is 11 mm in diameter. Probably have the mounts also.
- Pete Loney
- Car#: 777
Thanks Bob.
A new to the board and the Torrance area supplied me a bar.
Thanks Kin Lee!
Thanks Kin Lee!
- Steve Collins
- Car#: 799
Are you going to put that on your car?
- Pete Loney
- Car#: 777
Yeah. Trying to have a single spring/bar for fontana or el toro.Steve Collins wrote:Are you going to put that on your car?
Looking to add some rotation too.
Should work great. I never got a "no rear bar" setup to work at all with my car. Always felt like the car understeered and I would overload the rears trying to get it around.
- Steve Collins
- Car#: 799
Interesting. I may give the stock bar another try once I've had a chance to get used to the toyos. I'm hoping to get out to a few events now that the whole Mars landing thing has died down.
steve
steve
- Pete Loney
- Car#: 777
Fyi. I had to use shorty endlinks compared to the stock ones.Steve Collins wrote:Interesting. I may give the stock bar another try once I've had a chance to get used to the toyos. I'm hoping to get out to a few events now that the whole Mars landing thing has died down.
steve
I had leftover whiteline links from my subie days.
