Set of 4 Enkie RPF-1 rims. 15" x 7". 41 mm offset. Mounted with lightly used Bridgestone Potenza RE71-R 205/50R15 86V tires.
Purchased for autcross use on an NA Miata. This is $1,500 worth of gear if purchased new, and it is all in good condition. Money back if not satisfied.
I won't break up the set. More pictures of all 4 rims and tires available on request.
Doh! As pointed out below I forgot some important stuff. The bolt pattern is 4x100 and the hub center measures 60mm.
Enkie RPF-1s with RE71-R Tires Mounted - $550 in San Diego
Fauxrari Guy
- 20210725_163819.jpg (2.71 MiB) Viewed 9896 times
- 20210725_163136.jpg (2.3 MiB) Viewed 9896 times
- 20210725_163749.jpg (2.09 MiB) Viewed 9896 times
- Kathy Teulie
- Car#: 96
Re: Enkie RPF-1s with RE71-R Tires Mounted - $550 in San Diego
Just to help you out. A hub center dimension and bolt pattern (4 or 5 lug) lug to lug dimensions (# X #) would help.
Fauxrari Guy
Oops. Thanks! Updated the post.
