Best Route to Lincoln NE
David A
Post by David A »
I am taking my first trip to Solo Nats this year and trying to figure out the best route given I'll be towing my car (GR86). I'll be hauling my car behind my V8 Jeep Grand Cherokee which has a towing limit of 7,800 lbs on a Uhaul trailer. So, while this setup will be within the towing limit of my Jeep, it will not be as capable as if I were towing with a full size pick-up.
Google Maps is telling me the best route is to take I-70 through Colorado. I've not driven that route before but have read it is a challenging road for towing with a couple of passes over 10,000 of elevation, lots of steep decents, windy sections, etc.
For some of you that have towed vehicles to Lincoln a few times, what route do you recommend?
Sean Fenstermacher
Car#: 81
Re: Best Route to Lincoln NE
Post by Sean Fenstermacher »
I would suggest the most Northern route to avoid the Rockies.
I-15 thru Salt Lake City then I-80.
Good luck at Nats!
George Schilling
Car#: 66
Post by George Schilling »
As light as your car is, you'll have no problem taking I-70. You'll be rewarded with one of the most scenic drives in the country. Grand Junction makes a great overnight stopping point. Be sure to pull off and dip your toes in the Colorado River in Glenwood Canyon. Take the drive. You won't regret it!
David A
Post by David A »
Sean Fenstermacher wrote: ↑Wed Aug 28, 2024 10:22 am I would suggest the most Northern route to avoid the Rockies.
Good luck at Nats!
Thanks Sean. I hadn't considered I-80. That doesn't look like that bad of an option. It is only about 55 miles further but a much straigher shot.
I might do that.
David A
Post by David A »
George Schilling wrote: ↑Thu Aug 29, 2024 8:32 am As light as your car is, you'll have no problem taking I-70. You'll be rewarded with one of the most scenic drives in the country. Grand Junction makes a great overnight stopping point. Be sure to pull off and dip your toes in the Colorado River in Glenwood Canyon. Take the drive. You won't regret it!
I've heard it is just stunning. And, I've always wanted to drive that stretch of road. I may do it for either coming or going. It appears my decision point is 8.5 hours into my drive if I do it for the drive there. I'll have some time to ponder it. Thanks for the input. Your are right on the car being light. I've towed a 4k lb boat behind the jeep and could hardly tell it was there. My biggest concern was not having the HP to go up the grade easily. I think I can. My concern was with braking. I'll be hauling the car on a uhaul trailer (wildcard). If the brakes seem to be working good, it might ease my mind. If the trailer is a beater.......well, I don't want to rely on only my Jeep's brakes for those downslopes coming off 11,000 ft elevation on a 6+ degree downslope. Sure, I can downshift, and will, but it still will suck doing a long slow motor braking down those slopes.
Thanks!!
Bill Sanford
Post by Bill Sanford »
As my brother is in Denver/Aurora (My parents were before they passed) I have made the I-15 to I-70 tow more than a few times. it is not hard to tow a light cars as noted. A surge brake trailer as U-Hauls are, are good heavy duty trailers. You will find steeper grades in Utah than you would think. If you take the I70 route, pay attention to when the next "services" are. One section from Salina to Green river in Utah is @118 miles IIRC. (I never did the 15 to 80 route.
Very true the Glenwood canyon route has few peers, stop at a rest stop in there if you can at the very least. The grades in Colo are high, but gradual. Maybe leaving Denver is pretty significant. Same coming in, but there is plenty of traffic, so most of the time you won't be going fast as you hit big cities. Not really a problem except at "rush hour" going into or leaving Denver.
Be prepared for miles of boring sections and to remember every foot of every lap you made on your return home.. :lol:
Good luck, I think you'll do well!
Bill
PS: I forgot I've been running a Turbo Diesel for 20+ years... you will notice the altitude, power wise.
