Need a couple of '03 Z06 lug nuts (M12 1.5)
M12 1.5
I was able to clean up the studs and lug nuts, but the nuts are a bit loose now. Stud's seem OK when using good nuts, but I lost too much metal on the galled nuts.
If you have a couple that Karen can use on Sunday, I will buy you new ones. I won't be able to probably buy tomorrow since I'm helping at the Ladies School
Bob Pl
Car#: 26
Re: Need a couple of '03 Z06 lug nuts (M12 1.5)
Post by Bob Pl »
Got a box full in my garage, but the garage is in Carlsbad & I'm not in the event, so that's not much help. You should be able to pick up a nut that'll work at most napa/pepboy/kragen tonight. it's not a Vette specific part.
Most Vette guys (that come prepared) will have a couple of spare studs/nuts in their tool bag. Or someone with a prepped Camaro.
Is there something special about them? I can send some generic ones from my toolbox with Stacey tomorrow just in case you don't get offered what you want.
Jason Isley BS RX8
Post by Jason Isley BS RX8 »
Mako Koiwai wrote:M12 1.5
The Miata also uses a M12 1.5, just pull one off there.
Our Miata ones seem awfully short ...
Jason Isley BS RX8
Mako Koiwai wrote:Our Miata ones seem awfully short ...
Only need to be as long as the stud is thick. A lot of the longer nuts are not even threaded all the way. :unimpressed:
Note the lack of threads in the end of this C4 style lug.
Last edited by Jason Isley BS RX8 on Fri Nov 26, 2010 6:56 pm, edited 2 times in total.
OK ... we've got a LOT of brand new short Miata lug nuts ... I think we can save a few ounces that way. Look out Richard Warriner! (Karen) :gpower:
Bob Pl
Car#: 26
Post by Bob Pl »
Lug nut should have a bulge or you will "drill" into the c5 rim.
http://i125.photobucket.com/albums/p70/ ... G_1616.jpg
Above has the bulge AND threaded shank, whuch I prefer. Lot more thread engagement.
Our Miata ones are "capped" ... will check them out tomorrow
The problem with the Miata nuts ended up being that it didn't have that collar like the Vette one on the left. The temporary Miata one was OK for the few runs today. Replacing with oem soon.
Bob Pl
Car#: 26
Post by Bob Pl »
In the lug nut business they call it the bulge. Just so if you order some online from a source who knows the product, they will understand what you need.
You should go open end.
