Evans cooling
- Toby Larsson
Evans cooling
Putting in a brand new engine and new cooling system in my car. I'm tempted to fill with this, I like the idea of running a non pressurized system.
I know there's some smart people reading this that can give me some pro/cons to it (I'm not concerned about the cost).
http://www.evanscooling.com/products/coolants/npg-2/" onclick="window.open(this.href);return false;
- Bobby Beyer
Re: Evans cooling
Is it a requirement that you run with no ethyl glycol coolant?
The engine in your car was likely designed to a run a pressurized coolant system getting rid of the pressure cap doesn't seem like a good idea. also since its not running a pressurized cooling system its very likely you'll get some spillage during a heat cycle due to fluid expansion so you'll probably have to buy a few extra gallons.
Its a propylene glycol which is flammable so if a leak does occur you may end up with a bigger problem than an overheat situation.
- Toby Larsson
Re: Evans cooling
Bobby Beyer wrote:Is it a requirement that you run with no ethyl glycol coolant?
It's not a requirement but most people run what I used to use, straight water with water wetter or similar. The stock cap would stay in place, I guess it expands a lot less so it's almost non-pressurized. The flammable part is slightly concerning in case of a punctured radiator.
Re: Evans cooling
i've never used it but just doing some research here are some things i come up with.
CONS:
-npg (propylene glycol) is more dense than water, 8.6lb/gal vs 8.3lb/gal @25c
-it's got a lower thermal conductivity. 119 mw/m*k vs 607 mw/m*k
-it's got a lower specific heat capacity. 2.51 J/g/k vs 4.2 J/g/k
-its got higher thermal expansion. 7.3x10-4 /*C vs 1.5x10-4 /*C
-it's more viscous than water.
-it's flammable.
PROS:
-its got a higher boiling point. 187C vs 100C
summary:
looks like you'll need a bigger radiator and/or higher flow rates of (slightly) heavier fluid to match the thermal properties. you'll need a bigger overflow bottle. and it's likely to draw more power from the engine to make it all work. you could run the system at a higher overall temp with the NPG to trade back some of the larger radiator area/flow rate but that will likely be limited by oil temps and motor clearances. Considering it is now a fire risk i'd think proper AN (or equivalent) plumbing would be required vs the regular push on/hose clamp plumbing you can get away with using water.
CONS:
-it's flammable.
PROS:
summary:
- Car#: 14
Re: Evans cooling
Who are you and what have you done with Toby?Toby Larsson wrote:... (I'm not concerned about the cost)....
- Toby Larsson
Re: Evans cooling
Thanks Marshall, I think you made the decision for me. Not enough benefits to make up for the added cost.Marshall Grice wrote:i've never used it but just doing some research here are some things i come up with.
CONS:
-it's flammable.
PROS:
summary:
Maybe I'll go the NASCAR route and run a 30 psi 300 degree cooling system
- Richard Jung
- Car#: 71
Re: Evans cooling
I run Prestone's NASCAR coolant. No antifreeze in it, just add to distilled water.Toby Larsson wrote:
The FD RX7 guys used Evans, due to the low pressure aspect not causing the cooling system to blow up.
Re: Evans cooling
i agree. all 'real' racecars (F1, prototypes, ...even nascar) use a prepresurized sealed cooling system. something like this.Toby Larsson wrote:
http://www.crracing.com/tech/cooling-in ... ing-system" onclick="window.open(this.href);return false;
- Toby Larsson
Re: Evans cooling
Marshall Grice wrote: i agree. all 'real' racecars (F1, prototypes, ...even nascar) use a prepresurized sealed cooling system. something like this.
Great link. Those kind of systems are what lets NASCAR cars run in draft lap after lap with a grill opening that is only 2.5"x20" without overheating.
I'm a bit more conservative, my opening is 5"x24" which is still a lot smaller than OEM but I need to reduce drag as much as possible.
I wonder what other modifications are needed to run a 30 psi system, I've already replaced the hoses with Al tubing.
- Bobby Beyer
Re: Evans cooling
Are you running solid motor/tranny mounts?
- Toby Larsson
Re: Evans cooling
Sort of, links with rod ends fore and aft. 3M window weld ( I know I know, no support aftermarket for a 6g Celica) on the left and right mount.Bobby Beyer wrote:Are you running solid motor/tranny mounts?
