This car is tubbed, but you can see the tire is tucked.
2x4 under throttle pedal.Bryan Fargo wrote: I was hoping for an easy solution
Fender liners weren't invented back then for the Nova/Chevy II. ;)Mako Koiwai wrote:... you'll find lots of worn fender liners among our AX'ing cars ... ;)Bigger Tires
How about a 2 barrel carb???Mako Koiwai wrote:I know some ASP National Champs will do entire runs without ever giving full throttle in their Vettes ...
Make sure you run with your AC on and do whatever else you can to rob power in that thing!
Thanks for the feedback John. In my experience with leaf springs the lateral movement is minimal and does not require a panhard bar. One benefit I was thinking was the panhard bar could be built to raise the rear roll center to induce a bit more understeer. What do you think?John Coffey wrote:The following are typical leaf spring live axle mods and do help:
1. Panhard bar - as long as possible and as adjustable as possible.
2. Staggered shocks.
3. Cambered housing.
4. Composite rear springs (Hyperco and others).
5. Boxed sliding shackles.
And if you really want to make it work, get rid of the leaf springs and run a three link torque arm with coil overs.
I have a detroit locker- no limited slip, just locked or unlocked! Its a bit noisy- you will hear a clicking type noise when I go around corners.Mako Koiwai wrote:As others have mentioned ... what about a LSD ?
I appreciate your feedback John!John Coffey wrote:Every one of the changes I mentioned is an incremental improvement and one, by itself, is not a big deal. Its easy to argue against each one and miss the combined benefits of a whole system approach. Combined they better locate the live axle and make the rear suspension more subtle and responsive. Composite rear springs are lighter and if you run a Panhard bar and take the lateral location duty away from the leaf springs, they can be even lighter and more responsive. You will need to work our some method of handling pinion torque if you go too light on the leaf springs. An aluminum rear axle housing is another good option. The staggered shocks is a hit or miss thing. It works on some cars and drivers and doesn't work on others.
BTW.. something simple as adjusting pinon angle by a degree or two can make a noticeable difference in getting power down.
