Best tire for STS (90 Civic Si)
Re: Best tire for STS (90 Civic Si)
Jeff, we need a couple of those Toyo :heyes: decals for the Miata ...
I called some local tire places, and the best price I got was $460 out the door for the R1R's in 195/50/15 size. Is that a good price?
mounted and balanced with tax? if so, yes. Where did you find the deal at?Jonathan Lee wrote:I called some local tire places, and the best price I got was $460 out the door for the R1R's in 195/50/15 size. Is that a good price?
Jeff,Jeff Wong wrote:mounted and balanced with tax? if so, yes. Where did you find the deal at?Jonathan Lee wrote:I called some local tire places, and the best price I got was $460 out the door for the R1R's in 195/50/15 size. Is that a good price?
The place is in San Gabriel, $460 mounted and balanced - cash price. I will PM you the phone # and address.
Durometer testing on 225, 205, and 195 showed the same for all. The compound thing was a rumor. It's possible that Andy's tires froze during shipping or something.
What are the Toyo's like full tread???
- Ken Motonishi
- Car#: 491
They are faster than shaved.
Changing the subject as I often do, anyone have a source for an 89-91 differential?
Dood, are you gonna eat that?
I know someone. What ratio were you interested in? }:)Ken Motonishi wrote:anyone have a source for an 89-91 differential?
- Leslie Cohen
- Car#: 137
It seems that for a typical autocross course the 195 is a little better. But when you have some nice sweepers, the larger tire is works very well. ie. Last weekend in San Diego ;) Oh yeah, full tread actually works in San Diego.
Leslie
ST(S) Civic/SS Z06
ST(S) Civic/SS Z06
Do you guys have thoughts on the BFG T/A KDs? I was pretty confident with them when I was using them, but I've also not been on the scene in a few years. *never was a fan of Azenis...in any flavor/year*. So the consensus seems to be Toyo has a good tire, what of the Bridgestone RE-11? any good?
if you civic guys are doing ok on 195s I might drop down a step...used to running 205s on a 6" rim...thinkin that might be good. ::shrug:: have to try em.
2017 MX-5 - #427 ???
195 toyo or 205 RE-11
I wouldn't be thinking anything else.
KD's.... That was funny. Sooooo 2002.
I've never run in ST, but I ran on KDW2s (which were supposedly two generations improved over the KDs) in SK2 (admittedly on a car that weighed almost twice what a Civic weighs). They were okay, but when I switched to Star Specs, I dropped two seconds off my times almost immediately. And apparently the Toyo and the 'Stones are better on the lighter cars.Dan Shaw wrote:Do you guys have thoughts on the BFG T/A KDs? I was pretty confident with them when I was using them, but I've also not been on the scene in a few years. *never was a fan of Azenis...in any flavor/year*. So the consensus seems to be Toyo has a good tire, what of the Bridgestone RE-11? any good?
I ran the Star Specs on the STS Miata last year for National events (thanks Mike), At the two ProSolos I gave up 3/4 - 1 sec on the 100 ft times on each side. I then held my own, or caught up slightly over the remainder of the course.
The problem with the Star Specs on the 15" rims was the aspect ratio (taller tire). I honestly don't think I gave up anything in the Grip dept.... it was all at the start line. I have relatively no tire wear... they were ripping through the Toyo's
Plus I was on 195's vs. 225's....
it's all about if's... if the Star Spec was shorter, if it came wider.... if we could talk them into 225/50/15's
See the ST tire test in SCCA Sports Car magazine. I believe the Sept or Oct issue
Another ST Tire test in the Dec. issue of EuroTuner ... you can download it here:
http://gifts.barnesandnoble.com/search/ ... P=Z&FMT=32
Thanks for finding this Andy H!
You can make it as complicated as you want.
But bottom line, for a small car with 6" rims, you want either the
195 Toyo R1R
or the longer lasting 205 Bridgestone RE-11
Are there other tires? Yes. But not better tires for that car on narrow rims.
195 Toyo R1R
My Posts/Links were meant to be Off-Topic yet informative
- Car#: 226
WOW
I'm glad I'm not able to sleep and took the time to go through some of these threads. I didn't think you guys would be so willing to share info such as tire choice! Cool deal.
Thanks for the good read. I'm looking forward to more events in 2010 (I did two in 2009) with my CRX.
Hope to meet some of you out there!
Based upon recent evidence... this may not be true... the Hancook is looking like a contender too.Steve Ekstrand wrote:You can make it as complicated as you want.
195 Toyo R1R
not for a 6" rim. ;)Craig Naylor wrote:Based upon recent evidence... this may not be true... the Hancook is looking like a contender too.Steve Ekstrand wrote:You can make it as complicated as you want.
195 Toyo R1R
But yes, on a medium-high grip lot the Hankook is an awesome tire.
I focused on the rec's I did specifically for a light car on 6" rims.
I probably will try the Hankook's on my 7.5"rs... Assuming I have an ST future.
Think fast ratio Power Steering, Evo ... RevLab steering rack in a STIAssuming I have an ST future.
[quote ="Jonathan Lugod"]not for a 6" rim. ;) [/quote]
Whats so special about a 15 x 6" vs. 14 x 5.5" rim that the same width (225) in a lower aspect ratio (45), with an extra .5" width of rim space, suddenly can't work?
Seams non-nonsensical to me.
1st gen CRX's, and similarly year Civic's in stock class have stuffed Hoosier 225/50/14 on 14 X 5.5 rims for at least the 14 years I've been playing at this game, most likely much longer!Steve Ekstrand wrote:I focused on the rec's I did specifically for a light car on 6" rims.
You're missing the point. I know you can cram the tire on there. It just isn't faster than the properly fit 195s and 205s.
So the extra grip acquired on the DOT stock legal 225's (vs DOT 195/205) doesn't translate across to the "street" compounds? Even though the "streets" of today are probably way ahead of the "DOT" tires of 10+ years ago?Steve Ekstrand wrote:You're missing the point. I know you can cram the tire on there. It just isn't faster than the properly fit 195s and 205s.
Why less contact patch would be better?
