Page 2 of 2
Re: Return to AutoX
Posted: Tue Oct 01, 2013 9:22 pm
A lot of cars with non steel (or heavily bondo'ed) body panels use the static cling numbers/letters.
Guy Walker wrote: jay,
thanks! maybe I can use some of it but apparently the z's doors are not made of steel (aluminum it seems). my old numbers only sick to the fenders and not the doors!
i guess i'm going to have to look up the rules for numbers and class letters size and placement.
guy
PS: minimalistic, but rules eligible, numbers (8" high with 1.25" stroke) and class letters (4" high with 0.75" stroke) might fit on the fender between the front wheels and the door... i'm open to suggestions for door placement though! what do corvettes do?
Re: Return to AutoX
Posted: Wed Oct 02, 2013 8:14 am
by Bill Martin
And I use magnetic numbers on non-magnetic surfaces with double-stick tape. I like double-stick masking tape from McMaster. Reason to use the magnetic material is it's tough enough to remove/reuse repeatedly. And easy to buy.
Re: Return to AutoX
Posted: Wed Oct 02, 2013 10:07 am
by Guy Walker
Bill Martin wrote:And I use magnetic numbers on non-magnetic surfaces with double-stick tape. I like double-stick masking tape from McMaster. Reason to use the magnetic material is it's tough enough to remove/reuse repeatedly. And easy to buy.
hmm... i'll try this.
is there a particular type of double-stick tape? foam? I'm sure it can't be too thick or the wind would get behind the numbers.
Re: Return to AutoX
Posted: Wed Oct 02, 2013 12:29 pm
We like the Tacky numbers from iZoom.com
Static cling doesn't work in our opinion.
Important to keep the surface very cling with the tacky numbers
Lisa S ... CSCC driver No. 1 ... tapes a clear plastic sleeve to the side of her Vette that she can slide in her or her co-drivers number
Re: Return to AutoX
Posted: Thu Oct 03, 2013 8:27 pm
by Jayson Woodruff
Mako Koiwai wrote:Lisa S ... CSCC driver No. 1 ... tapes a clear plastic sleeve to the side of her Vette that she can slide in her or her co-drivers number
And it looks about as good as it sounds.
Mako's izoom stuff is about the best I've seen, I still haven't had any luck duplicating it. Static works long term ONLY IF you're clinically obsessed with keeping things clean, straight and well stored (see Samanyi).
Re: Return to AutoX
Posted: Fri Oct 04, 2013 12:07 am
Static works long term ONLY IF you're clinically obsessed with keeping things clean(ed), straight and well stored
Basically you need a GF to do this ... Thanks Karen! :thumbup:
Re: Return to AutoX
Posted: Wed Oct 09, 2013 9:08 pm
by Guy Walker
thanks to all, my first event back was fantastic! i had such fun driving and meeting up with old, and young, friends.
special thanks to jay for the class letters and numbers and to ken for delivering them to me.
you guys all make this sport much fun!
