Except for the driver....Bill Schenker wrote: Also, Steve, have to go w/Jason here: no bending, cutting, etc. is allowed in SP.
OCT. Fastrack
Re: OCT. Fastrack
- Steve Lepper
- Car#: 355
Re: OCT. Fastrack
I may have that wrong, as I've had my nose buried in the SM regs a lot recently.Bill Schenker wrote: Also, Steve, have to go w/Jason here: no bending, cutting, etc. is allowed in SP.
Although, if there is no cutting/bending/etc, that makes it even more interesting. I'll use your car as an example: your intake duct goes under the radiator, right? How did you get around the factory foam seal that goes between the lower radiator tank and plastic undertray? Seems a lot of Miata folks conveinently forget this part ever existed... yet I see a lot of stock cars (mine included) that still have it.
On a related note, now that they have allowed replacement radiators, it will be interesting to see how things like the Miata seal get handled. If my Miata didn't have a foam seal across the bottom of the radiator, I could build a big cold air duct in the space: think 1 1/2" high by 24" wide would have some effect? Betcha it would. I can think of a few other cars out there where this same kind of advantage could be applied.
Re: OCT. Fastrack
You must have not looked close enough: the foam is still there as my rad. is oem- nothing cut, bent or left out.Steve Lepper wrote:I may have that wrong, as I've had my nose buried in the SM regs a lot recently.Bill Schenker wrote: Also, Steve, have to go w/Jason here: no bending, cutting, etc. is allowed in SP.
Re: OCT. Fastrack
In SP, this isn't allowed.Steve Lepper wrote:This seems to set the precedent that it's not legal to slightly trim/bend parts to facilitate the installation of other parts.
- Mari Clements
- Car#: 130
Re: OCT. Fastrack
Not much worse than Ladies in STU...Mike Simanyi wrote: The only problem with ST classes following the category name occurs after STC...
- Curt Luther
- Car#: 9
Re: OCT. Fastrack
Mari Clements wrote: Not much worse than Ladies in STU...
Re: OCT. Fastrack
What is with these socal "Miata Tuners"? They claim this and that, sell parts to customers assuring them they are class legal, and then have to back pedal because the never looked at the rules.Steve Lepper wrote: I may have that wrong, as I've had my nose buried in the SM regs a lot recently.
Here is another prime example... Read the proposed rule about radiators in SP, and then edit your post to save yourself further embarrassment.
Re: OCT. Fastrack
Too bad the dimensions have to be the same:Steve Lepper wrote:I may have that wrong, as I've had my nose buried in the SM regs a lot recently.Bill Schenker wrote: Also, Steve, have to go w/Jason here: no bending, cutting, etc. is allowed in SP.
3) Fluid capacity /_and dry weight_/ of radiator must be no less than that of the standard part. Alternate
radiators may serve no other purpose (e.g. to allow a cold air intake passage).”
- Eric Clements
Re: OCT. Fastrack
No they don't! They just can't be smaller.Bob Beamesderfer wrote:[
Re: OCT. Fastrack
Oh, yeah. But the part about the size requirement as it relates to routing an intake is the key issue. Bigger? Might as well be the same.Eric Clements wrote:No they don't! They just can't be smaller.Bob Beamesderfer wrote:[
- Steve Lepper
- Car#: 355
Re: OCT. Fastrack
Thanks Bill... I figured if anyone here would know about that it would be you. I'll look more closely next time: I was remembering it passed under the radiator, but if you have the OEM seal in there then it must take a different route.Bill Schenker wrote: You must have not looked close enough: the foam is still there as my rad. is oem- nothing cut, bent or left out.
- Steve Lepper
- Car#: 355
Re: OCT. Fastrack
And, you would know what I sell... how? Mazda dealers are typically the ones selling their intake kit. You might want to get a clue before you attempt such foolish generalizations.Jason Isley BS RX8 wrote:What is with these socal "Miata Tuners"? They claim this and that, sell parts to customers assuring them they are class legal, and then have to back pedal because the never looked at the rules.
Go back and read the part where I said I don't use this kit. I can understand why a lot of folks would be annoyed by this: when a manufacturer sells an emissions and warranty legal accessory, you would think it should be legal in a class where intake systems are pretty much free. There's an easy way for Mazda to play along and eliminate the issue, (the topic is already on it's way to an interested party there) so it will be interesting to see if they decide to do anything about it.
- Steve Lepper
- Car#: 355
Re: OCT. Fastrack
I saw they shot that down right away before anyone could buld one with a big hole in the center.Bob Beamesderfer wrote:Oh, yeah. But the part about the size requirement as it relates to routing an intake is the key issue. Bigger? Might as well be the same.Eric Clements wrote:No they don't! They just can't be smaller.Bob Beamesderfer wrote:[
Re: OCT. Fastrack
But it does go under the rad. - but the foam is still there - not removed.Steve Lepper wrote:Thanks Bill... I figured if anyone here would know about that it would be you. I'll look more closely next time: I was remembering it passed under the radiator, but if you have the OEM seal in there then it must take a different route.Bill Schenker wrote: You must have not looked close enough: the foam is still there as my rad. is oem- nothing cut, bent or left out.
- Steve Lepper
- Car#: 355
Re: OCT. Fastrack
The stock foam should be contacting both the bottom of the rad and the lower splash pan almost all the way across with the exception of short open sections near each corner. To go under the center would mean bending the foam out of the way, and the rules state No Bending. Does it come through the lower right corner? I seem to remember the flex hose being on that side. I will definitely have to take a closer look next time I see your car.Bill Schenker wrote:But it does go under the rad. - but the foam is still there - not removed.Steve Lepper wrote:Thanks Bill... I figured if anyone here would know about that it would be you. I'll look more closely next time: I was remembering it passed under the radiator, but if you have the OEM seal in there then it must take a different route.Bill Schenker wrote: You must have not looked close enough: the foam is still there as my rad. is oem- nothing cut, bent or left out.
Re: OCT. Fastrack
I think you'd be hard put to say that with the foam in place I'm illegally "bending" the foam out of place.
Re: OCT. Fastrack
You will not find the word "bending" in the rules until the SM section. You are not allowed to cut holes in the hood for carburetors or in the firewall for cowl intakes. The rules are silent about pushing something flexible out of the way. This setup is on a couple of cars, Bill's and George Doganis'.
As for creative bracketery to tilt the radiator, that would be protest bait.
I would have been happier with a rule that allowed smaller physical dimension but required same capacity, there by opening a path for intake routing.
