Tito Sar
Car#: 562
Post by Tito Sar »
Currently, I am in STX. My Honda Civic EX is a NA 1.8L and has an aftermarket suspension (Camber, shocks/struts, sway, etc.), intake, and exhaust. Also, it is sitting on 17X8 235/40 RE-01R. What other options do I have besides STX? I have done research but I am not completely sure. Thanks!
Michael Palero
Car#: 18
Post by Michael Palero »
Tito Sar wrote:Currently, I am in STX. My Honda Civic EX is a NA 1.8L and has an aftermarket suspension (Camber, shocks/struts, sway, etc.), intake, and exhaust. Also, it is sitting on 17X8 235/40 RE-01R. What other options do I have besides STX? I have done research but I am not completely sure. Thanks!
I'm assuming you don't want to switch parts back to stock.
STX is actually a very good fit for your car with street tires.
The next closest preparation level for your car would be DSP.
San Diego has a pretty active DSP field. I'm not sure who will run DSP this year in LA.
You could also run bump in STU with your Civic.
Tito Sar
Car#: 562
Post by Tito Sar »
Thanks Michael. I have a question about CST by what does it mean by 'Times are not indexed.' and 'Run heads up with no PAX (index) applied to results.'
Michael Palero
Car#: 18
Tito Sar wrote: Thanks Michael. I have a question about CST by what does it mean by 'Times are not indexed.' and 'Run heads up with no PAX (index) applied to results.'
Heads up means the time you run will be compared directly to the times your competitors run.
If you run a 62 and your competitors run 64s, you will win.
If you beat your competitors in raw time, you win.
In an indexed class, times are multiplied by a factor called PAX.
Say driver B.S. drives a a car in an imaginary class called CeeEssPee.
CeeEssPee has a .500 PAX factor.
B.S. runs a 99sec lap.
Driver G.J. drives a car in an imaginary class called AyStock.
AyStock has a .600 PAX factor.
G.J. runs a 82.6sec lap.
G.J. and B.S. are running in an indexed class called PAX class.
If they were racing heads up, G.J. would win with a 82.6sec lap.
But since they are racing in an indexed class, we will multiply their times by the PAX factor for results.
B.S. time X CeeEssPee Factor:
99seconds x .500 = 49.500seconds
G.J. time X AyStock Factor:
82.6 x .600 = 49.56seconds
B.S. in this case will win with a 49.500second indexed time.
Last edited by Michael Palero on Tue Feb 03, 2009 9:40 am, edited 1 time in total.
Heads up with no index means you will be racing against all the other cars in the class for best time.
Which in CST means you would run against the Exige, the Elise, the Noble, and any other dudes with enough money to buy a nice car, but not enough to keep it in proper tires. }:)
Basically CST is run what ya brung as long as the tires are +140 treadwear rated.
If I were you I'd stick with STX, try to catch up to Aaron's Mini for now.
Jeff Nucum
Help classing 2000 miata
Post by Jeff Nucum »
2000 base miata
Tein Flex coilovers
Harddog Hardcore Hardtop rollbar
Hardtop
either
15x7 team dynamics with kumho r comps
or
16x7 team dynamics with kumho HRII all seasons
not sure where i fall in since i have coilovers
Re: Help classing 2000 miata
Jeff Nucum wrote:2000 base miata
Tein Flex coilovers
Hardtop
either
or
With the R-comps, your best fit is CSP. With the +140 treadwear tires, you could run our local SST.
SST already has an NC and an NB doing battle.
Jason Dang
Post by Jason Dang »
1991 toyota mr2 turbo
*****Engine*****
-Apexi GT spec exhaust (3inch)
-HKS SQV BOV
*****Suspension*****
-TRD front brace
-TRD rear brace
-Tein Flex coilover
-Eibach rear camber kit
-Suspension Tech. front & rear swaybar
*****Brake*****
-4x Powerslot Rotors
-porterfield R4S pads
-goodridge brake lines
*****Exterior*****
-17x8 +35(front)
-Falken RT-615 215/40/17
-17x9 +35(rear)
-Falken RT-615 255/40/17
Please class me
Giovanni Jaramillo
Post by Giovanni Jaramillo »
Jason Dang wrote:1991 toyota mr2 turbo
Please class me
Go to SCCA's Solo section with many PDF files for rules, classing and other FAQs
http://www.scca.org/contentpage.aspx?content=61 But based on reading the ST (Street Touring rules):
http://cms.scca.com/documents/Solo%20Ru ... cturer.pdf your car is EXCLUDED.
But in Stock form it's E-Stock or we have a local classes called SK1 (SS, AS, BS, FS) or SK2 (CS, DS, ES, GS). But with your mods, I'm sure others will chime in as to what your proper class. This off the top of my head and doing a quick check of the rules.
Locally you are eligible for CST. Its not a national class. But is a fun group locally and your car would be probably be pretty good there.
Everything else would be BRUTAL.
SSM depending on the configuration of those strut bars and any interior removal.
Jason Dang
so if i sign up for a cscc championship event i would register under CST class?
Jason Dang wrote:so if i sign up for a cscc championship event i would register under CST class?
Yup.
Jason Dang
how do i register for the X run when i register online?
Jason Dang
nm...i figure that part out. When i was registering i saw the option novice and time only... should i be in the novice class, since this is my first championship event and second time autocross?
Jason Dang wrote:nm...i figure that part out. When i was registering i saw the option novice and time only... should i be in the novice class, since this is my first championship event and second time autocross?
Yup.
You can sign up for Novice (with an index class of CST) which is a local class than you can compete in all year for a year end trophy, based on your best 6 events. Time Only is just that, for time only with no trophies or points for year end.
Jason Dang
as for the weekend membership fee i just need to show up to the event and buy it there right?
Giovanni Jaramillo
Jason Dang wrote:as for the weekend membership fee i just need to show up to the event and buy it there right?
Correct. Gayle Jardine is in charge of SCCA temporary weekend memberships.
Leonard Cachola
Novice Coordinator
Car#: 82
Post by Leonard Cachola »
Actually, the MR2 turbo is in B-Stock - the normally aspirated MR2 is in E-stock, while the Spyder and Supercharged version are in C-stock, but the car in question is modded...
Jeff Nucum
SST is based on STU? so i can have up to a 8.0 inch width wheel?
Giovanni Jaramillo
Jeff Nucum wrote:SST is based on STU? so i can have up to a 8.0 inch width wheel?
14.4 WHEELS
A. Any wheels are allowed with widths up to the following:
ST, STS – 7.5"
STX (AWD) – 8"
STX (2WD) – 9"
STU - unlimited
Jeff Nucum
So SST is unlimited width?
Yes unlimited. All the rules for SST are based on STU the only difference is that it lets in the otherwise excluded two seaters.
SST is a local class. There is some interest in exploring this as a national class, but it usually takes a lot of time and effort for that to happen.
CST is a local barely any rooms, bring what you could plausibly drive on the street with normal street safety equipment and a 140 treadwear DOT tire of any size on any rim.
No chance that ever becomes a national class.
Giovanni Jaramillo
Jeff Nucum wrote:So SST is unlimited width?
That is correct. Basically SST is for (Jay W's quote):
For cars not allowed in STU. 2 seaters, higher displacement FI and those on the exclusion list.
Giovanni Jaramillo
Sorry Steve....guess you beat me to the "Submit" button. :D
