Trash talk from El toro...and more
Giovanni Jaramillo
Re: El Toro Results
Post by Giovanni Jaramillo »
Steve Ekstrand wrote:After the oil "crash" I have no money....
Yeah what's up with this market anyways! Oil goes down and you'd think market would do the opposite
Steve Ekstrand wrote:But the idiot behind the wheel does matter more than the vehicle.
I agree on that principle. But remember.....if I'm the longshot wouldn't you want bigger returns?? :) Come on, I'm like the DIA options on the market.
Re: El Toro Results
I'm already rich... I like sure things. :mrgreen:
Re: El Toro Results
Giovanni Jaramillo wrote:
Marshall Grice wrote:giving you a near perfect RWD weight distribution of 45/55 f/r.
Perfect = BMW (49.5/50.1) front/rear :)
I'm sure Marshall can lend you some vehicle dynamics books, unless you wanna keep believing BMW's marketing.. :lol: ..then again maybe they have you sold on that applying brakes to teh rear wheels is just as good as a limited slip ;)
P.S. I like will's response a lot.
Giovanni Jaramillo
Re: El Toro Results
Steve Ekstrand wrote:I'm already rich... I like sure things. :mrgreen:
The only sure things in life are:
1. Death
2. Taxes
3. Schenker RED lighting at a ProSolo (usually the left side)!!! :mrgreen:
Giovanni Jaramillo
Re: El Toro Results
Aaron Goldsmith wrote:P.S. I like will's response a lot.
I don't! Smart-a** :)
Re: El Toro Results
Marshall Grice wrote:ok i figured it out...
Bills car needs a 6speed trans that he drives all the time in 3rd gear with the standard 6sp final drive ratio to give a top speed of 79mph at 7500rpm. combine that with a 1.8l turbo motor with a turbo sized to spool at ~3000rpm so that you're in boost by 30mph in 3rd with 2nd available if you're really going slow. with the stock 9.5:1 pistons and c16 that shouldn't be too much to ask. with out running any numbers i'd guess a gt28 or 16g should get 'er done, to the tune of roughly 280-300whp. the car would have to weigh 2240 so you'd have to add 200 or so lbs in the trunk giving you a near perfect RWD weight distribution of 45/55 f/r. Slap a good sized wing on the back for good measure.....
hey how much do miata's cost? :heyes:
I have one sitting in my driveway. It started out kinda cheap...
Re: El Toro Results
wanna drop $25k on it? i'll pitch in a couple thou...
$M ^2 does sound like fun. I'm just not rich enough.
Re: El Toro Results
Bob Beamesderfer wrote:I do think that a 13b powered Miata could be very fast and competitive in SM2, with the only drawback being not enough tire compared with the McKee-mobile.
i'd say the main drawback of a 13b in a miata for SM2 would be that it doesn't meet the rules. ;)
word on the street is you have to clearance the front subframe to fit the 13b which is a no-no in SM. would be sweet though.
I don't think O'Blenes had to do that with the setup he's got. Dry sump is necessary.
Re: El Toro Results
interesting. I thought he was the person i was talking to that told me it wasn't SM2 legal. I'm certainly no expert though.
Re: El Toro Results?
Bill Schenker wrote:
Giovanni Jaramillo wrote: And picking up girls, while smoking MIATAS on fwy on/off-ramps, cloverleafs, etc...etc...etc...
You wouldn't have a chance, TM(tm) against my car on an off/on ramp/cloverleaf. Period.
KEEP smokin' whatever it is your smokin because when you wakeup and realize all you see is my tailpipes merging onto the fwy from the on-ramp you'll realize that "RESISTANCE IS FUTILE".
Besides...heading into a cloverleaf I'd outbrake you, you'd somewhat catchup then coming out of the cloverleaf, I'd squeeze the throttle and you'd wobble in my turbulence.
Go back to "catching predators" on camera for NBC :)
You're daft. Your M3 has neither the light weight nor the lateral grip carry speed into the corner. Brake all you want because you have to. Bill's car won't need to. :lol: :lol: :lol:
So, what does your M3 weigh and how much horsepower does it really have?
Re: El Toro Results
That could very well be; my questions to him were based on building an XP car. Back to the turbo. Wonder if the new MZ motor can be fit without cutting?
Re: El Toro Results
I think i'm gunna have to re-assign the mod rights for this forum soon, haha. Events is the new off topic.
Re: El Toro Results
Anything over 250 rwhp will need a stouter transmission and diff, either from an FD or the new Quaiffe internals and the 1,000hp diff that Flyin' Miata $ell$. It's only money, right? The advantage to the latter solution is that you keep the power plant frame, which links the transmission and differential housings, reducing momentary twist.
Re: El Toro Results
Aaron Goldsmith wrote:I think i'm gunna have to re-assign the mod rights for this forum soon, haha. Events is the new off topic.
Like that would do any good. :lol: :lol: :lol:
Bill Schenker wrote:Sure feels good, being back in the saddle, slammin' the Monkey and putting him in his place... :computer:
http://www.youtube.com/watch?v=_oaSZxd9jOY
Re: El Toro Results
aren't they all eventually off topic (except for the for sale...i rule with an iron fist)
Re: El Toro Results
need an forum mod for off-topic, to delete posts that are on topic?
Giovanni Jaramillo
Bob Beamesderfer wrote:So, what does your M3 weigh and how much horsepower does it really have?
I agree on the weight, but HP? 333HP
If your car weighs the typical 3,450 pounds, you're pushing 12.8 pounds per lb-ft of torque, while Bill is pushing 14.3 pounds per lb-ft. You can win in straight line, but the car's skid pad rating is .98g. A Miata with the milder and much less sophisticated Racing Beat suspension pulls 1g. Bill's car certainly pulls more than 1g. In the corners, you lose.
Robert Puertas
Car#: 44
Re: El Toro Results
Post by Robert Puertas »
Forget the 13b.
The Miata solution for SM2 is Bill's car with the 2.3 duratec as used in the new Formula Atlantics.
300 hp na.
Of course the power band is probably 8000 rpm to 11000 rpm so you'd want a sequential gearbox...
Re: El Toro Results
We were talking to Mark Huffman at El Toro about those Duratec monsters. Fun fun fun!!!
Giovanni Jaramillo
We're talking bone-stock to bone-stock not Bill's monster CSP car.
Re: El Toro Results
Bone stock civic with me driving... 2500lbs
85 ft lbs of torque.
power to weight of 29.4
Can I play? I'm sure on OEM rubber the car has skidpad holding grip above .7 or so....
Re: El Toro Results
My truck and trailer...
21000lbs
650ftlbs of torque
P-W of 32.3
My truck empty....
7000lbs
650ftlbs of torque
p-w of 10.77
My tow vehicle has 10.77
My race car 23.5
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
Bill Schenker
Car#: 14
Post by Bill Schenker »
Giovanni Jaramillo wrote: We're talking bone-stock to bone-stock not Bill's monster CSP car.
No we're not. I quote: "KEEP smokin' whatever it is your smokin because when you wakeup and realize all you see is my tailpipes merging onto the fwy from the on-ramp you'll realize that "RESISTANCE IS FUTILE".
Besides...heading into a cloverleaf I'd outbrake you, you'd somewhat catchup then coming out of the cloverleaf, I'd squeeze the throttle and you'd wobble in my turbulence."
Since the only Miata I own is my CSP Miata, you are saying that you'd outbrake, out run, blah, blah, blah my Miata.
What are you smoking? :o
