CST for 140 Treadware (any mods on street tires) or higher or DSP if you want to run R-comps.m.meyer wrote:I have a 2011 Mazda Mazdaspeed3 it has the following modifications:
Rear Sway Bar
Upgraded rear polyurethane engine mount
Shifter cable mount relocater plate
Lighter shifter weight
Second Cat and resonator delete to stock muffler
Open for options on tires
- Anthony P.
New to the forum... new to the sport...
I don't know what class my car will fall in to.. hopefully someone can help...
2005 350z. mods are:
intake
cat-back exhaust
coilovers
camber arms (front and rear)
upgraded sway bar (front and rear)
18x9.5 wheels with 265/35 Federal 595 RSR
stillen front splitter
intake
cat-back exhaust
coilovers
- Adam Tarnoff
- Car#: 49
crazyjeys wrote:New to the forum... new to the sport...
intake
cat-back exhaust
coilovers
Sounds like STU. I wouldn't worry too much about classification if this is your first run with us. Sign up for Novice, then select the STU modifier. That way you'll be classed against other novices. Also on this forum, since a lot of us know each other, it is a good idea to actually use your real name for the forum. It makes it easier to communicate.
#49 STX Mazda RX-8
Thank you for that info Adam. I will just go ahead and sign up as novice and take it from there then.Adam Tarnoff wrote:crazyjeys wrote:New to the forum... new to the sport...
intake
cat-back exhaust
coilovers
PS: is it just me or there's something wrong here, i'm trying to change my username and followed the sticky but I don's seem to see the edit your profile icon on www.solo2.com homepage. hope you can help.
Don't hold me to it, but I think I remember someone saying it's best just to start over with a new registration.
Mihail Milkov
What class should the 2015 Camaro Z28 run in? Furthermore, as it comes stock with Pirelli P Zero Trofeo R tires with a treadwear of 60, is it legal for the street tire classes?
Mihail
Mihail
- Adam Tarnoff
- Car#: 49
Mihail Milkov wrote:What class should the 2015 Camaro Z28 run in? Furthermore, as it comes stock with Pirelli P Zero Trofeo R tires with a treadwear of 60, is it legal for the street tire classes?
Mihail
AS
#49 STX Mazda RX-8
- Jeff Stuart
Regarding your question about <140/200TW tires that are OE, here is 13.3.C.1 of the rules:
1. Any tire which is OE on a car eligible for Street Category may be used on that car in Regional Solo® events. OE tires must meet all requirements of Section 13.3 to be eligible for National Solo® events.
So essentially: the 60TW tires are fair game locally (if they were OE), but not at Tours/Pros/Nationals.
- Guy Walker
- Car#: 84
@AdamAdam Tarnoff wrote:Mihail Milkov wrote:What class should the 2015 Camaro Z28 run in? Furthermore, as it comes stock with Pirelli P Zero Trofeo R tires with a treadwear of 60, is it legal for the street tire classes?
Mihail
AS
Seeing that the Ford Mustang Boss 302 Laguna Seca and Porsche 911 GT3 are in SS (and the Nissan GT-R isn't even Stock eligible), I would think the similar if not better performing Z-28 would NOT be classed lower than those cars. I would have guessed SS or not even Stock eligible.
I only saw the 2014 ZL1 listed in AS (page 166). Has the new Z-28 been added to AS?
Guy Walker
#84 370Z
#84 370Z
- Adam Tarnoff
- Car#: 49
Street
#12802 Camaro Classing Proposal
Per the SAC, the following new listing, effective immediately upon publication, is added for the new Camaro 1LE in A
Street.
Chevrolet
Camaro Z28 (2014)
That's the only place I could find any info on classing that car.
Street.
Chevrolet
Camaro Z28 (2014)
#49 STX Mazda RX-8
- Jeff Stuart
Adam Tarnoff wrote:Street
Street.
Chevrolet
Camaro Z28 (2014)
That was in the March FasTrack, then in the May FasTrack:
#13616 Camaro Clarification
The response to item #12802 in the March Fastrack should have read as follows:
Per the SAC, the following new listing, effective immediately upon publication, is added for the new Camaro Z28
in A Street:
Chevrolet
Camaro Z28 (2014)
What class for 2005 Bentley Continental GT? I thought FStreet but then realized its a W12 twin turbo. But it's also 5,000 lbs. 0-60 in 4.5.
SCNAX Cup 2014. Team Poverty?
A Bentley is just a Volkswagon really and most VDubs go to H-Street. So, I'm voting H-Street.
I like your thinking, but you made a small mistake. ...the Bentley isn't most "VDubs" as you put it. Most VR6's are in GS. Since the car has basically 2 VR6's in it....Steve Ekstrand wrote:A Bentley is just a Volkswagon really and most VDubs go to H-Street. So, I'm voting H-Street.
So with your thought path... It would have a PAX of: 1.612 [(̶.̶0̶8̶0̶6̶x̶2̶)̶(.806x2), double the GS PAX]
Works for me!
edit to fix typo in pax
Well.... You did add a decimal place there, but I don't think .161 would be fair.
I'm thinking sequentially .806 and again apply the .806 for an effective pax of .650.
Tadd is concerned about tire wear, so we're just going to rent the Ferrari 458 Italia.
Ok, fixed it.
The Aston Martin DBS, and Bentely Flying Spur are 1/2 the price. The Tesla S is 1/4 the price.Steve Ekstrand wrote:Tadd is concerned about tire wear, so we're just going to rent the Ferrari 458 Italia.
Rent the Tesla if he won't drive his.
samuelbrownfield
Howdy, ran my first autocross with cal club at the last el toro event, and have some classing questions going forward (second in ES to Leonard within S2 class, not bad for first SCCA
I have a 1995 miata m package (currently 'Merlot' with age color, soon to be primer grey), with koni sports, hankook rs3s, and the rest is stock.
It does have DOT stainless brake lines, does this definitely put me out of ES? Do I need to revert to rubber to be ES?
Also on the spring perches on the konis, I have the springs at the lowest perch setting, is this ES legal (was at mid setting for last autoX)?
I know at regional no one is going to bust my... chops, for this, but I want to be properly classed, even though I have no chance for an S2 win, I want to know where I am in the ES cars.
Thanks for the help, looking forward to running again!
Sam
Sam
Samuel Brownfield
1995 'Merlot' Miata, Koni Sports, RS3s, Sweet Baja Seat Covers
- Leonard Cachola
- Novice Coordinator
- Car#: 82
Per the SCCA rule book for the Street Category:
13.6 BRAKES
A. The make and material of brake linings may be changed.
B. Substitution of clutch and brake hydraulic lines with solid metal or braided metal is allowed on all cars manufactured before model year 1992.
C. Alternate brake bleeder fittings (e.g., Speedbleeders®) are permitted. They may serve no other purpose.
From what I've been able to find on Miata.net, the highest perch is the one you need to set at to be Street class legal for your car. If someone wants to chime in with better info, please do.
https://www.google.com/search?q=koni+sh ... channel=sb
13.6 BRAKES
samuelbrownfield
Thanks Leonard, I was worried about that with the Konis. What do you run on your car?
I guess I'll be switching back to rubber hoses soon.
Samuel Brownfield
- Leonard Cachola
- Car#: 82
I have a set of Koni sports on the car. The ones for the NB didn't have adjustable perches, so much easier to figure out where to set it on my end.samuelbrownfield wrote:Thanks Leonard, I was worried about that with the Konis. What do you run on your car?
mhanson0331
I had some questions about my car and where it needs to be. It is a 2013 boss 302 and I have some things done to it. Here are the mods....
Bigger throttle body (90mm)
Cold air intake
Carbon hood with bigger vents
CDC top grille
Roush Lower grille delete
Stock shelby spoiler
MGW shifter
Steel braided clutch hose
Race pads and rotors
Wider wheels and tires
Also has full suspension on it with a rear end breather.
all the suspension is bolt on and nothing has been cut or moved.
The car looks stock with all interior in it (rear seats stay in).
Also about to put full exhaust on it and not run any cats and will have a new tune.
I wanted to know what tire choices could I get?
Are there any noise restrictions?
Any tuning restrictions?
Is there a specific insurance you need?
The one last question is I am thinking about some headwork and if i choose to do that, then what class would i have to be in?
All help would be greatly appreciated!!!!!!
Cold air intake
CDC top grille
MGW shifter
- Brian Kelly
- Car#: 215
Sounds like a good CAM or CST car. For those classes, no tuning restrictions, and any tire of 200tw or greater is allowed. I would look into the Hankook RS3, BFG Rival, or Dunlop Z2 depending on which ones have the sizes you need.mhanson0331 wrote:I had some questions about my car and where it needs to be. It is a 2013 boss 302 and I have some things done to it. Here are the mods....
Cold air intake
CDC top grille
MGW shifter
2000 Miata LS
#215 ES
#215 ES
Thinking of trying this out, is there a class for my car?
1965 Mini Cooper I inherited from my dad. Not stock, but really don't know the extent of the modifications as it was formally used as a rally car in the U.K. Still runs the stock size 10" wheels with Yokohama D.O.T. tires. Licensed and legal for street use.
This makes it pretty much impossible to class... (accurately)Firstturn wrote:Not stock, but really don't know the extent of the modifications...
That doesn't mean it can't run...
Here are two classes you can run in:
CSM (run what you brung on DOT tires, aka: non-slicks race tires)
CST (run what you brung on street tires)
Beyond that it becomes tricky. I'm assuming it was brought to the States as a non-US model under the grey import over 25yr old rule. This would exclude you from any Stock or ST class, even if the car was "stock".
From there you would need to know your modifications to go digging into the three levels of prep: Street Prepared (SP), Modified (M) and Prepared (P), and the respective class for which the Mini is listed in. Some levels of prep (ST) have class wide preparation rules, the other two can and do have class specific levels of prep, in addition to the general class rules.
Once you do solve your specific class... you could run in that class... or we have an indexed class called "Historic" where you could run against other older vehicles, so you don't have to run against class specific modern equipment.
