Page 4 of 48
Posted: Sat Feb 28, 2009 1:06 pm
by Mark Blucker
I'm new to solo 2 and need help classifying my street legal dune buggy. Originally a 50's beetle, it was cut in half and shortened 13" in 1963 and re-registered as Assembled (kit car?). Fiberglass body, 6 point cage, 5 point belts. 2 seater
It has a 1776cc VW engine with a counter weighted crank,110 cam, big valve ported heads and dual Weber 40's.
It also has 9" wide rear wheels
I hope to run it at El Toro in late March.
Any help would be appreciated.
Mark B
Posted: Sun Mar 01, 2009 6:28 pm
by Aaron Goldsmith
Do you mean the Pro Solo in March?
Well.. according to Marshall dune buggies are specifically allowed in B Mod..
Posted: Mon Mar 02, 2009 11:45 am
by Mark Blucker
Gene- Thanks for the reply. B Modified
And yes, I was referring to the the pro solo 3-28 and 3-29 at El Toro.
Mark
Posted: Mon Mar 02, 2009 12:57 pm
by Aaron Goldsmith
Mark Blucker wrote:Gene- Thanks for the reply. B Modified
Mark
It's a National level event so tech and classing is going to be strict at that one, so you'll need to make sure you read the rule book first and are in compliance with the Bmod rules.
http://cms.scca.com/documents/Solo_Rule ... _Rules.pdf" onclick="window.open(this.href);return false;
Since it's a pro solo, you'll also want to read the supplemental Pro Solo rules.
http://cms.scca.com/documents/Solo%20Ru ... oRules.pdf" onclick="window.open(this.href);return false;
You also need a Rule Book (which they sell there at tech) and to be a full SCCA member to compete at National events like the SD National Tour and El Toro Pro Solo.
Newbie Classing Question (Trihawk!)
Posted: Tue Mar 03, 2009 1:40 pm
by John Brusky
Hello,
I have a 1985 Trihawk (similar to a Morgan 3-wheeler). My father did SCCA autocross events in the early 1980's with this vehicle. It is unmodified. Stats: 1350 lbs, 1299 cc Citroen GSA engine (naturally aspirated), 64 bhp, street tires. It has seats, seatbelts, a-pillar and rollbar. I don't think anyone has raced one in a long time. I appreciate your help classing this and any advice on how to get started (autocross). I live in Orange County, Ca. Thank you very much!
John
Photo of a Trihawk:
http://pages.zoom.co.uk/elvis/trihawk.jpg
Posted: Tue Mar 03, 2009 1:59 pm
by Marshall Grice
3 wheels vehicles are not legal in any class.
Re: Newbie Classing Question (Trihawk!)
Posted: Tue Mar 03, 2009 2:00 pm
by Aaron Goldsmith
John Brusky wrote:Hello,
John
Photo of a Trihawk:
CST or CSM the run what you brung classes is about it i'd think.
Posted: Thu Mar 05, 2009 8:37 pm
by John Brusky
Thanks for the quick reply,
Should I just show up and try for CSM, or is there somebody I should clear it with first?
John
Posted: Sat Mar 07, 2009 2:43 am
by Jeff Nucum
sample run groups for prosolo:
Group 1 FJA, FJB, HS, GS, FS, ES, STS2
Group 2 L2, DS, BI-1
Group 3 CS, BS, AS
Group 4 SS, STS
Group 5 STX, FSP, ESP, DSP
Group 6 CSP, BSP, L1, BI-2
Group 7 ASP, SM, SM2, Prepared Index Class (XP and CP thru GP)
Group 8 STU, Modified (AM thru FM), F125
i noticed SST wasn't there since i'm guessing its a local class. what would i place into for prosolo?
Posted: Sat Mar 07, 2009 4:45 am
No SST, CST, or CSM at the tours or Pros.
Jeff, you'd be CSP.
Posted: Sat Mar 07, 2009 8:59 am
by Jason Isley BS RX8
John Brusky wrote:Thanks for the quick reply,
John
Nothing to clear, as posted before, you can not run it in any class at an SCCA event. There is no class that gives an allowance for less than four wheels.
12.1 AUTOMOBILE (CAR)
A self-propelled land vehicle, running on at least four wheels, not in
a line, which must be in contact with the ground when at rest.
Posted: Sat Mar 07, 2009 9:30 am
by Will Kalman
Jason Isley BS RX8 wrote:Nothing to clear, as posted before, you can not run it in any class at an SCCA event. There is no class that gives an allowance for less than four wheels.
Why are you guy misleading him about classing when he's asking about eligibility? Otherwise, he may bring it out for a practice, where there are no classes. Or try to run Time Only on a Sunday.
John, sorry to inform you that the SCCA rules do not allow vehicles with less than four wheels to participate.
Posted: Sat Mar 07, 2009 10:30 am
Will Kalman wrote:Why are you guy misleading him about classing when he's asking about eligibility? Otherwise, he may bring it out for a practice, where there are no classes. Or try to run Time Only on a Sunday.
Will, he asked what class it goes in.
What makes you think a practice or time onlys are a free for all and SCCA rules do not apply? Do you not have a SSS on hand for those events? I am not sure what kind of silly point you are trying to make, when it is clear you get the fact that the car can not run at any SCCA event.
Posted: Sat Mar 07, 2009 10:31 am
by Robert Puertas
John, your dad autocrossed his Trihawk locally before we switched to SCCA rules.
I remember watching it run at Cypress college. I also remember visiting the Trihawk shop/showroom down in Dana Point.
Come on out to an event! It would be fun to see it, and I'm sure we could find someone to give you a ride around the course in their car.
Posted: Sat Mar 07, 2009 4:50 pm
Jason Isley BS RX8 wrote:Will Kalman wrote:Why are you guy misleading him about classing when he's asking about eligibility? Otherwise, he may bring it out for a practice, where there are no classes. Or try to run Time Only on a Sunday.
Jason, you misread what Will wrote. Re-read it. He clearly says the vehicle isn't allowed to run. As a writer and editor, you need to focus.
Posted: Sat Mar 07, 2009 8:13 pm
by Vincent Chang
Anyone knows where a stock Smart car might be classed? HS?
Posted: Sat Mar 07, 2009 9:28 pm
Vincent Chang wrote:Anyone knows where a stock Smart car might be classed? HS?
None, the SSF factor (pg 253-254 of the Solo rules) keeps it out. There may have even been a past FasTrack on that one.
Posted: Sat Mar 07, 2009 9:57 pm
Jason Isley BS RX8 wrote:Vincent Chang wrote:Anyone knows where a stock Smart car might be classed? HS?
In stock class....
Re: Post Car Classing Help Questions Here! (Trihawk)
Posted: Sun Mar 08, 2009 10:01 pm
by John Brusky
Thanks for the info. Sorry to hear that I can't participate. I remember riding shotgun with my father at local autocross events and at a large event at Lone Pine. Trihawk hired a professional driver (Lance Stewart) who I understand posted some pretty good times in the Trihawk. By today's standards it is pretty slow and I imagine not very competitive. I was hoping to challenge myself and my vehicle in a safe environment (I am not so much interested in competing against others yet). If anyone has any ideas I would love to hear your suggestions (practice events, non-timed events, etc?) I am not familiar with other options I might be allowed to participate in, SCCA or otherwise. Please don't tell me to buy a four-wheeler, that's not the point
Sincerely,
John
Posted: Sun Mar 08, 2009 11:25 pm
John-
There are some marquee clubs and also speedventures that occasionally put on events. They are not as regular or as structured as we are. I can't say they will let you run, but you should try contacting them. That would be your best shot. They have different insurance and sanctions and almost always fewer rules than our Taliban style competition.
Posted: Tue Mar 10, 2009 5:21 pm
by John Brusky
Thank you all very much. It would be great if SCCA had a non-competitive class with relaxed rules for oddballs like me. Morgan 3-wheelers have a 70+ year history of racing. It is a shame to exclude this class of vehicle. I have posted a query to NASA-x. I have never had a ticket, but it is only a matter of time unless I find some place to knock over some cones! ;) I won't check the newsgroup much longer, but if anyone has any other suggestions I would appreciate an email anytime in the future. Thanks again.
Sincerely,
John
Posted: Tue Mar 10, 2009 8:39 pm
by Aaron Goldsmith
John Brusky wrote:Thank you all very much. It would be great if SCCA had a non-competitive class with relaxed rules for oddballs like me. Morgan 3-wheelers have a 70+ year history of racing. It is a shame to exclude this class of vehicle. I have posted a query to NASA-x. I have never had a ticket, but it is only a matter of time unless I find some place to knock over some cones! ;) I won't check the newsgroup much longer, but if anyone has any other suggestions I would appreciate an email anytime in the future. Thanks again.
Sincerely,
John
For any future folks wondering about this, we have a class with pretty much no prep rules (CSM). The insurance carriers for the SCCA have a few that supersede any classing though.
Posted: Thu Mar 19, 2009 11:21 pm
by Kirk Blair
Hi,
I have a lotus 7 replica type.... it has a stock Honda S2000 motor (air filter housing & exhaust are not stock) and Falkin 615 tires. Not sure what other info is needed..
Posted: Fri Mar 20, 2009 5:32 am
by Michael Palero
Kirk Blair wrote:Hi,
It can run in X-Prepared (XP) or California Street Modified (CSM) on race tires, or California Street Touring (CST) on your Falken street tires.
Posted: Fri Mar 20, 2009 9:41 am
That looks like a fun car!
