What's a good tar remover?
Posted: Sun Sep 27, 2020 9:38 pm
by Stephen Yeoh
What does everyone like for tar remover (specifically to remove cone marks)?
Re: What's a good tar remover?
Posted: Mon Sep 28, 2020 8:31 am
by Anthony P.
Stephen Yeoh wrote: ↑Sun Sep 27, 2020 9:38 pm
I like goof off as I use it for other cleanup work, but I'm sure others will chime in.
Posted: Mon Sep 28, 2020 4:11 pm
by Brian Howlett
Mothers "R3" is made just for removing tar and rubber marks and it "WORKS"
You also might try "NOT HITTING PYLONS" that works wonders also.
Brian
Posted: Tue Sep 29, 2020 1:29 pm
by Tom Layton
Turtle Wax label and sticker remover takes cone marks right off without any effort, way better than anything else I've tried. I also have a set of plastic razor blades to help with really built up marks.
https://www.amazon.com/Turtle-Wax-T-529 ... 201&sr=8-1
R3 race rubber remover didn't work at all for me. Goof off didn't work as well either.
Posted: Wed Sep 30, 2020 7:59 am
by Anthony P.
Tom Layton wrote: ↑Tue Sep 29, 2020 1:29 pm
Based off the msds this makes sense, ill have to try the tutle wax.
3.2 Mixture (Turtle Wax)
Component CAS Number Concentration (wt%)
Petroleum Distillites (Hydrotreated Light) 64742-47-8 15-40%
Diethylene Glycol Monobutyl Ether 112-34-5 10-30%
Propane 74-98-6 10-30%
Acetone 67-64-1 7-13%
D-Limonene 5989-27-5 3-7%
Undeceth-3 34398-01-1 1-5%
vs
Hazardous Components (Goof Off)
3. COMPOSITION/INFORMATION ON INGREDIENTS
Benzenemethanol {Benzyl alcohol} 5.0 -10.0 %
Oleic acid potassium salt 5.0 -10.0 %
Ethanol, 2-Butoxy- {Ethylene glycol n-butyl ether,
(a glycol ether)} 1.0 -5.0 %
112-34-5 Diethylene glycol monobutyl ether {2-(2-Butoxyethoxy)ethanol {(a glycol ether)} 1.0 -5.0 %
770-35-4 Propylene glycol phenyl ether {(not 313)} 1.0 -5.0 %
Posted: Sun Oct 18, 2020 11:30 am
by Sean Fenstermacher
Turtle Wax stuff works great! I been using it for years
