FS: 1991 CRX HF BAR'd for B16 motor
Posted: Thu Dec 04, 2008 2:36 am
1991 Honda CRX HF Clean title, BAR'd as a Del Sol Vtec by CARB (B16 motor is allowed in this specific chassis).
$3,000 Cash gets you:
-BAR'd B16 CRX HF Frame, car was (professionally) painted flat black
-ZC Style carbon fiber hood (painted along with the rest of the car)
-Wings West polyurethane RS Body kit (Mugen replica)
-Walboro fuel pump
-Autopower 4 point roll bar w/auto power harness tube installed
-Crowe 3" 5 point (includes sub belt) harness installed (driver and passenger)
-KSPORT Kontrol Pro coilovers with 16kg front / 14kg rear spring rates
-Legend brake calipers up front and Si brake calipers in the rear
-Stainless steel brake lines
-Cable B16 YS1 transmission w/KAAZ LSD (works great)
-Exedy 12 lbs. fly wheel
-Exedy street clutch
-MSD ignition
-Viper car alarm
-Battery was professionally relocated to the spare tire compartment at the rear of the car
-Battery cut off switch located at the rear passenger side of the car
You will need the following to drive this car: motor, ecu, radiator, exhaust header, cat back exhaust, catalytic convertor, wheels, and a steering wheel. The interior is mostly striped clean except for the dash board. This car is not beat up at all, and would make a great car to participate at an Autocross event, you can drive there without fear of having your car impounded also
I am also selling some spare parts separately from the car. If you purchase the car you can purchase the spare parts for 25% off the price listed:
-AEM EMS model #1040 w/CD and cable : $1200
-AEM short ram intake : $30
-Carbon Fiber Bucket seats w/Recaro sliders, WEDGE brackets ready to install : $700 for the pair
-Cusco front strut bar & Cusco rear strut bar : $200 for both
-Project Kics Magnetic Drain plug for engine and transmission : $30
-spare B16 Motor : $750
-spare B16 Transmission (needs rebuild) : $100
-HONDA JAPAN INTEGRA TYPE R (98 SPEC) HEADER: 4 INTO 1 w/heat shields and gaskets : $400
-4 Konig Heliums 15x6.5 4x100 40mm offset Flat Black mounted and balanced with 205/50/15 Nitto NT01 (used) : $560/set
-4 Konig Heliums 15x6.5 4x100 40mm offset Flat Black mounted and balanced with 205/50/15 Nitto NT01 (NEW) : $680/set
-Toda Spec B camshafts w/Toda cam gears (Less than 1,000 miles of use) : $500
CONTACT
Via solo2.com message board, private message or email me : b16crx4sale@yahoo.com (if you email please put, "1991 CRX solo2.com" in the subject line so I know it isn't spam)
PHOTOS
-Walboro fuel pump
-MSD ignition
-Viper car alarm
CONTACT
PHOTOS
