New T25/ T28 Turbo for sale on eBay $99 No reserve
Posted: Wed Feb 18, 2009 5:20 pm
Here is the Link:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123" onclick="window.open(this.href);return false;
I got this turbo from eBay with the intention to use it on my Mazda Miata.
The turbo is very similar to the $1,000 Garrett GT2560 but the compressor side is smaller. I guess that can give you faster spool time but less top end HP.
One of my goals was to make at least 300whp so I eventually decided to go with an original Garrett unit.
The turbo was not used at all and it's in perfect condition - I does fit with the Begi and FM manifold but as I said the compressor side is a bit smaller.
This should be an ideal turbo if you are shooting for 220-250 whp.
Here are the specs:
Turbine Turbocharger
Oil cooled and water cooled
Compressor Specs :
1.70" Compressor Inlet
1.685" or 42.81mm inducer
2.362" or 60.00mm Major
Compressor .80 A.R.
M24 T2 Compressor Housing
Turbine Specs :
1.850" Exducer
Turbine .86 A.R.
2.090" or 53.10mm Major
1.820" or 46.25mm Minor
Exhaust Outlet Flange with 5 bolt design
Internal wastegate set around 7psi.
For 1.6L to 2.0L engine up to 100-275HP
Here are the specs:
Compressor Specs :
Compressor .80 A.R.
Turbine Specs :
1.850" Exducer
Turbine .86 A.R.
