Truck tires
Truck tires
The new truck has Michelin LTX A/S 265-70-17 tires on it. They are rated at 3200lbs at 80psi.
Any opinions on these tires? Michelin used to be good. But now who knows! I haven't seen many good OEM tires on Dodges.
That gives me a rear axle load cap of 6400. Should be okay with an anticipated tongue weight of under 2300lbs.
The new truck has tire pressure monitoring. And a hi/lo switch for runnning unloaded pressures versus max load.
Re: Truck tires
Great tires. Got 65,000 miles out of the set on my F350. They are a street truck tire and handle well, if you can use that term with a one ton truck. When you get tired of your stock shocks, the Bilstien HDs are a good upgrade.
Re: Truck tires
SRW?Steve Ekstrand wrote:The new truck has Michelin LTX A/S 265-70-17 tires on it. They are rated at 3200lbs at 80psi.
- Curt Luther
- Car#: 9
Re: Truck tires
If you don't do an 8" lift and put on 40" super swampers, you're just ghey...
Re: Truck tires
SRW is Single Rear Wheel.
I know they tow better, but I couldn't deal with the 16" wider width of the Dually. I'm a city boy.
Damn, I love my new truck. I need to stop driving it, because we can't really afford to blow too far through my 800 gallon a year allotment.
Nice to know from John that the tires are decent. The OEM Goodyears on the Dakota, Durango, and Intrepid were all verging on unsafe without any loads.
Re: Truck tires
Save that card for the tow to Nationals.Steve Ekstrand wrote:SRW is Single Rear Wheel.
Re: Truck tires
As John said good for 65-75000 just put some on my truck my problem is a set a year
Re: Truck tires
Gesh Pat.
That is an INSANE amount of miles for anybody but a real trucker.
- Thomas Smith
- Car#: 158
Re: Truck tires
Doesn't the truck weigh something like 7000 pounds unloaded? I don't know what the weight distribution is but I'd bet truck + 5th wheel gets you up to well over 5000 pounds on the rear axle.Steve Ekstrand wrote: That gives me a rear axle load cap of 6400. Should be okay with an anticipated tongue weight of under 2300lbs.
Thomas Smith
Re: Truck tires
Rear curb weight is listed as 2833.
So----
2833 Truck
2300 Tongue
200 Hitch and bed cover
300 Rear addtion of passengers and cargo? I'm closer to the front axle than the rear?
5633lbs 6200lbs rating 6390lbs tires @ 80lbs psi
I'd like to have 1,000's of pounds of extra capacity. But this is my daily driver too and I'm not getting a Freightliner!
So----
2833 Truck
2300 Tongue
Re: Truck tires
Currently, I wouldn't either. They no longer offer the Cummins as an option. MB(Detroit) or Cat. Cat adds too much weight, 5-600 lb difference between the MBE4000 and the Cat engine. And the DBW/Emission tune of the MBE/DD just sucks. Nothing like decending a hill on full turbo brake and get on the throttle to power up the next grade only to hear the turbo de-spool, pause, then the engine start to pick up. Same thing when downshifting when comming to a stop.... NEVER AGAIN will I buy a DD powered truck.Steve Ekstrand wrote: But this is my daily driver too and I'm not getting a Freightliner!
- David Avard
Re: Truck tires
And with either the Megacab or Quadcab, the DRW doesn't appear to get you anything in load carrying capacity; just more weight. 10100-lb SRW vs 10500 DRW. The 12000 lbs (actually, 11.5k 2wd, 12.2k 4wd) is only with the regular cab.
