...because I'm listed as CASOC; I'm PSCC.
TIA
Team points are not correct from last event, John...
Re: Team points are not correct from last event, John...
John, I don't know about Bill's claim as he always seems to be a bit confused, especially politically.Bill Schenker wrote:...because I'm listed as CASOC; I'm PSCC.
TIA
But while your at it, August looks suspect also.
- John Fendel
- Car#: 23
The corrected team results for Sept are reposted in the original thread. I looked at the August results and could not find any errors. If you know of a specific error, let me know and I'll take another look.John, I don't know about Bill's claim as he always seems to be a bit confused, especially politically.
The August team points totals seem unusually low, almost like you left out a driver. I couldn't find the detail as to how you arrived at the totals, but just comparing the results with other months leads me to believe something is wrong.John Fendel wrote:The corrected team results for Sept are reposted in the original thread. I looked at the August results and could not find any errors. If you know of a specific error, let me know and I'll take another look.John, I don't know about Bill's claim as he always seems to be a bit confused, especially politically.
Same point calculator as for class, in the sup regs.George Schilling wrote:The August team points totals seem unusually low, almost like you left out a driver. I couldn't find the detail as to how you arrived at the totals, but just comparing the results with other months leads me to believe something is wrong.John Fendel wrote:The corrected team results for Sept are reposted in the original thread. I looked at the August results and could not find any errors. If you know of a specific error, let me know and I'll take another look.John, I don't know about Bill's claim as he always seems to be a bit confused, especially politically.
- John Fendel
- Car#: 23
The points totals are low because Katy beat the second fastest PAX driver by 2.669 seconds. That gave him only 76+ points. That also shifted everybody elses points down quite a bit. And since it was a 45 second PAX time, the difference in times was even more significant.The August team points totals seem unusually low,
Thanks for checking John. While I readily concede that Katy is one of the finest drivers in the country and regularly spanks most of us, I think you may have used results that were in error and were subsequently corrected. Keeping that in mind, could you take a third look please?John Fendel wrote:The points totals are low because Katy beat the second fastest PAX driver by 2.669 seconds. That gave him only 76+ points. That also shifted everybody elses points down quite a bit. And since it was a 45 second PAX time, the difference in times was even more significant.The August team points totals seem unusually low,
- John Fendel
- Car#: 23
You are correct George. I used the corrected results, but they were corrected again after I had posted the points totals. They are now recorrected and should be good. Thanks for keeping an eye on me.I think you may have used results that were in error and were subsequently corrected.
