Page 1 of 3
Best tire for STS (90 Civic Si)
Posted: Thu Nov 12, 2009 11:17 am
by Jonathan Lee
I've been out of the autocross scene for almost 3 years now, and I'm slowly trying to get back in. What's the most competitive tire for STS class right now? I will be using them on 15" Volk TE-37's (15x6.5, +39) wheels. Car is a 1990 Civic Si.
Any suggestions would be appreciated, thanks!
Re: Best tire for STS (90 Civic Si)
Posted: Thu Nov 12, 2009 11:24 am
by Jonathan Lugod
There is no more STS/STS2. It is now ST/STS.
There is no bad choice when deciding what tire to choose from. Out here in the west the hot shots are running the Toyo R1R and the Bridgestone RE-11. The Advan AD08 and Hankook RS-3's are good choices as well from a spectator point of view. <----I still haven't decided which one i want to try out for next year.
Bang for buck. I would say go with the Kumho XS as it is very cheap and lasts a long time. Don't go Falken Azenis as it has been a tire of the WAY past... However they will be coming out with an updated version later (Azenis 615-K)
Posted: Thu Nov 12, 2009 1:07 pm
by Jeff Wong
Whats a 1990 Civic Si look like? Do you have the 89 doors with the 91 rear trailing arms and fuel tank?
Posted: Thu Nov 12, 2009 1:14 pm
by Nicole Wong
Jeff Wong wrote:Whats a 1990 Civic Si look like?
Go look in the garage.. :lol:
Posted: Thu Nov 12, 2009 1:36 pm
by Sebastian Rios
Jeff Wong wrote:Whats a 1990 Civic Si look like? Do you have the 89 doors with the 91 rear trailing arms and fuel tank?
Wouldn't that be awesome? The best of both worlds!
Posted: Thu Nov 12, 2009 2:18 pm
by Jeff Wong
hehe, that would be awesome for you! Just claim that your rear trailing arms cracked and your gas tank is clogged!
Posted: Thu Nov 12, 2009 3:47 pm
by Jonathan Lee
The 90 and 91 should have the same fuel tanks, because I can run my car with 1/4 tank of fuel.
Are the Falken 615's that bad now? I know they've been around for years, but this $80 rebate makes it hard to pass up.
Posted: Thu Nov 12, 2009 3:51 pm
by Jonathan Lugod
its because they are getting ready to release their new 615K. I would not pull the trigger on the azenis and go with the Kumhos. That will be your bang for buck tire.
Posted: Thu Nov 12, 2009 4:14 pm
by Sebastian Rios
Jeff Wong wrote: hehe, that would be awesome for you! Just claim that your rear trailing arms cracked and your gas tank is clogged!
Gas tank has some of the undercoating scraped off from dragging cones, and a few unfortunate trailer load/unloads }:)
Are the trailing arms superceded too?
Posted: Thu Nov 12, 2009 4:22 pm
by Jason Isley BS RX8
Just something in a 225.
Posted: Thu Nov 12, 2009 4:23 pm
by Jason Flores
So the car Andy Hollis has would be ideal then..icici
Posted: Thu Nov 12, 2009 4:25 pm
by Jason Flores
Jonathan Lugod wrote:its because they are getting ready to release their new 615K. I would not pull the trigger on the azenis and go with the Kumhos. That will be your bang for buck tire.
+1 on NO Falkens.....youll thank us...i promise...
if you can wait for 2010 there may be a change in pricing of the RE-11...just call it a hunch...winkwink
Posted: Thu Nov 12, 2009 4:29 pm
by Jonathan Lee
Thanks for the tip, I will wait for 2010.
Posted: Thu Nov 12, 2009 4:32 pm
2010 ST natls tech inspection
Posted: Thu Nov 12, 2009 4:51 pm
by Jeff Wong
Jonathan,
I didn't mean to hijack your thread!
http://www.onlinetires.com/products/veh ... r+82v.html" onclick="window.open(this.href);return false;
The Toyo R1R 195/50/15 tire would be a great choice. The Kuhmo's are horrible on the first run and the braking is very touchy.
FWIW, 6 out of 9 drivers equipped with Toyo Tires trophied in ST this year at nationals and that was out of 38 drivers. The three that didn't trophy, 1 finished DFL in an RSX and the other two were DSQ'd.
5 out of 5 drivers equipped with Toyo Tires trophied in STS and the final count was 46 total entries.
Both first place winners in ST and STS were on Toyo 195/50/15 R1R.
Posted: Thu Nov 12, 2009 5:24 pm
So, 22% of Toyo drivers cheat?
Posted: Thu Nov 12, 2009 6:41 pm
by Jonathan Lugod
Jonathan,
Of course you did! lmao... Toyo needs to come out with a rebate soon. SO many decisions and im running out of rubber already! Damn El Toro
Posted: Thu Nov 12, 2009 8:20 pm
by Ken Motonishi
Is this due to the law of demand and supply? }:)
Posted: Thu Nov 12, 2009 8:39 pm
by Jonathan Lee
So I'm guessing both Steve and Ken run R1R's :D Why the 195 size and not 205?
Posted: Thu Nov 12, 2009 8:40 pm
If I recall correctly for some reason, the 205 compound isn't as sticky as the 195's ?!
Posted: Thu Nov 12, 2009 10:01 pm
by Jonathan Lugod
nothing about compound. They are all reportedly the same. The 195 just "works" on a civic. :shock:
Posted: Fri Nov 13, 2009 7:06 am
If you read the "original" SCCA Forum thread, wasn't it originally thought that there must be a compound difference, per Andy H ?
Posted: Fri Nov 13, 2009 7:52 am
I thought all the fast 195's were from the same batch made like 2 yrs ago????
Posted: Fri Nov 13, 2009 8:48 am
by Jeff Wong
Jonathan Lee wrote:So I'm guessing both Steve and Ken run R1R's :D Why the 195 size and not 205?
Majority of us used to run the 225/45/15 Toyo R1R's but like everything else in ST, some of us are lemmings and wanted to run what the national champion had or.... We go by what the interweb bible says. Forget testing, interweb surpasses that. ;)
Posted: Fri Nov 13, 2009 8:52 am
by Jason Flores
Mako Koiwai wrote:If you read the "original" SCCA Forum thread, wasn't it originally thought that there must be a compound difference, per Andy H ?
initial thoughts were compound difference but as more and more people drove them the 195 proved to give better feel and response for our car size and weight, given that the larger 225 gave more peaked grip, it usually took the driver a bit more work to make them work...
WOngs got both...let here what he has 2 say...
