				Jan 11th- New member
				Posted: Fri Dec 25, 2009 1:12 am
				by Justin Wallace
				Hey guys,
Wanted to introduce myself in here. I'm new to autoX, i've ran in one event in San Diego and once at Button Willow. I've had a lot of classroom instruction and do understand what im doing, just need to learn how to apply it. When I ran at Button I got a lot of seat time and was improving more and more as the day went on. However when I ran at Qualcomm's MX5 event I felt like I was squeezed in the track. Are the miata events a narrower course? So if you see me out there, i'd love your input.
 I was in the service, which limited my ability to get out to the track. Fortunately it gave me time to build the car up some. The car is an 07 Mustang 4.0 with  legal bolt-ons, upgraded rear end and driveshaft. Stock tires and suspension. I do own a helmet, Snell 2000 approved.
Hope to see you out there for Jan 11th's practice.
J
				Re: Jan 11th- New member
				Posted: Fri Dec 25, 2009 11:28 am
				by Craig Naylor
				Not familiar with Miata of San Diego hosting events.
If your talking about the "Miata Club day with SCAT" (one of the San Diego region SCCA host teams) earlier this year a special event was put on for non autocross type members of the SD Miata Club.  This event was to familiarize and assist them to feel more secure with their cars and handling capabilities, vs. a typical autocross event.
				Posted: Sun Dec 27, 2009 4:01 am
				by Justin Wallace
				It was with scat
http://www.sdr-scca.com/solo2/results/2 ... 05-fin.htm" onclick="window.open(this.href);return false;
				Posted: Sun Dec 27, 2009 2:33 pm
				by Daryl Slawnikowski
				Looking forward to seeing you there. It'll be our first runs w/ the 02 GT. Better make it to the Jan 9 practice or'll you'll be two day slate. LOL
				Posted: Sun Dec 27, 2009 2:46 pm
				by Michael Sullivan
				Well it will be good to see some Mustangs out there for a change. I sent in my check for the practice as well, so if I get in see you guys out there.
				Posted: Mon Dec 28, 2009 8:00 pm
				We'll have a guest from Canada on Saturday ... Brian L's C6 Z06 is wintering down here. His old Mustang:   }:)
http://www.bdlmotorsports.com/1988_saleen_mustang.htm
88 Saleen Mustang has a Torsen T2r diff and Global West traclink. Supercharger is now goneā¦. 460 hp Z347 motor now.
				Posted: Mon Jan 04, 2010 4:37 am
				by Justin Wallace
				Sweet. Glad to see some mustang fans attending. I made the practice list so i'll be there early if the drive goes well.
Even with 2 less cyl this pony will be looking at any stock pre 05 GT from the rear view
  Don't under estimate the 4.0. It's driver however can barley make it through the course, hopefully I'll get it down by the end of the day.
See you there!
				Posted: Mon Jan 04, 2010 5:20 am
				by Michael Sullivan
				I'll bet that your stock 4.0 has more HP than my stock 5.0
				Posted: Mon Jan 04, 2010 6:52 am
				Justin ... what is critical is that you let the more experienced drivers help you. Make sure you take the Novice Course Walk in the morning. Make sure you arrive early enough to register, empty your car, get through Tech and have time for at least two course walks. You can't be fast if you don't know the course. Whenever you're not running or working you should be getting rides with others. Giving rides is an accepted part of practices. And make sure you let an experienced driver drive your car to show you what the car is capable of. That will give you confidence in the car. The driver can also give you feedback on your cars set-up. Don't waste time just doing the same thing over and over again. After each run, review the run in your mind. For each run, give yourself ONE thing to work on the next run. Remember, you can't be fast if you don't use your brakes well!
Lots of good reading material:
http://www.teamblewracing.com/forum/for ... p?TID=1963
