Spring rate help, where do I start?
Posted: Wed Feb 24, 2010 10:04 am
My new car is getting close, but I could use some help. The new car is a 1975 2002, apx 2300 lb, rear wheel drive with 110 hp at the rear wheels. I wish it was more but why lie to myself.
I am moving on to coil-overs in the front with Bilstein Sport inserts, the rears will be 5" coils with Bilstein's also. The shocks and inserts are not adjustable. The sway bars are 22mm and 19mm. The front has two points of adjustment, the rear is fully adjustable.
The previous set-up was 325 front and 250 rear. If you have any ideas, please let me know.
Thank you.
David
Thank you.
David
