Points Card # Question
Ryan Hodges
Car#: 279
Post by Ryan Hodges »
I just registered for my 2010 points car for number 279. I went to the 2010 point card number section and saw that it was blank. I submitted my registration/payment and received confirmation that I was registered. When I edit "my garage" on AXWare, it says my number is reserved by someone else. I can't register for the next event at El Toro with my number. What do I do? Isn't the number mine since I paid for the points card? Can we both run the same number and be in different classes?
Ryan Hodges #279 CST Toyota Yaris Sedan
Re: Points Card # Question
Your name is in the 279 slot now, so that part's right.
Ryan Hodges wrote:I just registered for my 2010 points car for number 279. I went to the 2010 point card number section and saw that it was blank. I submitted my registration/payment and received confirmation that I was registered. When I edit "my garage" on AXWare, it says my number is reserved by someone else. I can't register for the next event at El Toro with my number. What do I do? Isn't the number mine since I paid for the points card? Can we both run the same number and be in different classes?
I see a "Jarrett Gorlick" registered at EL Toro under 279, but he's not listed in the points card numbers. He's in the novice class, so might not have the process right and used your number on accident.
Jarrett Gorlick's number has been changed to 600 and yours from 279X to 279. Note that numbers with an X are for X-Runs only, which we are not allowing to be pre-registered at the present time.
Giovanni Jaramillo
Post by Giovanni Jaramillo »
As Rick and Jay mentioned, the AXWare system is not directly tied into our points card database, but the most important thing is what it's in OUR database supercedes anything in AXWare. I replied with your confirmation for your number. Welcome to the region Ryan.
Last edited by Giovanni Jaramillo on Tue Mar 16, 2010 9:11 pm, edited 1 time in total.
Ryan Hodges
Car#: 279
Thank you all! Now I can buy numbers! :thumbup:
Lemme point you toward Jayson Woodruff - who happened to respond earlier in the thread. I use his numbers, magnetic on one car and static cling on the other.
