Chevrolet/Corvette Service Pasadena Area
Posted: Tue Mar 30, 2010 2:28 pm
The local authorized Chevy dealers/service don't get very high marks. Looking for an estimate to have the Parking Brakes serviced.
The Shop Manual and Vette Forum DIY's are fairly formidable ... especially compared to the VW's I use to do.
The nominal diameter of the p-brake drum, which is part of the rotor, is 7.50." Verify this dimension by measuring at several points. On my car, both drums were slightly smaller. The left side drum diameter was between 7.471" and 7.477." I used 7.475," the average of five measurements, as the diameter. This dimension must be .028" to .036" larger than the lined shoe diameter to provide the correct .014" to .018" drum-to-lining clearance all the way around.
To make this clearance .016," I set and locked the caliper at 7.443" (7.475" minus .032"). You may want to use a few thousands less--if I did the job again, I would try for a total clearance of about .024." Tap the shoe here and there until it looks centered on the wheel hub. Then, using the locked caliper as a "go-no go" gauge, hold it horizontally right over the centerline of the threaded spindle.
Re: Chevrolet/Corvette Service Pasadena Area
Posted: Tue Mar 30, 2010 2:30 pm
http://www.c5forum.com/cgi-bin/ultimate ... /5323.html
In a fairly short matter of time the hand brake handle now goes all the way up and barely holds the car in place on a slight grade.
Posted: Tue Mar 30, 2010 6:06 pm
by Bob Pl
Mako Koiwai wrote:http://www.c5forum.com/cgi-bin/ultimate ... /5323.html
Adjust the pb until it drags when you rotate the wheel, you will feel & hear it. Back off (a few clicks) until it's free. Done.
That will be how the tech at the dealership will do it.
