Source for carbon fiber tube
Posted: Sun Jul 25, 2010 2:39 pm
by Bill Schenker
I'm looking for thin-walled, 3" o.d., 2' long, CF tubing; anyone know of a good, cheap source for the stuff?
TIA
Bill
Re: Source for carbon fiber tube
Posted: Sun Jul 25, 2010 3:08 pm
by Mark DeShon
Depends on what your definition of 'cheap' is. I looked at McMaster Carr and they didn't have anything big enough. Here's what I found on a quick Yahoo search.
http://www.dragonplate.com/ecart/produc ... 872&cID=79" onclick="window.open(this.href);return false;
Hope that helps.
Mark D.
Posted: Sun Jul 25, 2010 4:39 pm
by Arthur Grant
Other than a C at the beginning of their names do Cheap and Carbon Fiber have anything in common? isn't Cheap Carbon Fiber an oxymoron?
Posted: Sun Jul 25, 2010 5:14 pm
by Robert Puertas
http://www.decalfx.com/carbon_2_sheets.html" onclick="window.open(this.href);return false;
Posted: Sun Jul 25, 2010 5:29 pm
by Bill Schenker
:unimpressed: :unimpressed: :mrt:
Posted: Sun Jul 25, 2010 6:37 pm
by Toby Larsson
Mike S. sent me a link for a project I had in mind, can't find it now but check with Mike. ( I think his hood prop is carbon tube!!)
Posted: Sun Jul 25, 2010 7:11 pm
Toby Larsson wrote:Mike S. sent me a link for a project I had in mind, can't find it now but check with Mike. ( I think his hood prop is carbon tube!!)
It is and it adds 25 more horsepower than the billet aluminum hood prop! :lol:
Posted: Sun Jul 25, 2010 8:16 pm
by Jayson Woodruff
Hmm, tricky. Such a short run, other materials might be minimally more weight (like grams). If you NEED carbon, how about laying it out yourself or by some fiberglass worker? Three inch, thin wall... I'd make a few spares while you're at it.
Bill Schenker wrote:I'm looking for thin-walled, 3" o.d., 2' long, CF tubing; anyone know of a good, cheap source for the stuff?
TIA
Bill
Posted: Sun Jul 25, 2010 9:14 pm
by Robert Puertas
http://www.carbonfibertubeshop.com/more%20tubing.html" onclick="window.open(this.href);return false;
or
http://www.offshorespars.com/store/spar ... ubing.html" onclick="window.open(this.href);return false;
or, 6061 aluminum:
http://www.onlinemetals.com/merchant.cf ... &top_cat=0" onclick="window.open(this.href);return false;
The thin wall aluminum is going to weigh about 50% more than equivalent CF. Figure 1.4 lbs. for 2 linear feet of 3" od vs. .9 pounds for the thin cf tube. It's also going to cost about half as much assuming both are new and not scrap. However, you might find a scrap piece of aluminum that will work at IMS in Irvine and that would be substantially cheaper...
You might also try Wright Hardware in Costa Mesa. They have all kinds of weird junk. Actually, if you've never been there before, that's probably not a good place for you to discover this close to Nationals...
Intake?
Posted: Mon Jul 26, 2010 2:49 pm
by Marshall Grice
i'm curious what you're going to use it for?
Posted: Mon Jul 26, 2010 3:26 pm
by Will Kalman
Marshall Grice wrote:i'm curious what you're going to use it for?
I'm guessing a lightweight driveshaft. Everything on either end of it has already broken and it's feeling left out. }:)
Posted: Mon Jul 26, 2010 3:33 pm
by Aaron Goldsmith
As a bonus everyone that runs after him will have a flat from all the carbon shards. :lol:
Posted: Mon Jul 26, 2010 5:32 pm
by Bill Schenker
Jayson Woodruff wrote:Hmm, tricky. Such a short run, other materials might be minimally more weight (like grams). If you NEED carbon, how about laying it out yourself or by some fiberglass worker? Three inch, thin wall... I'd make a few spares while you're at it.
TIA
Bill
Yeah, I wouldn't be saving that much over the alu. I have now, though that stuff is pretty thick walled. Thought about laying it up my self, but would have to get a right sized mandrel, a way of vacuum bagging it, etc. - was hoping to find something relatively low cost and thin walled.
Posted: Mon Jul 26, 2010 8:45 pm
by Bill Schenker
Robert Puertas wrote:http://www.carbonfibertubeshop.com/more%20tubing.html
or
or, 6061 aluminum:
Intake?
Thanks! That spar supplier might be the way to go! $88 for 2'. Less than half of the other stuff I found! And yes, for an intake.
Posted: Mon Jul 26, 2010 8:53 pm
by Bill Schenker
Intake tract.
Posted: Tue Jul 27, 2010 12:23 pm
by Mike Simanyi
Uh, you mean "tract?" I don't think anyone's racing around under your hood... ;)
Edited to add: ... except maybe wayward pieces parts.
I used the first link Robert provided, http://www.carbonfibertubeshop.com/more%20tubing.html" onclick="window.open(this.href);return false;
Posted: Tue Jul 27, 2010 12:38 pm
by Marshall Grice
for an intake pipe i'd use kevlar instead of carbon. Kevlar is lighter and you don't need the strength of carbon. plus it's probably cheaper.
